2. 软件版本:allegro16.6
3. 层数:12层
4. 用到的主要芯片:XC5VSX95T-FF1136+TMS320C6416TBGLZA6+AD9779ABSVZ
5. PCB尺寸:异形
| Bill of Material Report (Condensed) | | | | | |
| SYM_NAME | COMP_DEVICE_TYPE | COMP_VALUE | COMP_CLASS | QUANTITY | REFDES |
| 名称 | 类型 | 属性 | 类别 | 数量 | 位号 |
| 8_SO | MAX491EESD | | IC | 2 | U6; U20 |
| 24-PIN_QFN | EN5339QI | | IC | 4 | U24; U25; U26; U27 |
| 48PIN_TSOP | AM29LV320DB90EI | | IC | 2 | U8; U16 |
| 68-PIN_QFN | EN6360QI | | IC | 1 | U23 |
| ADT1-1WT | ADT2-1T | | IC | 1 | T5 |
| C0402 | 0_1UF | | IC | 127 | C47; C48; C49; C50; C51; C52; C53; C54; C55; C56; C57; C58; C62; C71; C73; C75; C76; C77; C78; C79; C80; C81; C82; C83; C84; C85; C86; C87; C88; C89; C90; C91; C92; C93; C94; C95; C96; C97; C98; C99; C100; C101; C102; C103; C104; C105; C106; C107; C108; C111; C112; C114; C115; C116; C117; C118; C119; C123; C124; C125; C126; C127; C128; C129; C130; C131; C132; C133; C134; C135; C136; C137; C138; C139; C140; C141; C142; C143; C144; C145; C146; C147; C148; C149; C150; C151; C152; C153; C154; C155; C156; C157; C158; C159; C160; C161; C162; C163; C164; C165; C166; C167; C168; C169; C170; C171; C172; C173; C193; C194; C195; C196; C197; C198; C199; C200; C201; C202; C203; C204; C205; C206; C214; C294; C295; C296; C313 |
| C0603 | 1UF | | IC | 25 | C1; C2; C5; C6; C9; C26; C46; C60; C61; C64; C65; C66; C67; C68; C69; C70; C72; C74; C186; C191; C192; C239; C240; C249; C250 |
| C0603 | 0_1UF | | IC | 106 | C3; C4; C8; C10; C11; C12; C13; C14; C15; C16; C17; C18; C19; C20; C21; C22; C24; C30; C31; C32; C33; C34; C35; C36; C37; C38; C40; C41; C42; C43; C44; C45; C59; C63; C174; C175; C176; C177; C178; C179; C180; C181; C182; C183; C184; C185; C187; C188; C207; C210; C213; C215; C216; C217; C219; C220; C221; C222; C224; C252; C254; C256; C258; C259; C260; C261; C262; C263; C264; C265; C266; C267; C268; C269; C270; C272; C276; C277; C279; C280; C281; C282; C283; C284; C285; C286; C289; C290; C291; C292; C297; C298; C299; C302; C303; C304; C305; C306; C307; C310; C314; C315; C317; C318; C320; C323 |
| C0603 | 12PF | | IC | 1 | C7 |
| C0603 | 0_01UF | | IC | 7 | C28; C208; C211; C300; C311; C321; C324 |
| C0603 | NC | | IC | 4 | C39; C218; C223; C316 |
| C0603 | 120PF | | IC | 1 | C109 |
| C0603 | 22PF | | IC | 5 | C209; C212; C301; C312; C322 |
| C0603 | 15PF | | IC | 1 | C229 |
| C0603 | 15NF | | IC | 1 | C230 |
| C0603 | 10PF | | IC | 3 | C237; C247; C248 |
| C0603 | 8_2PF | | IC | 1 | C238 |
| C0603 | 1NF | | IC | 5 | C271; C273; C308; C309; C319 |
| C0603 | 2_2UF | | IC | 5 | C274; C275; C278; C287; C288 |
| C0603 | 56PF | | IC | 2 | C325; C326 |
| C0603 | 0_22UF | | IC | 1 | C355 |
| C0805 | NC | | IC | 2 | C189; C190 |
| C0805 | 10UF | | IC | 2 | C251; C253 |
| C1206 | 10UF | | IC | 10 | C23; C25; C27; C29; C110; C113; C120; C121; C122; C293 |
| C1206 | 22UF | | IC | 6 | C225; C226; C231; C232; C241; C242 |
| C1206 | 47UF | | IC | 12 | C227; C228; C233; C234; C235; C236; C243; C244; C245; C246; C255; C257 |
| CP-8-2 | AD4899-1YCPZ | | IC | 2 | U10; U21 |
| CP-72-5 | LTC2260IUJ-14 | | IC | 1 | U5 |
| CP_48_8 | AD9219ABCPZ-40 | | IC | 1 | U4 |
| D0805 | LED-GREEN | | IC | 10 | D1; D2; D3; D4; D5; D6; D7; D8; D9; D10 |
| DSP_JTAG | DSP_JTAG | | IC | 1 | P1 |
| FILTER_3P | NFM18CC222R1C3 | | IC | 1 | E1 |
| FPGA_JTAG | FPGA_JTAG | | IC | 1 | P2 |
| HDR2X5 | HEADER_5X2 | | IC | 1 | P3 |
| J30J-21TJW-J | J30J-21TJW-J | | IC | 1 | XP_TEST |
| J30J-37TJN | J30J-37TJN | | IC | 1 | XP7 |
| L0603 | BLM18PG121SN1D | | IC | 16 | CLKL1; CLKL2; CLKL3; CLKL4; CLKL5; L4; L8; L9; L10; L11; L12; L13; L14; L15; L16; L17 |
| L0603 | BLM18PG330SN1D | | IC | 4 | L2; L3; L6; L7 |
| MSOP | LTC3260EMSE | | IC | 1 | U30 |
| OSC | 25MHZ | | IC | 1 | G1 |
| OSC | 14_7456MHZ | | IC | 1 | G2 |
| OSC | 50MHZ | | IC | 2 | G3; G4 |
| OSC | 20MHZ | | IC | 1 | G5 |
| PDS-120JW-01 | PDS-120JW-01 | | IC | 1 | XP4 |
| QFN-48 | CDCE62005RGZT | | IC | 1 | U19 |
| QFP-N20 | TPS74401RGW | | IC | 2 | U28; U29 |
| R0402 | 10K | | IC | 34 | R22; R52; R53; R54; R67; R97; R100; R113; R115; R116; R117; R118; R119; R120; R193; R194; R195; R196; R197; R198; R199; R200; R201; R202; R204; R205; R219; R235; R236; R237; R238; R239; R240; R241 |
| R0603 | 1K | | IC | 47 | R1; R2; R3; R6; R12; R15; R16; R21; R23; R26; R27; R29; R31; R36; R37; R40; R42; R44; R46; R50; R51; R62; R63; R65; R72; R74; R80; R81; R83; R84; R85; R87; R88; R104; R106; R130; R149; R150; R172; R174; R176; R181; R188; R189; R191; R192; R212 |
| R0603 | 10K | | IC | 27 | R4; R56; R57; R68; R76; R103; R107; R111; R112; R125; R126; R128; R129; R142; R143; R144; R145; R146; R177; R183; R184; R185; R211; R246; R247; R248; R249 |
| R0603 | NC | | IC | 38 | R5; R14; R18; R28; R30; R32; R33; R34; R35; R38; R39; R41; R43; R45; R47; R48; R49; R55; R59; R61; R66; R73; R75; R82; R86; R124; R127; R168; R170; R171; R173; R178; R179; R180; R182; R187; R209; R218 |
| R0603 | 24_9_1 | | IC | 6 | R7; R8; R69; R70; R210; R220 |
| R0603 | 100 | | IC | 4 | R9; R71; R121; R217 |
| R0603 | 200 | | IC | 4 | R10; R11; R122; R123 |
| R0603 | 25 | | IC | 8 | R13; R17; R24; R147; R169; R175; R186; R190 |
| R0603 | 50 | | IC | 5 | R19; R20; R25; R224; R225 |
| R0603 | 4_7K | | IC | 27 | R58; R60; R77; R78; R79; R89; R90; R91; R92; R94; R95; R96; R98; R102; R105; R108; R109; R110; R114; R134; R135; R136; R137; R138; R139; R140; R314 |
| R0603 | 22 | | IC | 6 | R64; R131; R132; R133; R234; R244 |
| R0603 | 140 | | IC | 1 | R93 |
| R0603 | 330 | | IC | 2 | R99; R101 |
| R0603 | 0 | | IC | 7 | R141; R148; R203; R213; R221; R245; R312 |
| R0603 | 243K_1 | | IC | 1 | R151 |
| R0603 | 15K | | IC | 1 | R152 |
| R0603 | 365K_1 | | IC | 1 | R153 |
| R0603 | 3_57K_1 | | IC | 3 | R154; R164; R165 |
| R0603 | 100K | | IC | 3 | R155; R228; R230 |
| R0603 | 348K_1 | | IC | 5 | R156; R157; R158; R160; R161 |
| R0603 | 77_4K | | IC | 1 | R159 |
| R0603 | 110K_1 | | IC | 1 | R162 |
| R0603 | 174K_1 | | IC | 1 | R163 |
| R0603 | 1_15K_1 | | IC | 1 | R166 |
| R0603 | 2_87K_1 | | IC | 1 | R167 |
| R0603 | 240 | | IC | 2 | R206; R207 |
| R0603 | 15 | | IC | 2 | R208; R214 |
| R0603 | 1K_1 | | IC | 1 | R215 |
| R0603 | 287_1 | | IC | 1 | R216 |
| R0603 | 1_0M | | IC | 3 | R222; R226; R227 |
| R0603 | 316K | | IC | 2 | R223; R229 |
| R0603 | 200K | | IC | 1 | R231 |
| R0603 | 33 | | IC | 64 | R250; R251; R252; R253; R254; R255; R256; R257; R258; R259; R260; R261; R262; R263; R264; R265; R266; R267; R268; R269; R270; R271; R272; R273; R274; R275; R276; R277; R278; R279; R280; R281; R282; R283; R284; R285; R286; R287; R288; R289; R290; R291; R292; R293; R294; R295; R296; R297; R298; R299; R300; R301; R302; R303; R304; R305; R306; R307; R308; R309; R310; R311; R315; R316 |
| RESET_SMD | RESET | | IC | 1 | S1 |
| SM-22 | MABAES0060 | | IC | 1 | T1 |
| SMA | BMA-JHD | | IC | 4 | XP5; XP6; XP8; XP9 |
| SOT23-5 | TPS3823-33DBVT | | IC | 1 | U9 |
| SOT-23 | MAX4594DBVR | | IC | 1 | U17 |
| SSOP | IDT74LVC16245APV | | IC | 5 | U11; U12; U13; U15; U18 |
| SSOP | IDT74ALVC164245PV | | IC | 1 | U14 |
| TEST-PAD | TEST_PAD | | IC | 4 | TEST1; TEST2; TEST3; TEST4 |
| TMS320C6416T | TMS320C6416TBGLZA6 | | IC | 1 | U1 |
| TQFP_EP | AD9779ABSVZ | | IC | 1 | U22 |
| TSOP | MT48LC4M32B2TG | | IC | 1 | U7 |
| XC5VSX95T-FF1136 | XC5VSX95T-FF1136 | | IC | 1 | U3 |
| XC_FT64 | XCF128XFT64C | | IC | 1 | U2 |
