查看: 394|回复: 1
[AD 10][4层]隔离型4轨推挽式IGBT门驱动电源板(LM5030MM/NOPB+TPS27082LDDC+LP295...
发表于 2020-1-9 15:56 | 只看该作者 |只看大图 回帖奖励 |正序浏览 |阅读模式
作品名:[AD 10][4层]隔离型4轨推挽式IGBT门驱动电源板(LM5030MM/NOPB+TPS27082LDDC+LP2954AIM/NOPB)原理图和PCB源文件6 C  e2 P1 U& A) B- X; S7 i* j
. B& d' J$ K5 j9 ~0 a9 Q6 S/ v
文件描述
# Y- x# N' C, B6 {$ X  E) p$ w$ r
1. 作品用途:隔离型4轨推挽式IGBT门驱动电源板2 ?% b9 p( N9 A+ c3 V, G* x! F
* M/ E# T4 C; r  o2 ~
2. 软件版本:AD 10
0 s2 N6 e% _9 Z/ u3 k* B1 F4 u+ `0 b' ^  h$ B" ?; S. m
3. 层数:4层板
3 o$ a" C1 X: |# h% o/ h+ k8 @
8 P' a: T1 r' Y$ r4. 用到的主要芯片:LM5030MM/NOPB+TPS27082LDDC+LP2954AIM/NOPB
  C  _8 h5 ?) s# H
  Y0 [' |7 ~( `9 G  }) N/ W5 t4 h5. PCB尺寸:145mm*100mm% r! N$ B8 D* c" w8 ^0 O' Q; ~
3 i8 Z5 E% q/ i3 P. c  N, L; I% B; l) ^8 d  D( O& Q
作品截图如下:
) D% H' O# K4 [& I6 ~' E; ?$ J% }0 E0 m( a1 }, G6 j: U: m
顶层截图:' ?7 q$ ^' S# X9 V3 R
3 ^8 |4 O6 a) Y
; u& B; t& b6 |底层截图:9 u" w6 Q3 O( L
, i8 m: [6 B: y0 E- D# u, g3 w
  }9 k6 X: h/ s( q
全层截图:
  H  p# ]- V' W, F) Q5 ?' d( L 9 o3 y4 X- |7 U# U
( x: Z. r6 o% U3 L" d; @叠层信息截图如下:7 G5 F4 s5 y; d( o
: X" e' D9 ~8 E) Q% U. [' C
8 t  I2 H0 t! P) YBOM:# u4 b. Z8 p5 ]3 V0 Z
Comment(属性)Designator(位号)Footprint(封装)Quantity(数量)
EEE-FK1K470PC1SM_RADIAL_G
1uF/63VC2CAPSMT_62_D55
22uF/16VC31206
C2012C0G1E223JC40805
GRM216R71E102KA01DC5, C7, C80805_HV
CC0805KRX7R9BB471C60805_HV
22uF/35VC9, C59SM_RADIAL_D
10uF/50VC10, C11, C12, C22, C23, C24, C35, C36, C37, C47, C48, C49, C60, C61, C62, C72, C73, C741206_190
18
EEE-FK1V470PC13, C14, C17, C18, C25, C26, C29, C30, C38, C39, C42, C43, C50, C51, C54, C55, C63, C64, C67, C68, C75, C76, C79, C80SM_RADIAL_D
24
100pFC15, C27, C40, C52, C65, C770805
4.7uF/25VC16, C28, C41, C53, C66, C780805
B37947K9103J62C19, C200805_HV
10uF/16VC21, C33, C46, C58, C71, C830805
10nFC31, C32, C44, C45, C56, C57, C69, C70, C81, C820805
10
EEE-FC1V220PC34SM_RADIAL_D
08055C104JAT2AC84, C85, C86, C87, C88, C89, C90, C91, C92, C93, C94, C950805_HV
12
282841-2CONN1TEC_282841-2
CON-OSTVN02A150CONN2CN2_MTB_P100_PD80_D1.1_S5.54X6.5_STACK
CON-OSTVN04A150CONN3, CONN4, CONN5, CONN6, CONN7, CONN8TB_OSTVN04A150_4P
B260A-13-FD1SMA
DNPD2, D3D_SOD123
B190-13-FD4, D5, D6, D7, D8, D9, D10, D11, D12, D13, D14, D15, D16, D17, D18, D19, D20, D21SMA
18
FiducialFID1, FID2, FID3, FID4, FID5, FID6Fiducial10-20
NY PMS 440 0025 PHH1, H2, H3, H4NY PMS 440 0025 PH
1902CH5, H6, H7, H8Keystone_1902C
JUMPER_2X100MILJ1, J2, J3, J4, J5, J6HDR100_1X2
MSS1210-225KEL1IND_MSS1210
Size: 0.65" x 0.20 "LBL1Label_650x200
LED_LG L29K-G2J1-24-ZLD1, LD2, LD3, LD4, LD5, LD6, LD7, LD8, LD9, LD10, LD11, LD12, LD13, LD14, LD15, LD16, LD17, LD18, LD19, LD20, LD21, LD22, LD23, LD24LED0603AA
24
CSD88539NDQ1SO-8
CSD19533Q5AQ2, Q3TRANS_NexFET_Q5A
CRCW08050000Z0EAR1, R3, R7, R9, R10, R11, R13, R15, R18, R19, R21, R22, R31, R32, R41, R42, R51, R52, R61, R62, R71, R720805_HV
22
CRCW08051K00FKEAR20805_HV
RC0805FR-0726K7LR40805_HV
ERJ-6ENF1003VR5, R24, R34, R44, R54, R64, R740805_HV
CRCW080510K0FKEAR60805_HV
ERJ-6ENF2492VR80805_HV
CRCW080522R0JNEAR12, R140805_HV
CRCW08051K15FKEAR160805_HV
ERJ-8RQFR22VR171206
CRCW080510K0JNEAR20, R25, R26, R29, R30, R35, R36, R39, R40, R45, R46, R49, R50, R55, R56, R59, R60, R65, R66, R69, R70, R75, R76, R790805_HV
24
ERJ-6GEYJ125VR23, R33, R43, R53, R63, R730805_HV
RR1220P-334-DR27, R37, R47, R57, R67, R770805_HV
CRCW0805102KFKEAR28, R38, R48, R58, R68, R780805_HV
ERJ-8GEY0R00VR801206
750342312T1, T2, T3Wurth_750342312
LM5030MM/NOPBU1MUB10A_N
TPS27082LDDCU2DDC0006A_N
LP2954AIM/NOPBU3, U5, U7, U9, U11, U13M08A_N
TPS7A3001DGNU4, U6, U8, U10, U12, U14DGN_8P
MMSZ5242B-TPZ1SOD-123
0 p( S1 W( u* Z' x, W! ]7 C附件:  s) j2 Z/ k1 Z
8 A" ^) H: l) j3 b0 M% c2 D
原理图和PCB源文件如下:
/ n( W4 K& K! v+ c1 y: q
游客,如果您要查看本帖隐藏内容请回复
* [& `+ ~# I& P! z2 K8 g8 M- x$ J' ?7 U5 Y
: I9 h* T7 w* w' [  H
: s+ `6 Y# v- G7 P3 W! E
发表于 2022-9-24 18:37 | 只看该作者
驱动原理是什么呢
“来自电巢APP”
GMT+8, 2025-11-27 06:00 , Processed in 0.171875 second(s), 29 queries , Gzip On.
