% s; D7 u0 L5 B, h* w. _4 U- |: I[allegro16.6][4层] C2392 MIPI CSI 接口摄像头模组(C2392_PLCC10X10_MIPI_FSI+DIP_HS300_MIPI+HDR3)pcb文件( ?4 `" u( q8 T* H6 U
' ], w& N' E5 Y G7 z; \/ O9 g文件描述:
, r0 }7 z9 S- R: j) k- Q' l* U7 T* t, V4 _3 C
1. 作品用途:C2392 MIPI CSI 接口摄像头模组" w3 W& d3 u `! T/ W. V
2. 软件版本:allegro16.6% S( b ?1 u+ P3 t t- C/ B: \
3. 层数:4层
+ r1 O7 d( N- K1 u* t" L4. 用到的主要芯片:C2392_PLCC10X10_MIPI_FSI+DIP_HS300_MIPI+HDR3
( V1 B- E$ _/ F$ p5. pcb尺寸: 46*70 MM' }! I% i9 H1 o3 R; E: V
$ p0 T' X W$ d$ l' a/ G作品截图如下:, g/ n, M# a: |, s @
% @5 T( ^( q5 j R. O) |% B顶层截图:
, z+ v" |8 f% S8 u8 [
9 `/ I% ]( T! N底层截图:
+ l4 @ e3 N3 q5 E, S& ~
; @# Y" H9 Z% f# ^
( ^8 o: P& P* I1 Z
全层截图:
( x' g/ Q6 P+ |: u7 {# A7 y+ g1 |, \
0 B- m" M# q+ \' o
, B. Q/ G3 b, K! ^BOM:7 N5 k- n; ?+ v2 X
| Bill of Material Report (Condensed) | | SYM_NAME | COMP_DEVICE_TYPE | COMP_VALUE | COMP_CLASS | QUANTITY | REFDES | | 名称 | 类型 | 属性 | 类别 | 数量 | 位号 | | 603 | CAP NP_0_0603_0.1UF-0603 | 0.1uF-0603 | IC | 11 | C1; C2; C3; C4; C5; C7; C9; C10; C11; C15; C36 | | 603 | CAP NP_0_0603_10UF-0603 | 10uF-0603 | IC | 5 | C6; C8; C20; C38; C39 | | 603 | CAP NP_0_0603_1UF-0603 | 1uF-0603 | IC | 10 | C14; C16; C17; C18; C37; C40; C41; C42; C43; C44 | | 603 | RESISTOR_0_0603_0-0603 | 0-0603 | IC | 4 | R1; R9; R10; R30 | | 603 | RESISTOR_0_0603_10K-0603 | 10k-0603 | IC | 1 | R2 | | 603 | RESISTOR_0_0603_10R-0603 | 10R-0603 | IC | 1 | R11 | | 603 | R_0603_NC(3.3K-0603) | NC(3.3K-0603) | IC | 2 | R12; R13 | | 603 | R_0603_NC(0-0603) | NC(0-0603) | IC | 4 | R23; R25; R27; R33 | | 603 | R_0603_0-0603 | 0-0603 | IC | 5 | R24; R26; R28; R31; R32 | | 603 | RESISTOR_0_0603_NC(5-0603) | NC(5-0603) | IC | 1 | R29 | | ARRAY_120X60_1X1_MM | ARRAY_3X1_ARRAY_120X60_1X1_MM_A | Array_3X1 | IC | 2 | A1; A2 | | CLCC_1000X1000_48N_MM | C2392_PLCC10X10_MIPI_FSI_CLCC_1 | C2392_PLCC10X10_MIPI_FSI | IC | 1 | U1 | | HOLE_320_MM | T POINT R_HOLE_320_MM_HOLE | HOLE | IC | 2 | H1; H2 | | JP_DIP254P_20NB_MM | DIP_HS300_MIPI_7_JP_DIP254P_20N | DIP_HS300_MIPI | IC | 1 | U2 | | JP_SIP254P_3N_MM | CON3_0_JP_SIP254P_3N_MM_HDR3 | HDR3 | IC | 2 | J1; J2 | | SOT95P_165X290_5N_MM | LP5907_0_SOT95P_165X290_5N_MM_L | LP5907MFX-3.0/NOPB | IC | 1 | U3 | | TP_SIP254P_1N_MM | TP_TP_SIP254P_1N_MM_HEADER 1 | HEADER 1 | IC | 8 | T1; T2; T3; T4; T5; T6; T7; T8 | 附件:6 V( m9 ~! p* J. R3 e7 a0 l0 R
PCB文件如下:
& z2 j1 g9 p( y3 X9 g) h: z
- M% Y: w6 m+ z! n# H) V5 t# ~( w
( j# s# Y, S; g- |4 N! J6 G |
