| Bill of Material Report (Condensed) |
| SYM_NAME | COMP_DEVICE_TYPE | COMP_VALUE | COMP_CLASS | QUANTITY | REFDES |
| 名称 | 类型 | 属性 | 类别 | 数量 | 位号 |
| 402 | CAP_0.1UF_X7R_16V_10% 0402 _402 | 0.1uf,16V | IC | 14 | C4; C111; C164; C186; C202; C216; C217; C218; C219; C225; C226; C227; C228; C229 |
| 402 | CAP_0.01UF_X7R_16V_10%_0402_402 | 0.01uf,16V | IC | 83 | C30; C31; C33; C35; C38; C39; C43; C44; C45; C46; C47; C48; C49; C50; C51; C52; C53; C54; C55; C56; C57; C58; C59; C60; C61; C62; C63; C65; C66; C67; C68; C69; C70; C71; C72; C73; C74; C75; C76; C77; C78; C80; C81; C82; C83; C84; C85; C86; C87; C88; C89; C90; C94; C95; C96; C97; C99; C100; C101; C102; C103; C104; C105; C107; C108; C112; C113; C114; C115; C116; C117; C118; C119; C120; C121; C122; C123; C124; C125; C127; C185; C223; C224 |
| 402 | CAP_25PF_NPO_100V_5%_0805_0402_ | 25pF,50V | IC | 2 | C32; C34 |
| 402 | CAP_18PF_COG_50V_5%_0402_402_18 | 18pF,50V | IC | 4 | C36; C37; C221; C222 |
| 402 | CAP_0.001_X7R_50V_5%_0402_402_0 | 0.001uf,50V | IC | 1 | C40 |
| 402 | CAP_1.0UF_X5R_10V_10%_0402_402_ | 1uF,10V | IC | 5 | C91; C92; C93; C106; C131 |
| 402 | CAP_1.0UF_X5R_10V_10%_0402_40_1 | 1uF,10V,DNI | IC | 1 | C110 |
| 402 | RES_100K_1/16W_1%_0402_402_10_3 | 100K | IC | 1 | R8 |
| 402 | RES_10K_1/16W_1%_0402_402_10K,1 | 10K,1% | IC | 14 | R11; R34; R90; R213; R214; R215; R216; R217; R218; R219; R249; R251; R252; R261 |
| 402 | RES_1.1K_1/16W_1%_0402_402_1K | 1K | IC | 5 | R29; R257; R258; R259; R260 |
| 402 | RES_100K_1/16W_1%_0402_402_10_2 | 100K,1% | IC | 16 | R30; R31; R91; R99; R102; R105; R108; R109; R112; R113; R114; R116; R117; R119; R120; R122 |
| 402 | RES_1M_1/16W_1%_0402_402_1M, DN | 1M, DNI | IC | 1 | R32 |
| 402 | RES_0_1/16W_1%_0402_402_0 | 0 | IC | 5 | R33; R35; R36; R88; R220 |
| 402 | RES_33_0402_402_33,0402 | 330,402 | IC | 45 | R37; R38; R39; R40; R41; R42; R43; R44; R45; R46; R47; R48; R49; R50; R51; R52; R53; R54; R55; R56; R57; R58; R59; R60; R61; R62; R63; R64; R65; R66; R67; R68; R69; R70; R71; R72; R73; R74; R75; R76; R77; R80; R81; R82; R83 |
| 402 | RES_33_0402_402_22,0402 | 220,402 | IC | 2 | R78; R79 |
| 402 | RES_2.2K_1/16W_1%_0402_402_2.2K | 2.2K,1% | IC | 4 | R84; R85; R248; R250 |
| 402 | RES_50_2W_1%_4124_0402_49.9,1% | 49.9,1% | IC | 1 | R86 |
| 402 | RES_100K_1/16W_1%_0402_402_9.1K | 9.1K,1% | IC | 3 | R92; R94; R95 |
| 402 | RES_100K_1/16W_1%_0402_402_9._1 | 9.1K,1%,DNI | IC | 1 | R93 |
| 402 | RES_100K_1/16W_1%_0402_402_10_1 | 100K,1%,DNI | IC | 13 | R96; R97; R98; R101; R103; R104; R106; R107; R110; R111; R115; R118; R121 |
| 402 | RES_100K_1/16W_1%_0402_402_100K | 100K,1%.DNI | IC | 1 | R100 |
| 402 | ZEROOHMRESISTOR1/16W0402_402_0 | 0 | IC | 1 | R131 |
| 402 | RES_100K_1/16W_1%_0402_402_10K, | 10K,1% | IC | 1 | R188 |
| 402 | RES_0_1/16W_1%_0402_402_0,DNI | 0,DNI | IC | 6 | R190; R191; R192; R194; R195; R196 |
| 402 | RES_100_1/10W_5%_0402_402_100,5 | 100,5%,DNI | IC | 1 | R193 |
| 402 | RES_1M_1/16W_1%_0402_402_1.6M,1 | 1.6M,1% | IC | 1 | R230 |
| 402 | RES_1M_1/16W_1%_0402_402_180K,1 | 180K,1% | IC | 1 | R231 |
| 402 | RES_100K_1/16W_1%_0402_402_392K | 392K,1% | IC | 1 | R232 |
| 402 | RES_0_1/16W_1%_0402_402_0,1% | 0,1% | IC | 12 | R239; R240; R241; R242; R243; R244; R245; R246; R256; R262; R263; R266 |
| 402 | RES_10K_1/16W_1%_0402_402_100K | 100K | IC | 1 | R247 |
| 402 | RES_12.1K_1/16W_1%_0402_402_12. | 12.1K,1% | IC | 1 | R253 |
| 402 | RES_0_1/16W_1%_0402_402_0, DNI | 0, DNI | IC | 1 | R267 |
| 805 | CAP_10UF_Y5V_10V_10%_0805_805_1 | 10uF,10V | IC | 6 | C41; C42; C64; C79; C98; C201 |
| 805 | CAP_22UF_X5R_6.3V_120%_0805_805 | 22uF,6.3V | IC | 1 | C126 |
| 805 | CAP_10UF_Y5V_10V_10%_0805_0805_ | 2.2uF, 25V | IC | 2 | C203; C204 |
| 7343 | CAP POL_7343_47UF | 47uF | IC | 1 | C2 |
| 6605728-1 | CONNECTORRJ45_10_100MB_6605728- | RJ-45 10_100Mb | IC | 2 | J2; J3 |
| AM33XX_15X15 | IC_AM335X_ZCE_2_AM33XX_15X15_AM | AM335X_ZCZ | IC | 1 | U5 |
| BGA84_8X12P5_P8MM | MEM_MT47H64M16_FBGA84_1_BGA84_8 | MT47H128M16RT-25E:C | IC | 1 | U7 |
| BLM18A | FERRITEEMI600OHM500MASMD0603_BL | 600OHM500mA | IC | 2 | FB4; FB7 |
| CHKFOOTPRINT | 4.7UH30%0.9ASMD_CHKFOOTPRINT_4. | 4.7uH | IC | 1 | L1 |
| CON14_P5MM_3P75X9P5SMD | CONN FLEX 14_CON14_P5MM_3P75X9P | 10051922-1410ELF | IC | 1 | J13 |
| CONN_OSTTC02 | CONN_LEADSCREWDOWN_2PIN_CONN_OS | OSTTC022162, DNI | IC | 1 | J14 |
| DA2304 | DA2304-ALB_DA2304_DA2304 | DA2304 | IC | 1 | L5 |
| DBV5 | TPS61041DBV_DBV5_TPS61041DBV | TPS61041DBV | IC | 1 | U27 |
| DCK5 | SN74LVC1G06DCK_0_DCK5_SN74LVC1G | SN74LVC1G06DCK | IC | 1 | U22 |
| DCK5 | SN74LVC1G07DCK_DCK5_SN74LVC1G07 | SN74LVC1G07DCK | IC | 1 | U23 |
| DO157LS_116X220SMA | DIODE_5ARECT_REV40V_3_DO157LS_1 | B340A-13-F | IC | 1 | D33 |
| HDR2X20_50LS | CONN PCB 20X2_HDR2X20_50LS_CONN | CONN PCB 20x2 | IC | 1 | J9 |
| HDR2X25_50LS | CONN PCB 25X2_HDR2X25_50LS_CONN | CONN PCB 25x2 | IC | 1 | J12 |
| HEADER10X2_SMD | HDR_10X2_CJTAG_0_HEADER10X2_SMD | CTI JTAG,DNI | IC | 1 | P2 |
| HTQFP_48PIN | TLK110_2_HTQFP_48PIN_TLK110 | TLK110 | IC | 2 | U12; U14 |
| IND108SMD_110X102 | INDUCTOR_IND108SMD_110X102_VLF3 | VLF3010AT-2R2M1R0 | IC | 1 | L6 |
| IND_354SMD_400SQ | INDUCTOR IRON_IND_354SMD_400SQ_ | 68uH | IC | 1 | L7 |
| LED4_1210SMD-1 | 598-8610-307F_LED4_1210SMD-1_59 | 598-8610-307F | IC | 2 | D4; D5 |
| LQFP64_10X10 | IC_FT2232H_LQFP64_LQFP64_10X10_ | FT2232LQFN64 | IC | 1 | U8 |
| MBR0520L | DIODE_500MA20V_MBR0520L_MBR0520 | MBR0520LT1 | IC | 3 | D12; D13; D32 |
| MC-306 | CRYS_32_768KHZ_SMD32_MC-306_32. | 32.768KHz MC-306 | IC | 1 | Y1 |
| MELF0102 | RES_10K_1/16W_1%_0402_MELF0102_ | 49.9, MELF | IC | 1 | R268 |
| MELF0102 | RES_10K_1/16W_1%_0402_MELF010_1 | 1.2K, MELF | IC | 8 | R269; R270; R271; R272; R273; R274; R275; R276 |
| NORCOMP_DB9F_SMD | CONN_DSUB9F_NORCOMP_DB9F_SMD_CO | Conn_DB9F | IC | 1 | J8 |
| PW8 | SN74CBQ3306APW_PW8_SN74CBQ3306A | SN74CBQ3306APW | IC | 1 | U29 |
| RAPC712 | CONN_PWRJACK_RAPC712_RAPC712_RA | RAPC712 | IC | 1 | J1 |
| SC70-5 | LM94022_SC70-5_LM94022 | LM94022 | IC | 1 | U6 |
| SD-MICRO-SCHA5B0300 | MICROSD_CONN_8_SD-MICRO-SCHA5B0 | SCHA5B0200 | IC | 1 | P3 |
| SIP2_50LS | CONN PCB 2_SIP2_50LS_CONN PCB 2 | CONN PCB 2 | IC | 3 | J4; J5; J7 |
| SIP3_50LS | CONN PCB 3_SIP3_50LS_CONN PCB 3 | CONN PCB 3 | IC | 2 | J6; J10 |
| SM-7351-CAP-0402 | 0.01UFCAPACITOR16V10%0402_SM-73 | 0.01uF | IC | 16 | C1; C143; C144; C147; C148; C150; C158; C159; C162; C163; C166; C167; C169; C175; C191; C200 |
| SM-7351-CAP-0402 | 0.1UFCAPACITOR16V10%0402_SM-735 | 0.1uF | IC | 29 | C3; C128; C129; C130; C132; C133; C134; C135; C136; C138; C139; C140; C141; C142; C145; C146; C153; C154; C155; C156; C157; C160; C161; C172; C173; C176; C211; C212; C238 |
| SM-7351-CAP-0402 | 1UFCAPACITOR16V10%0402_SM-7351- | 1uF | IC | 3 | C5; C28; C29 |
| SM-7351-CAP-0402 | 2.2UFCAPACITOR6.3V20%SMDX5R0402 | 2.2uF | IC | 9 | C8; C18; C19; C20; C21; C24; C25; C26; C27 |
| SM-7351-CAP-0402 | 0.1UFCAPACITOR16V10%0402_SM-7_1 | 0.01uF | IC | 1 | C15 |
| SM-7351-CAP-0402 | 15PFCAPACITOR50V10%SMD0402_SM-7 | 15pF | IC | 2 | C149; C151 |
| SM-7351-CAP-0402 | 100PFCAPACITOR16V10%0402_SM-735 | 100pF | IC | 2 | C177; C178 |
| SM-7351-CAP-0402 | 2.2UF16V10%SMD0805_SM-7351-CAP- | 2.2uF | IC | 2 | C190; C198 |
| SM-7351-CAP-0402 | 0.001UFCAPACITOR50V5%0402_SM-73 | 0.001uF | IC | 1 | C192 |
| SM-7351-CAP-0402 | 0.1UFCAPACITOR50V10%0402_SM-735 | 0.1uF | IC | 2 | C193; C194 |
| SM-7351-CAP-0402 | 1UFCAPACITOR10V10%0402_SM-7351- | 1uF | IC | 1 | C199 |
| SM-7351-CAP-0402 | 15PFCAPACITOR50V10%SMD0402_SM_1 | 10pF | IC | 1 | C206 |
| SM-7351-CAP-0402 | 3.3UFCAPACITOR16V10%0603_SM-7_1 | 1uF/16V | IC | 4 | C207; C208; C209; C210 |
| SM-7351-CAP-0402 | 0.001UFCAPACITOR50V5%0402_SM-_1 | 0.022uF | IC | 9 | C215; C230; C231; C232; C233; C234; C235; C236; C237 |
| SM-7351-CAP-0603 | 4.7UFCAPACITOR6.3V20%SMDX5R0603 | 4.7uF | IC | 5 | C7; C16; C17; C22; C23 |
| SM-7351-CAP-0603 | CAP_4.7UF_X5R_6.3V_10%_0603_SM- | 4.7uF | IC | 2 | C109; C220 |
| SM-7351-CAP-0603 | 4.7UFCAPACITOR16V20%TANT_SM-735 | 4.7uF | IC | 1 | C170 |
| SM-7351-CAP-0603 | 3.3UFCAPACITOR16V10%0603_SM-735 | 4.7uF | IC | 1 | C174 |
| SM-7351-CAP-0805 | 10UFCAPACITOR16V10%0805_SM-7351 | 10uF | IC | 11 | C6; C9; C10; C11; C12; C13; C14; C137; C152; C168; C171 |
| SM-7351-CAP-0805 | 2.2UF16V10%SMD0805_SM-7351-CA_1 | 2.2uF | IC | 2 | C213; C214 |
| SM-7351-CAP-1206 | 10UFCAPACITOR50V10%1206_SM-7351 | 10uF,50V | IC | 3 | C196; C197; C205 |
| SM-7351-IND-0805 | FER_180_200_0_SM-7351-IND-0805_ | 150OHM800mA | IC | 6 | FB1; FB2; FB3; FB10; FB11; FB12 |
| SM-7351-IND-0805 | FERBEAD_180OHM200MA_SM-7351-IND | 150OHM800mA | IC | 4 | FB5; FB6; FB8; FB9 |
| SM-7351-RES-0402 | 150OHM1/16W1%SMD0402_SM-7351-RE | 150 | IC | 19 | R1; R18; R123; R124; R125; R126; R204; R206; R207; R208; R209; R210; R211; R212; R221; R222; R227; R228; R229 |
| SM-7351-RES-0402 | 4.7KOHMRESISTOR1/16W0402_SM-735 | 4.7K | IC | 2 | R2; R3 |
| SM-7351-RES-0402 | ZEROOHMRESISTOR1/16W0402_SM-735 | 0 | IC | 9 | R6; R7; R15; R28; R151; R173; R187; R198; R199 |
| SM-7351-RES-0402 | 10KOHMRESISTOR1/16W0402_SM-7351 | 10K | IC | 23 | R10; R12; R14; R17; R87; R132; R133; R134; R135; R136; R137; R150; R158; R172; R175; R203; R205; R233; R234; R235; R254; R255; R264 |
| SM-7351-RES-0402 | 10KOHMRESISTOR1/16W0402_SM-73_1 | 3.24K | IC | 1 | R13 |
| SM-7351-RES-0402 | 100KOHMRESISTOR1/16W0402_SM-735 | 1K | IC | 10 | R127; R128; R129; R130; R223; R224; R225; R226; R236; R237 |
| SM-7351-RES-0402 | 330OHM1/16W5%SMD0402_SM-7351-RE | 330 | IC | 6 | R138; R142; R143; R160; R164; R165 |
| SM-7351-RES-0402 | 2.2KOHMRESISTOR1/16W0402_SM-735 | 2.2K | IC | 24 | R139; R140; R141; R144; R152; R153; R154; R155; R156; R157; R161; R162; R163; R166; R167; R176; R177; R178; R179; R180; R181; R184; R201; R202 |
| SM-7351-RES-0402 | 2.2KOHMRESISTOR1/16W0402_SM-7_1 | 2.2K, DNI | IC | 1 | R145 |
| SM-7351-RES-0402 | 49.9OHMRESISTOR1/16W0402_SM-735 | 49.9 | IC | 8 | R146; R147; R148; R149; R168; R169; R170; R171 |
| SM-7351-RES-0402 | 4.99KOHMRESISTOR1/16W0402_SM-73 | 4.99K | IC | 2 | R159; R174 |
| SM-7351-RES-0402 | 100KOHMRESISTOR1/16W0402_SM-7_1 | 100K | IC | 2 | R182; R183 |
| SM-7351-RES-0402 | 33OHMRESISTOR1/16W5%0402_SM-735 | 33 | IC | 2 | R185; R186 |
| SM-7351-RES-0402 | R_SM-7351-RES-0402_4.7K | 4.7K | IC | 3 | R189; R197; R238 |
| SM-7351-RES-0402 | 10KOHMRESISTOR1/16W0402_SM-73_2 | 12.1K | IC | 1 | R265 |
| SM-7351-RES-0603 | ZEROOHMRESISTOR1/16W0603_SM-735 | 0 | IC | 13 | R4; R5; R9; R16; R19; R20; R21; R22; R23; R24; R25; R26; R27 |
| SM-7351-RES-0603 | 25KOHM1/10W0.1%SMD0603_SM-7351- | 25K | IC | 1 | R200 |
| SM-SO-SC70-5 | SN74LVC1G08DCKT_SC70_SM-SO-SC70 | SN74LVC1G08 | IC | 2 | U13; U15 |
| SMCJ36CA | DIODE_SMCJ36CA_SMCJ36CA_SMCJ26C | SMCJ26CA | IC | 1 | D23 |
| SMDSC70-5 | TPS71718_SMDSC70-5_TPS71718 | TPS71718 | IC | 1 | U2 |
| SMINI6-F3-B | RN1907_SMINI6-F3-B_DMC56404 | DMC56404 | IC | 5 | Q1; Q2; Q3; Q4; Q5 |
| SM_LED_0603 | LED_GREEN_SM_LED_0603_GREEN LED | Green LED | IC | 14 | D3; D6; D8; D9; D10; D11; D24; D25; D26; D27; D28; D29; D30; D31 |
| SM_LED_0603 | LED_RED_SM_LED_0603_RED LED | Red LED | IC | 1 | D7 |
| SM_OSC_ABM3 | CRYSTAL25MHZABM3_SM_OSC_ABM3_25 | 25MHz | IC | 1 | Y4 |
| SO8_W_DUB | ISO1050_SO8_W_DUB_ISO1050 | ISO1050 | IC | 1 | U20 |
| SOD-123 | DIODE_5ARECT_REV40V_2_SOD-123_M | MBRX140-TP | IC | 1 | D22 |
| SOIC8_265 | W25Q64_SOIC8_265_W25Q64 | W25Q64 | IC | 1 | U19 |
| SOIC-8 | TPS5410D_SOIC-8_TPS5410D | TPS5410D | IC | 1 | U28 |
| SOIC_8 | TPS76650_SOIC_8_TPS76650 | TPS76650 | IC | 1 | U18 |
| SOIC_8 | CAT24C256W_SOIC_8_CAT24C256W | CAT24C256W | IC | 1 | U21 |
| SOT23-6 | IC_93C46B_SSOT23-6_SOT23-6_93C4 | 93C46B_SOT23-6 | IC | 1 | U17 |
| SW3_4X2P5 | SW_DP_MOM_SW3_4X2P5_DISCRETE_B3 | B3U-1100 | DISCRETE | 1 | S1 |
| TFBGA48 | M29W128G_0_TFBGA48_M29W160EB70Z | M29W160EB70ZA6E | IC | 1 | U10 |
| TH_TP_5002 | TESTPOINTTHROUGHHOLE_TH_TP_5002 | TP | IC | 1 | TP3 |
| TP60C_SMD | TESTPT1_TP60C_SMD_TESTPT1 | TESTPT1 | IC | 3 | TP7; TP8; TP9 |
| TP_SMD1MMCIRCLE | TESTPOINT_SMD1MMCIRCLE_TP_SMD1M | TP1mm | IC | 17 | TP1; TP4; TP5; TP10; TP11; TP12; TP13; TP14; TP15; TP16; TP17; TP18; TP19; TP20; TP21; TP22; TP23 |
| TQFP-100 | CY7C024AV/025AV/026AV_0_TQFP-10 | CY7C024AV/025AV/026AV | IC | 1 | U9 |
| TVSOP-48 | SN74ALVCH16374DGV_0_TVSOP-48_SN | SN74ALVCH16374DGV | IC | 1 | U11 |
| USB-MINI-SMT-NUM | MINI-USB-AB-SOCKET_USB-MINI-SMT | mini USB-B | IC | 1 | P4 |
| U_8_DCU | IC_SN74AUP2G08_8-VSSOP_U_8_DCU_ | SN74AUP2G08 | IC | 2 | U3; U4 |
| U_16_D | TPIC2810_U_16_D_TPIC2810 | TPIC2810 | IC | 1 | U26 |
| U_16_DW | ISO1176T_U_16_DW_ISO1176T | ISO1176T | IC | 1 | U16 |
| U_28_PWP | SN65HVS882_U_28_PWP_SN65HVS882 | SN65HVS882 | IC | 1 | U25 |
| U_48_RSL | TPS65910_0_U_48_RSL_TPS65910 | TPS65910 | IC | 1 | U1 |
| VLCF5020T | 2.2UHINDUCTOR10%2.6ASMD_VLCF502 | 2.2uH | IC | 3 | L2; L3; L4 |
| XTAL4_3P2X2P5_SMD | CRYS_24MHZ_SCC_XTAL4_3P2X2P5_SM | 24MHz | IC | 1 | Y2 |
| XTAL4_3P2X5SMD | XTAL_HC-49SMT | 12.000MHz | IC | 1 | Y6 |
附件:
