| Bill of Material Report (Condensed) |
| SYM_NAME | COMP_DEVICE_TYPE | COMP_VALUE | COMP_CLASS | QUANTITY | REFDES |
| 名称 | 类型 | 属性 | 类别 | 数量 | 位号 |
| 402 | CAP_0402_4.7NF | 4.7nF | DISCRETE | 9 | C1; C13; C269; C364; C446; C495; C498; C501; C525 |
| 402 | CAP 3300PF 10% 50V 0402_0402_3. | 3.3nF | IC | 3 | C2; C27; C95 |
| 402 | CAP_0402_56PF | 56pF | DISCRETE | 1 | C3 |
| 402 | CAP 39PF 5% 50V 0402_0402_39PF | 39pF | DISCRETE | 3 | C4; C22; C99 |
| 402 | CAP_0402_0.1UF | 0.1uF | DISCRETE | 158 | C9; C15; C18; C19; C20; C35; C36; C37; C38; C44; C45; C47; C50; C53; C58; C59; C60; C61; C67; C70; C71; C72; C73; C79; C80; C82; C83; C84; C86; C89; C90; C91; C96; C109; C110; C123; C124; C125; C126; C127; C134; C135; C140; C146; C147; C154; C155; C156; C157; C158; C159; C160; C161; C169; C173; C174; C181; C182; C185; C205; C206; C207; C210; C211; C213; C218; C220; C229; C233; C245; C249; C250; C251; C253; C265; C270; C275; C284; C289; C297; C299; C303; C304; C309; C315; C321; C325; C327; C334; C348; C349; C351; C365; C368; C369; C379; C385; C390; C392; C401; C403; C405; C420; C447; C452; C456; C462; C463; C465; C467; C474; C475; C476; C477; C481; C486; C490; C491; C493; C496; C499; C502; C503; C504; C505; C510; C512; C513; C514; C515; C516; C517; C518; C519; C520; C521; C526; C529; C533; C534; C535; C536; C537; C544; C546; C547; C548; C549; C550; C551; C552; C553; C554; C555; C556; C557; C558; C559 |
| 402 | CAP 2.2UF +/-20% 6.3V 0402_0402 | 2.2uF | DISCRETE | 3 | C10; C16; C107 |
| 402 | CAP_0402_10PF | 10pF | DISCRETE | 2 | C23; C46 |
| 402 | CAP 100PF 5% 50VDC 0402_0402_22 | 220pF | DISCRETE | 1 | C28 |
| 402 | CAP_0402_1UF | 1uF | DISCRETE | 18 | C29; C43; C51; C74; C78; C119; C179; C180; C194; C203; C278; C311; C314; C355; C370; C378; C399; C545 |
| 402 | CAP_0402_4.7UF | 4.7uF | DISCRETE | 23 | C62; C63; C170; C178; C200; C202; C224; C225; C227; C237; C257; C261; C307; C331; C376; C396; C398; C400; C404; C407; C409; C411; C412 |
| 402 | CAP_0402_1.0NF | 1.0nF | DISCRETE | 5 | C94; C120; C139; C295; C479 |
| 402 | CAP_0402_DNI | DNI | DISCRETE | 3 | C97; C132; C460 |
| 402 | CAP_0402_68PF | 68pF | DISCRETE | 1 | C98 |
| 402 | CAP 1000PF 10% 50V 0402_0402_10 | 1000pF | DISCRETE | 1 | C100 |
| 402 | CAP_0402_47PF | 47pF | DISCRETE | 1 | C101 |
| 402 | CAP 0.1UF 25VDC 0402_0402_0.1UF | 0.1uF | DISCRETE | 15 | C104; C105; C113; C121; C122; C142; C143; C421; C422; C433; C434; C439; C440; C461; C480 |
| 402 | CAP_0402_0.01UF | 0.01uF | DISCRETE | 57 | C106; C164; C165; C171; C176; C183; C189; C219; C230; C238; C239; C240; C241; C252; C258; C262; C263; C268; C274; C276; C291; C293; C294; C298; C316; C317; C318; C320; C328; C330; C332; C333; C336; C338; C339; C340; C341; C342; C343; C344; C345; C357; C363; C367; C391; C413; C426; C445; C450; C454; C455; C466; C483; C485; C509; C511; C524 |
| 402 | CAP_0402_9.0PF | 9.0pF | IC | 1 | C133 |
| 402 | CAP_0402_12PF | 12pF | DISCRETE | 2 | C149; C150 |
| 402 | CAP_0402_22NF | 22nF | DISCRETE | 23 | C162; C163; C175; C190; C191; C192; C201; C242; C243; C259; C288; C292; C302; C353; C354; C356; C371; C380; C386; C395; C397; C402; C410 |
| 402 | CAP_0402_47NF | 47nF | DISCRETE | 27 | C166; C167; C168; C188; C196; C197; C198; C199; C256; C277; C279; C281; C283; C286; C287; C290; C306; C308; C310; C312; C313; C322; C323; C352; C377; C406; C408 |
| 402 | CAP_0402_0.47UF | 0.47uF | DISCRETE | 21 | C177; C221; C228; C231; C260; C271; C300; C324; C326; C350; C362; C393; C448; C451; C453; C457; C458; C468; C523; C530; C532 |
| 402 | CAP_0402_0.22UF | 0.22uF | DISCRETE | 10 | C193; C195; C209; C236; C254; C255; C280; C282; C305; C329 |
| 402 | CAP_0402_1000PF | 1000pF | DISCRETE | 2 | C208; C264 |
| 402 | CAP_0402_270PF | 270pF | DISCRETE | 2 | C214; C438 |
| 402 | CAP_0402_33PF | 33pF | DISCRETE | 1 | C215 |
| 402 | CAP_0402_2.2NF | 2.2nF | DISCRETE | 29 | C217; C222; C234; C266; C272; C296; C301; C361; C366; C389; C394; C436; C437; C443; C449; C464; C469; C470; C471; C472; C473; C482; C487; C494; C500; C522; C527; C528; C531 |
| 402 | CAP_0402_27PF | 27pF | DISCRETE | 1 | C246 |
| 402 | CAP_0402_100PF | 100pF | DISCRETE | 1 | C247 |
| 402 | CAP_0402_3.3NF | 3.3nF | DISCRETE | 4 | C267; C444; C484; C497 |
| 402 | CAP_0402_2.2UF | 2.2uF | DISCRETE | 1 | C285 |
| 402 | CAP 0.22UF 10% 10V 0402_0402_0. | 0.22uF | DISCRETE | 1 | C424 |
| 402 | CAP_0402_470PF | 470pF | DISCRETE | 1 | C441 |
| 402 | CAP_0402_15PF | 15pF | DISCRETE | 1 | C442 |
| 402 | INDUCTOR_0402_3.9NH | 3.9nH | DISCRETE | 1 | L9 |
| 402 | INDUCTOR_0402_5.6NH | 5.6nH | DISCRETE | 2 | L11; L12 |
| 402 | RESISTOR_0402_14.7K | 14.7K | DISCRETE | 1 | R1 |
| 402 | RES 0 OHM 5% 1/16W 0402 SMD_040 | 0 | DISCRETE | 28 | R2; R34; R41; R42; R47; R48; R88; R95; R110; R115; R116; R124; R125; R141; R142; R149; R150; R161; R162; R167; R168; R169; R170; R171; R213; R249; R303; R345 |
| 402 | RES 10.0K OHM 1.0% 1/16W 0402_1 | DNI | DISCRETE | 3 | R3; R33; R96 |
| 402 | RESISTOR_0402_16.9K | 16.9K | DISCRETE | 1 | R4 |
| 402 | RESISTOR_0402_28.7K | 28.7K | DISCRETE | 1 | R5 |
| 402 | RES 100K OHM 1.0% 1/16W 0402_04 | 100K | DISCRETE | 6 | R6; R30; R90; R294; R300; R304 |
| 402 | RES 0 OHM 5% 1/16W 0402 SMD_0_1 | DNI | IC | 13 | R7; R29; R45; R46; R50; R51; R83; R84; R92; R248; R279; R283; R298 |
| 402 | RESISTOR_0402_15.0K | 15.0K | DISCRETE | 1 | R8 |
| 402 | RES 10.0K OHM 1.0% 1/16W 0402_0 | 10.0K | DISCRETE | 6 | R9; R27; R91; R93; R94; R299 |
| 402 | RESISTOR_0402_267K | 267K | DISCRETE | 1 | R10 |
| 402 | RESISTOR_0402_54.9K | 54.9K | DISCRETE | 1 | R11 |
| 402 | RESISTOR_0402_100, 1% | 100, 1% | DISCRETE | 13 | R12; R22; R23; R148; R181; R184; R195; R216; R223; R245; R251; R266; R272 |
| 402 | RESISTOR_0402_4.7K | 4.7K | DISCRETE | 8 | R13; R38; R39; R40; R43; R49; R166; R180 |
| 402 | RESISTOR_0402_20.0K | 20.0K | DISCRETE | 3 | R14; R17; R176 |
| 402 | RES 10 OHM 1.0% 1/16W 0402_0402 | 10 | DISCRETE | 6 | R15; R16; R103; R253; R310; R311 |
| 402 | RESISTOR_0402_1M | 1M | DISCRETE | 1 | R18 |
| 402 | RESISTOR_0402_124 | 124 | DISCRETE | 2 | R19; R24 |
| 402 | RESISTOR_0402_84.5 | 84.5 | DISCRETE | 2 | R20; R25 |
| 402 | RESISTOR_0402_100K | 100K | DISCRETE | 5 | R21; R31; R191; R194; R202 |
| 402 | RESISTOR_0402_169.0K | 169.0K | DISCRETE | 2 | R26; R224 |
| 402 | RESISTOR_0402_31.6K | 31.6K | DISCRETE | 1 | R28 |
| 402 | RES 16.5K OHM 1/10W 1% 0402_0_1 | 14.0K | DISCRETE | 1 | R32 |
| 402 | RESISTOR_0402_DNI | DNI | DISCRETE | 38 | R35; R55; R58; R97; R98; R106; R107; R111; R172; R173; R186; R188; R190; R192; R199; R200; R201; R217; R218; R234; R235; R258; R271; R285; R302; R308; R312; R313; R314; R315; R316; R320; R321; R329; R334; R336; R340; R353 |
| 402 | RESISTOR_0402_187 | 187 | DISCRETE | 2 | R36; R64 |
| 402 | RESISTOR_0402_750 | 750 | IC | 1 | R37 |
| 402 | RESISTOR_0402_4.99K | 4.99K | DISCRETE | 3 | R44; R158; R159 |
| 402 | RESISTOR_0402_10.0K | 10.0K | DISCRETE | 34 | R52; R71; R86; R126; R127; R128; R133; R134; R135; R136; R137; R138; R139; R140; R143; R144; R145; R177; R197; R225; R226; R237; R242; R243; R250; R282; R341; R342; R343; R346; R347; R348; R350; R356 |
| 402 | RESISTOR_0402_0 | 0 | DISCRETE | 19 | R54; R60; R61; R62; R63; R67; R75; R81; R82; R85; R179; R210; R241; R263; R273; R322; R328; R335; R337 |
| 402 | RESISTOR_0402_10K | 10K | DISCRETE | 22 | R56; R57; R59; R65; R66; R122; R254; R255; R256; R257; R269; R301; R324; R331; R332; R344; R349; R351; R352; R354; R355; R359 |
| 402 | RESISTOR_0402_1.00K | 1.00k | DISCRETE | 22 | R68; R72; R73; R74; R76; R77; R80; R117; R118; R119; R120; R121; R178; R185; R187; R189; R281; R293; R309; R319; R333; R338 |
| 402 | RESISTOR_0402_1.50K | 1.50K | DISCRETE | 1 | R69 |
| 402 | RESISTOR_0402_0402_115K (1%) | 115K (1%) | DISCRETE | 1 | R87 |
| 402 | RES 10.0K OHM 1.0% 1/16W 0402_2 | 10K | IC | 1 | R89 |
| 402 | RESISTOR_0402_0402_21K (1%) | 21K (1%) | DISCRETE | 2 | R99; R305 |
| 402 | RESISTOR_0402_316.0K | 316.0K | DISCRETE | 1 | R100 |
| 402 | RES 16.5K OHM 1/10W 1% 0402_040 | 16.5K | DISCRETE | 1 | R101 |
| 402 | RES 13.7K OHM, 1/16W, 1%, 0402_ | 13.7K | DISCRETE | 1 | R102 |
| 402 | RESISTOR_0402_56.2 | 56.2 | DISCRETE | 27 | R104; R105; R108; R112; R113; R114; R129; R130; R131; R132; R146; R147; R151; R152; R153; R154; R155; R156; R163; R164; R165; R259; R260; R261; R262; R357; R358 |
| 402 | RESISTOR_0402_100 | 100 | IC | 1 | R109 |
| 402 | RESISTOR_0402_4.70K, 1% | 4.70K, 1% | DISCRETE | 6 | R157; R175; R182; R183; R265; R330 |
| 402 | RESISTOR_0402_180K | 180K | DISCRETE | 1 | R160 |
| 402 | RESISTOR_0402_4.02K | 4.02K | DISCRETE | 1 | R193 |
| 402 | RESISTOR_0402_27.4K | 27.4K | IC | 1 | R196 |
| 402 | RESISTOR_0402_2.00K | 2.00K | DISCRETE | 3 | R198; R205; R209 |
| 402 | RESISTOR_0402_22.1K | 22.1K | DISCRETE | 1 | R203 |
| 402 | RESISTOR_0402_240 | 240 | DISCRETE | 10 | R204; R244; R276; R286; R287; R288; R306; R325; R326; R327 |
| 402 | RESISTOR_0402_220 | 220 | DISCRETE | 5 | R206; R207; R208; R211; R212 |
| 402 | RESISTOR_0402_215.0K | 215.0K | DISCRETE | 1 | R214 |
| 402 | RESISTOR_0402_11.3K | 11.3K | DISCRETE | 1 | R215 |
| 402 | RESISTOR_0402_499K | 499K | IC | 1 | R219 |
| 402 | RESISTOR_0402_2.55K | 2.55K | DISCRETE | 1 | R220 |
| 402 | RESISTOR_0402_11.5K | 11.5K | DISCRETE | 1 | R221 |
| 402 | RESISTOR_0402_200 | 200 | DISCRETE | 4 | R222; R317; R318; R323 |
| 402 | RESISTOR_0402_5.76K | 5.76K | DISCRETE | 1 | R227 |
| 402 | RESISTOR_0402_45.3K | 45.3K | DISCRETE | 1 | R228 |
| 402 | RESISTOR_0402_49.9 | 49.9 | DISCRETE | 10 | R229; R230; R231; R238; R239; R240; R246; R247; R277; R289 |
| 402 | RESISTOR_0402_590K | 590K | DISCRETE | 1 | R232 |
| 402 | RESISTOR_0402_4.70M | 4.70M | DISCRETE | 1 | R233 |
| 402 | RESISTOR_0402_2.37K | 2.37K | DISCRETE | 1 | R236 |
| 402 | RESISTOR_0402_37.4 | 37.4 | DISCRETE | 1 | R267 |
| 402 | RESISTOR_0402_75 | 75 | DISCRETE | 8 | R268; R270; R274; R278; R280; R284; R291; R292 |
| 402 | RESISTOR_0402_51 | 51 | DISCRETE | 2 | R275; R339 |
| 402 | RES 9.53K OHMS 1% 1/16W 0402_04 | 9.53K | DISCRETE | 1 | R295 |
| 402 | RES 30.1K OHM 1% 1/16W 0402 SMD | 30.1K | DISCRETE | 1 | R296 |
| 402 | RES 75K OHM 1% 1/16W 0402 SMD_0 | 75K | DISCRETE | 1 | R297 |
| 603 | CAP_0603_2.2UF | 2.2uF | DISCRETE | 7 | C8; C34; C49; C85; C103; C184; C478 |
| 603 | CAP 1.0UF 10% 6.3V 0603_0603_1U | 1uF | IC | 3 | C11; C12; C108 |
| 603 | CAP_0603_10UF | 10uF | DISCRETE | 16 | C31; C55; C56; C57; C118; C335; C360; C388; C425; C435; C538; C539; C540; C541; C542; C543 |
| 603 | CAP_0603_22UF | 22uF | IC | 1 | C33 |
| 603 | CAP 0.1UF 50V 0603_0603_0.1UF | 0.1uF | IC | 3 | C141; C144; C488 |
| 603 | CAP_0603_1UF | 1uF | DISCRETE | 3 | C346; C372; C373 |
| 603 | CAP_0603_0.1UF | 0.1uF | DISCRETE | 2 | C358; C383 |
| 603 | BEAD_FERRITE_SM_0603_120 OHM FB | 120 Ohm FB | IC | 1 | L10 |
| 603 | RESISTOR_0603_750 | 750 | DISCRETE | 1 | R290 |
| 805 | CAP 22UF +/-10% 6.3V 0805_0805_ | 22uF | DISCRETE | 12 | C6; C7; C25; C26; C111; C112; C136; C137; C152; C153; C506; C507 |
| 805 | CAP_0805_10UF | 10uF | DISCRETE | 8 | C42; C66; C77; C145; C148; C204; C319; C492 |
| 805 | CAP_0805_4.7UF | 4.7uF | DISCRETE | 5 | C416; C417; C418; C431; C432 |
| 805 | CAPACITOR NON-POL_0805_DNI | DNI | DISCRETE | 1 | C419 |
| 805 | CAP 4.7UF +/-10% 16V 0805_0805_ | 4.7uF | DISCRETE | 1 | C423 |
| 1206 | CAP_1206_10UF | 10uF | DISCRETE | 5 | C52; C128; C129; C130; C131 |
| 1206 | CAP 47UF +/-20% 6.3V 1206_1206_ | 47UF | DISCRETE | 4 | C68; C81; C359; C374 |
| 1206 | CAP 100UF +/-20% 6.3V 1206_1206 | 100UF | DISCRETE | 2 | C87; C88 |
| 1206 | CAP_1206_100UF | 100uF | DISCRETE | 1 | C248 |
| 1206 | RES 0.001 OHM 1% 1W 2010_1206_0 | 0.001 | IC | 1 | R70 |
| 1210 | CAP 22UF +/-10% 25V 1210_1210_2 | 22uF | DISCRETE | 12 | C5; C21; C76; C114; C115; C116; C117; C138; C151; C375; C489; C508 |
| 1210 | CAP_1210_22UF | 22uF | DISCRETE | 9 | C172; C186; C187; C212; C216; C232; C244; C387; C414 |
| 7343-V_LOW-PROFILE | PCAP_7343-V_LOW-PROFILE_330UF | 330uF | DISCRETE | 4 | C17; C30; C92; C226 |
| 7343-X | PCAP_7343-X_47UF | 47uF | DISCRETE | 2 | C41; C65 |
| 7343P | PCAP_7343P_330UF | 330uF | DISCRETE | 4 | C24; C40; C48; C102 |
| 7343P | PCAP_7343P_68UF | 68uF | DISCRETE | 1 | C32 |
| 7343P | PCAP_7343P_220UF | 220uF | DISCRETE | 5 | C39; C54; C64; C75; C93 |
| 7343P | CAP-TANT 330UF 7343 20% 6.3V _7 | 330uF | DISCRETE | 1 | C69 |
| AVX-1210_CASE-B | PCAP_AVX-1210_CASE-B_100UF | 100uF | DISCRETE | 11 | C14; C223; C235; C273; C337; C347; C384; C427; C428; C429; C430 |
| BCC96 | 88E1111_BCC96_88E1111 | 88E1111 | IC | 1 | U11 |
| CAP_PACK_4_1206 | CAP_ARRAY_CAP_PACK_4_1206_0.1UF | 0.1uF | IC | 6 | CN1; CN2; CN3; CN4; CN5; CN6 |
| DFN6-2X2_EPAD | LTC3025-1_0_DFN6-2X2_EPAD_LTC30 | LTC3025-1 | IC | 1 | U39 |
| DFN6-2X2_EPAD | LT3009XDC_0_DFN6-2X2_EPAD_LT300 | LT3009xDC | IC | 1 | U42 |
| DFN6-3X2_EPAD | LTC3085EDCB_DFN6-3X2_EPAD_LT308 | LT3085EDCB | IC | 1 | U10 |
| DFN6_EPAD | LTC4357_DFN6_EPAD_LTC4357 | LTC4357 | IC | 3 | U41; U44; U46 |
| DFN12_EPAD | LTC4352CDD_DFN12_EPAD_LTC4352CD | LTC4352CDD | DISCRETE | 2 | D31; D33 |
| DFN16_EPAD_5X3 | LT3022EDHC_DFN16_EPAD_5X3_LT302 | LT3022EDHC | IC | 2 | U7; U18 |
| DIPSWITCH_SMT_OCTAL | 76SB08_DIPSWITCH_SMT_OCTAL_TDA0 | TDA08H0SB1 | IO | 1 | SW1 |
| DIPSWITCH_SMT_QUAD | SPST4_DIPSWITCH_SMT_QUAD_TDA04H | TDA04H0SB1 | IO | 3 | SW3; SW4; SW5 |
| DQFN14 | FXL5T244_DQFN14_DNI | DNI | IC | 2 | U31; U34 |
| DRC-10_EPAD | TPS51200_DRC-10_EPAD_TPS51200 | TPS51200 | IC | 2 | U43; U53 |
| DRT | TPD2EUSB30_DRT_TPD2EUSB30 | TPD2EUSB30 | IC | 1 | U5 |
| ECS3525 | OSC_ALT_0_ECS3525_50MHZ | 50MHz | DISCRETE | 1 | X6 |
| EG2207 | SW_SLIDE_DPDT_EG2207_SW_SLIDE_D | SW_SLIDE_DPDT | IO | 1 | SW2 |
| F64_10X8 | PC28FXXXP30B85_1_F64_10X8_PC28F | PC28F00AP30BF | IC | 1 | U20 |
| F256 | 5M2210ZF256_F256_5M2210ZF256 | 5M2210ZF256 | IC | 1 | U32 |
| F1152 | 5CGTFD9E5F35_F1152_5CGTFD9E5F35 | 5CGTFD9E5F35 | IC | 1 | U13 |
| FDMC8878_VER2 | FDMC8878_VER2_FDMC8878_VER2_FDM | FDMC8878 | IC | 5 | U9; U14; U16; U17; U19 |
| HDR2X5_100MIL_SMT | 2X5_HDR2X5_100MIL_SMT_DNI | DNI | IO | 1 | J18 |
| IND_0603 | BEAD_FERRITE_SM_IND_0603_3A, 30 | 3A, 30 Ohm FB | IC | 2 | L5; L13 |
| IND_SUSUMU_PCMC_BTYPE | IND 1.2UH IR=6.5A CUBE SMD_IND_ | 1.2uH | DISCRETE | 3 | L1; L2; L8 |
| IND_WURTH_744314047 | IND 0.47UH IR=18A ISAT=20A SMD_ | 0.47uH | DISCRETE | 2 | L6; L7 |
| IND_WURTH_744325120 | INDUCTOR_IND_WURTH_744325120_1. | 1.2uH | DISCRETE | 2 | L3; L4 |
| KEYSTONE_BT-2994 | BATTERY_0_KEYSTONE_BT-2994_BATT | Battery | IC | 1 | BT1 |
| LFPAK-4 | RJK0301DPB_LFPAK-4_RJK0305DPB | RJK0305DPB | DISCRETE | 2 | Q1; Q4 |
| LFPAK-4 | RJK0301DPB_LFPAK-4_RJK0301DPB | RJK0301DPB | DISCRETE | 2 | Q2; Q3 |
| LLP16_EPAD | LMH0384_LLP16_EPAD_LMH0384 | LMH0384 | IC | 1 | U47 |
| LLP16_EPAD | LMH0303_LLP16_EPAD_LMH0303 | LMH0303 | IC | 1 | U50 |
| LUMEX_LED0805 | LED_LUMEX_LED0805_GREEN_LED | Green_LED | DISCRETE | 29 | D1; D2; D3; D4; D6; D7; D8; D9; D10; D11; D12; D13; D14; D15; D16; D17; D18; D19; D20; D22; D23; D24; D25; D26; D27; D28; D29; D30; D32 |
| LUMEX_LED0805 | LED_LUMEX_LED0805_RED_LED | Red_LED | DISCRETE | 1 | D5 |
| LUMEX_LED0805 | LED_LUMEX_LED0805_BLUE LED | BLUE LED | DISCRETE | 1 | D21 |
| LUMEX_LED0805 | LED_LUMEX_LED0805_YELLOW LED | YELLOW LED | DISCRETE | 4 | D34; D35; D44; D45 |
| M100 | EPM570M100_0_M100_S1,S2,S3_DNI | DNI | IC | 1 | U23 |
| MICRON_DDR3_96_9X14 | MT41J128M16HA_MICRON_DDR3_96_9X | MT41K128M16JT | IC | 7 | U8; U15; U22; U26; U27; U28; U30 |
| MLX_22_23_2021_VRT_HDR_2P | CON2_MLX_22_23_2021_MLX_22_23_2 | 22_23_2021 | IO | 1 | J15 |
| MLX_SHROUD_VRT_HDR_10PIN | 70247-1051_MLX_SHROUD_VRT_HDR_1 | 70246-1004 | IO | 1 | J13 |
| MOLEX_MINI-AB_USB_TH | USB_CON_TH_MOLEX_MINI-AB_USB_TH | USB MINI-AB | IO | 1 | J5 |
| MSOP10 | TS5A23157_MSOP10_TS5A23157 | TS5A23157 | IC | 2 | U36; U37 |
| NEWHAVEN_LCD | LCD_HEADER_NEWHAVEN_LCD_LCD_HEA | LCD_HEADER | IO | 1 | J10 |
| PCIX-4PORT | PCIE_BRACKET_X4_PCIX-4PORT_PCIE | PCIE_Slot | IO | 1 | J16 |
| QFN24 | REG SWITCHING, LTC3605EUF_QFN24 | LTC3605EUF | IC | 3 | U1; U2; U25 |
| QFN40 | LTC3855_QFN40_LTC3855EUJ | LTC3855EUJ | IC | 1 | U40 |
| QFN52_3EPAD | REG SWITCHING, LTC3608_QFN52_3E | LTC3608 | IC | 1 | U21 |
| QFN56_7X9MM | LTC3613EWKH_7_QFN56_7X9MM_LTC36 | LTC3613EWKH_6 | IC | 1 | U24 |
| QSOP24P | IDTQS3861_QSOP24P_IDTQS3861 | IDTQS3861 | IC | 1 | U29 |
| RAPC712 | CONN JACK PWR_3_RAPC712_CONN JA | CONN JACK PWR | IO | 1 | J8 |
| RES_PACK_8 | RES_PACK_0_RES_PACK_8_S1+S2+S3+ | 51 | DISCRETE | 7 | RN1; RN2; RN3; RN4; RN5; RN6; RN7 |
| RJ45 | HFJ11-1G02E_RJ45_HFJ11-1G02E | HFJ11-1G02E | IO | 1 | J9 |
| SAMTEC_HDR_2X3_2MM_SMT | CON6A_SAMTEC_HDR_2X3_2MM_SMT_DN | DNI | IC | 1 | J17 |
| SAMTEC_QSHDP120CUSTOM | QSH_HSM_SAMTEC_QSHDP120CUSTOM_A | ASP-122953-01 | IO | 2 | J1; J2 |
| SENSE | SENSE_PAD_SENSE_SENSE_PAD | SENSE_PAD | IC | 18 | V1; V2; V3; V4; V5; V6; V18; V19; V35; V36; V37; V38; V39; V40; V41; V42; V43; V44 |
| SMA_LTI-SASF546-P26-X1 | SMA_LTI_SASF54GT_0_SMA_LTI-SASF | LTI-SASF546-P26-X1 | IO | 2 | J3; J6 |
| SMA_LTI-SASF546-P26-X1 | SMA_SMA_LTI-SASF546-P26-X1_LTI- | LTI-SASF546-P26-X1 | IO | 3 | J4; J7; J14 |
| SMB_RA_JACK_RECEP | CONN, MINI SMB, THM, RA_SMB_RA_ | Mini SMB | IO | 2 | J11; J12 |
| SO16_WIDE | EPCQ256_SO16_WIDE_EPCQ256SI16N | EPCQ256SI16N | IC | 1 | U33 |
| SOD323 | DIODE, SCHOTTKY CMDSH-3_SOD323_ | CMDSH-3 | DISCRETE | 5 | D36; D37; D41; D42; D43 |
| SOD323 | D-SCHOTTKY_0_SOD323_CMDSH-3 | CMDSH-3 | DISCRETE | 2 | D38; D40 |
| SOT23 | MMBD1205_SOT23_MMBD1205 | MMBD1205 | DISCRETE | 1 | D39 |
| SOT23 | PWRMOSFET_EN_GSD_0_SOT23_FDV305 | FDV305N | DISCRETE | 1 | Q5 |
| SOT23-8 | MAX3372EEKA_0_SOT23-8_MAX3373 | MAX3373 | IC | 2 | U12; U38 |
| SOT-143 | MAX811_SOT-143_MAX811 | MAX811 | IC | 1 | U6 |
| SOT-143 | RESET, MAX811_SOT-143_DNI | DNI | IC | 1 | U51 |
| SSOP28_NAR | LTC2418_SSOP28_NAR_LTC2418 | LTC2418 | IC | 1 | U45 |
| STAR_VIA | VIA_1_STAR_VIA_VIA_1 | VIA_1 | IC | 26 | V7; V8; V9; V10; V11; V12; V13; V14; V15; V16; V17; V20; V21; V22; V23; V24; V25; V26; V27; V28; V29; V30; V31; V32; V33; V34 |
| TDFN-10 | SL18860DC_TDFN-10_SL18860DC | SL18860DC | IC | 1 | U52 |
| TQFP100SQ | EPM570T100 | EPM570GT100C3N | IC | 1 | U49 |
| TSSOP14 | MAX3023_TSSOP14_MAX3023 | MAX3023 | IC | 1 | U35 |
| TSSOP14 | MAX3378_0_TSSOP14_MAX3378 | MAX3378 | IC | 1 | U48 |
| VFBGA56 | CY7C68013A_VFBGA_VFBGA56_CY7C68 | CY7C68013A_VFBGA | IC | 1 | U4 |
| VFQFPN-28_EPAD | IDT5T9306_0_VFQFPN-28_EPAD_IDT5 | IDT5T9306 | IC | 1 | U3 |
| WSL2010 | RES 0.003 OHM 1% 1/2W 2010_WSL2 | 0.003 | IC | 5 | R53; R79; R123; R174; R307 |
| WSL2010 | RESISTOR_WSL2010_0.001 | 0.001 | IC | 1 | R78 |
| WSL2010 | RESISTOR_WSL2010_0.003 | 0.003 | DISCRETE | 2 | R252; R264 |
| WURTH_6X3P5_TACT_SWITCH | TS-A02SA-2-S100_0_WURTH_6X3P5_T | PB Switch | IO | 7 | S1; S2; S3; S4; S5; S6; S7 |
| X2Y_0603 | CAP_X2Y_X2Y_0603_0.1UF | 0.1uF | IC | 2 | C382; C459 |
| X2Y_1206 | CAP_X2Y_X2Y_1206_220NF | 220nF | IC | 2 | C381; C415 |
| XTAL_EG2100 | 635L3C3_XTAL_EG2100_125.0MHZ | 125.0MHz | DISCRETE | 1 | X5 |
| XTAL_FA-128 | CRYSTAL_SM_13_XTAL_FA-128_24.00 | 24.00MHz | DISCRETE | 1 | Y1 |
| XTAL_SG310 | OSC_ALT_XTAL_SG310_25.00MHZ | 25.00MHz | DISCRETE | 1 | X1 |
| XTAL_SI570 | SI571_XTAL_SI570_SI571 | SI571 | DISCRETE | 1 | X3 |
| XTAL_SI570 | SI570_ALT1_XTAL_SI570_SI570 | SI570 | DISCRETE | 1 | X4 |
| XTAL_XG-1000CB | OSC_ALT_1_XTAL_XG-1000CB_100MHZ | 100MHz | DISCRETE | 1 | X2 |
附件:
