作品名:[AD 10][4层]主控板(STM32F407ZG+ADV7123+THC61LVDM63A)PCB源文件2 w- i5 s( |, Y6 ~
) S4 a: E$ j" G, D' T. f
文件描述
4 W/ N$ o6 h4 G" C9 A/ \' x" V, }
1. 作品用途:主控板
9 C5 L! J2 y- a9 _( L( U( x
/ I! \5 D/ {3 `5 f2. 软件版本:AD 10( K$ I& a ]+ p) u! q: ?
: ^, W6 l: i2 F1 ]5 F& M0 W" T2 j& Y
3. 层数:4层板
- l% @# z8 c- e7 q4 o
& O0 K* }# F$ _4. 用到的主要芯片:STM32F407ZG+ADV7123+THC61LVDM63A
& i6 F1 j1 N: A; ?- w7 a
( F' y( o; X$ u/ w' F4 }, u5. PCB尺寸:115mm*110mm: ?$ P2 H3 u7 A _
" ] a4 z0 |! V8 n; r: o! f' O
4 d5 T: N4 a* Y7 P: _
作品截图如下:% k2 X$ x; K r
' j' W1 X- q* H: a/ V1 B1 r顶层截图:
5 Y5 E" t# F& V5 w* A* U
2 \! S3 Y, \6 \3 J! U, s1 R
$ D. V) [# P) `! B8 \) p5 }" `+ ~9 a
底层截图: k: U) `8 B: @" J' c# ^9 W
$ S J: f' T1 e6 [9 N
# A) [1 R8 \' U) |( x+ A) a9 |全层截图:: p, R6 c5 c+ I3 {: m: V' S) S3 T/ N
( d$ [% p5 [/ C6 \9 G+ {1 w" v! h( t9 K2 b
叠层信息截图如下:& Y1 `" u) p1 E
1 j# T' s' N2 e1 \* X
7 Z& G4 m) a) {& C
BOM:
3 V$ @. D- y- q| Comment(属性) | Designator(位号) | Footprint(封装) | Quantity(数量) | | BAT1 | CR20XX | 1 | | 22uF/10V | C1, C10, C16 | C_B | 3 | | 150nF | C2, C3 | 0805r | 2 | | 2.2uF | C4 | 1206 | 1 | | 470pF | C5 | 0805r | 1 | | 22uF/16V | C6, C9, C14 | C_B | 3 | | 104 | C7, C8, C48, C55, C80, C82, C86, C87, C90, C92 | 0805r | 10 | | 104 | C11, C12, C13, C15, C17, C19, C20, C21, C22, C23, C24, C25, C26, C27, C28, C29, C30, C31, C34, C39, C40, C41, C42, C43, C44, C45, C60, C61, C62, C65, C66, C67, C68, C69, C70, C71, C72, C73, C74, C75, C76, C77, C78, C104 | 0603R | 44 | | 2.2uF/25V | C18, C46, C47, C49, C50, C51, C52, C53, C57, C59 | 1206 | 10 | | 2.2uF/16V | C32, C33 | 1206 | 2 | | 22p | C35, C36 | 0805r | 2 | | 6p | C37, C38 | 0805r | 2 | | 47uF/25V | C54 | C_C | 1 | | 103 | C56, C58, C81 | 0805r | 3 | | 10uF/CAP-B | C63 | C_B | 1 | | 102/2KV | C64 | 1206 | 1 | | 47uF/16V | C79, C83, C84, C85, C89, C105, C106, C107 | C_C | 8 | | 33nF | C88, C91, C93 | 0805R | 3 | | Ccross | C94, C95, C96, C97, C98, C99, C100, C101, C102, C103 | 1206Cross | 10 | | 4148 | D1, D2 | 4148 | 2 | | SS14 | D3, D4, D5, D6, D7, D8 | SS14 | 6 | | TCMA201209 | FB1, FB8, FB9, FB10, FB11 | 1206 | 5 | | FB2, FB12, LED1 | 0805r | 3 | | TCMA201209 | FB3, FB4, FB5, FB6, FB7 | 0805r | 5 | | 151 | FB13, FB14, FB15 | 0805r | 3 | | CON4 | J1 | A2512WR-4P | 1 | | CON6 | J2 | C3030-2*3PZ | 1 | | J3, J4 | SIP2 | 2 | | CON4 | J5 | SIP4 | 1 | | CON4 | J6, J8 | A2512WV-4P | 2 | | J7, J12, J16 | A2512WV-3P | 3 | | J9, J10 | IDC20-2.0 | 2 | | CON6 | J11 | A2512WV-6P | 1 | | J13, J14, J15, J17, J19 | A2512WV-2P | 5 | | CON3 | J18 | A2512WV-3P | 1 | | 9013 | Q1, Q2, Q5, Q6, Q9, Q10, Q16, Q19 | SOT-23-BEC | 8 | | 9012 | Q3, Q7, Q11 | SOT-23-BEC | 3 | | AO3401 | Q4, Q8, Q12, Q18 | SOT-23-BEC | 4 | | A03402 | Q13, Q14, Q15, Q17 | SOT-23-BEC | 4 | | 1.5K | R1, R29, R31, R91 | 0805r | 4 | | 22 | R2, R3, R47, R48, R49, R50, R51 | 0805r | 7 | | 1K | R4, R11, R12, R13, R14, R21, R22, R26, R27, R28, R30, R32, R89 | 0805r | 13 | | 10K | R5, R10, R20, R38, R40, R41, R86, R87, R88 | 0805r | 9 | | 22K | R6 | 0805r | 1 | | 60 | R7, R8 | 0805r | 2 | | 510 | R9 | 0805r | 1 | | 5.1K | R15, R16, R17, R18, R19, R34 | 0805r | 6 | | 2K | R23 | 0805r | 1 | | 0Ω | R24, R25 | 0805r | 2 | | 33K | R33, R90 | 0805r | 2 | | 22 | R35 | 1206 | 1 | | 13K | R36 | 0805r | 1 | | 1.8K | R37 | 0805r | 1 | | 560 1% | R39 | 0805r | 1 | | 75Ω1% | R42, R43, R44 | 0805r | 3 | | 0 | R45, R46 | 0805r | 2 | | 1kΩ | R52, R54, R56, R57, R58, R64, R66, R67, R68, R74, R76, R77, R78, R93 | 0805r | 14 | | 75kΩ | R53 | 0805r | 1 | | 10kΩ | R55, R59, R60, R61, R65, R69, R70, R71, R75, R79, R80, R81, R84, R85, R92, R94 | 0805r | 16 | | 1.2kΩ | R62, R72, R82 | 0805r | 3 | | 1Ω | R63, R73, R83 | 2512 | 3 | | 1M | R95 | 1206 | 1 | | MPX2010GS | S1, S2 | MPX2010GS | 2 | | USBLC6 | U1 | SOP6 | 1 | | TS4871ID | U2 | SOP8 | 1 | | TJA1050 | U3 | SOP8 | 1 | | NCV1117 | U4 | SOT-223 | 1 | | W25X16 | U5 | SOP8 | 1 | | DS1232 | U6 | SOP8 | 1 | | TPS79333 | U7 | SOT-23 | 1 | | STM32F407ZG | U8 | TQFP-144 | 1 | | IS42S16400 | U9 | TSSOP-54 | 1 | | LM258 | U10, U23, U24 | SOP8 | 3 | | AD623 | U11, U12 | SOP8 | 2 | | LT1962 | U13 | MSOP8 | 1 | | LT1762-5.0 | U14 | MSOP8 | 1 | | REF3030 | U15 | SOT-23-BEC | 1 | | ADV7123 | U16 | LQFP48 | 1 | | THC61LVDM63A | U17 | SSOP48 | 1 | | MAX232 | U18 | SO-G16 | 1 | | 78L08 | U19 | SOT-89 | 1 | | NE555 | U20 | SOP8 | 1 | | 79L08 | U21 | SOT-89 | 1 | | TLC084 | U22 | SSOP14 | 1 | | SN74LVC1G04 | U25 | SOT-23 | 1 | | 25MHz | X1 | 49U | 1 | | 32768 Hz | X2 | MC | 1 | 6 r% K; W4 X6 j4 q5 b$ C" d( H
附件:
6 r8 O+ g' f) h5 K+ _9 F0 l! [8 {( o$ X3 x8 l$ u8 f F
PCB源文件如下:' \, ]* e# X# o3 F$ j
' F) J" v9 ~# u1 S, |. }" d- d6 o- {7 A# ^& p) i
! y$ B7 p& y4 \! t4 ^3 A5 y% ]
+ u2 l; k- @; s
