查看: 1962|回复: 24
[allegro16.6][16层]IP CAMERA(2个XC7X045FFG900+ADV7511WBSWZ+12片DDR+HR911130...
发表于 2020-1-2 17:38 | 只看该作者 |只看大图 回帖奖励 |正序浏览 |阅读模式
# Q0 J0 J; [4 x9 K  {* E
& X3 F& p# F9 j$ {9 y6 I! h& v- R4 _
[allegro16.6][16层]IP CAMERA(2个XC7X045FFG900+ADV7511WBSWZ+12片DDR+HR911130CE)原理图和pcb文件
7 z5 g* _" z1 [# r' }3 a6 P' ~1 t) F& w+ g9 G* {  e' a
: j" C( m6 M! e9 Z* v. ^( D/ S文件描述:1 y1 ]2 A* a1 B  K+ T* f
( ], u. x. ]  a% M
7 R( J5 n$ A4 N3 W- G. q. O; N9 [1 j1. 作品用途:IP CAMERA& t3 V4 H1 _% {/ d3 \% k
2. 软件版本:allegro16.6
) L& F* \7 B- z3 s+ H" g, D3. 层数:16层
! t: ^: B! _! Z- Q6 M4. 用到的主要芯片:2个XC7X045FFG900+ADV7511WBSWZ+12片DDR+HR911130CE+ H+ q% R  l* \, ~3 P
5. pcb尺寸:175*90 MM8 k& Z) G! ^4 {" r
7 O3 W9 t+ g$ Q2 p$ `
  w5 h5 i; F/ Y0 E# D! ^作品截图如下:* M# q( z- J! L( W7 _7 L
* w6 b* ?  s" F
2 A- k; x# b  Z+ Z顶层截图:
% [) q& N; r4 a  r
% j/ P) B& w7 d6 V: Q6 K7 X底层截图:# E9 j; t* T8 b' F$ x8 V8 \# b
: N! ?- G! H: ~0 x  }+ Q, n
2 ^6 {" g' G: _" w+ M0 B& G全层截图:1 a$ e0 r5 e' f9 h# i
6 Y3 `9 w; X1 |& f/ C
8 h7 x9 t; v( [, W
) M6 L( q& J- x* r% p7 a1 u4 \& D1 ^BOM:
0 {* |; E8 w  S: ]
SYM_NAMECOMP_DEVICE_TYPECOMP_VALUECOMP_CLASSQUANTITYREFDES
名称类型属性类别数量位号
467650301_SD46765-0301_467650301_SD_46765-046765-0301IC1U40
525593652_SD525593652_525593652_SD_52559365525593652IC1J8
541323633_SD525593652_541323633_SD_54132363541323633IC2J23; J24
541323633_SD_TOP525593652_541323633_SD_TOP_5413541323633IC1J22
B0603_H80BEAD1_B0603_H80_BLM18PG121SN1BLM18PG121SN1IC33B1; B2; B5; B6; B7; B8; B10; B11; B12; B13; B14; B15; B18; B19; B20; B23; B24; B25; B26; B27; B28; B29; B30; B31; B36; B37; B38; B39; B41; B42; B43; B44; B45
B0603_H80BEAD1_B0603_H80_NCNCIC2B9; B40
B1206_H110BEAD1_B1206_H110_BLM31PG330SN1BLM31PG330SN1IC2B21; B22
BGA77_P127_H500LTM4644IY#PBF_0_BGA77_P127_H500LTM4644IY#PBFIC3U33; U34; U35
BGA117_P100_H15088E1111-XX-BAB1I000_BGA117_P10088E1111-B2-BAB1I000IC2U14; U44
C0402_H40CAPACITOR NP_C0402_H40_0.01UF/10.01uF/16VDISCRETE130C50; C53; C54; C55; C56; C60; C61; C62; C63; C64; C68; C69; C70; C71; C72; C76; C77; C78; C79; C80; C84; C85; C86; C87; C88; C231; C234; C235; C236; C237; C241; C242; C243; C244; C245; C249; C250; C251; C252; C253; C257; C258; C259; C260; C261; C265; C266; C267; C268; C269; C343; C344; C361; C362; C363; C364; C365; C366; C367; C371; C372; C373; C374; C375; C376; C377; C383; C384; C390; C391; C392; C393; C394; C395; C396; C400; C401; C402; C403; C404; C405; C406; C594; C606; C608; C609; C610; C611; C612; C613; C614; C618; C619; C620; C621; C622; C623; C624; C628; C629; C630; C631; C632; C633; C634; C635; C639; C640; C641; C642; C643; C644; C645; C651; C1503; C1504; C1505; C1506; C1507; C1508; C1509; C1510; C1511; C1512; C1513; C1514; C1515; C1516; C1517; C1518
C0402_H40CAPACITOR NP_C0402_H40_0.1UF/250.1uF/25VIC13C129; C130; C131; C153; C310; C311; C312; C411; C424; C440; C539; C550; C551
C0402_H60CAPACITOR NP_C0402_H60_0.47UF/10.47uf/16VIC184C13; C14; C15; C16; C20; C21; C22; C23; C24; C28; C29; C30; C32; C35; C42; C58; C59; C66; C67; C74; C75; C82; C83; C114; C115; C116; C117; C118; C119; C120; C124; C126; C128; C136; C137; C139; C140; C141; C142; C144; C146; C194; C195; C196; C197; C201; C202; C203; C204; C205; C209; C210; C211; C213; C217; C224; C239; C240; C247; C248; C255; C256; C263; C264; C295; C296; C297; C298; C299; C300; C301; C305; C307; C309; C316; C317; C320; C321; C323; C324; C326; C327; C335; C336; C338; C339; C341; C342; C359; C360; C369; C370; C388; C389; C398; C399; C552; C553; C554; C555; C556; C557; C558; C559; C560; C561; C562; C563; C564; C565; C566; C567; C568; C569; C570; C571; C572; C573; C574; C575; C576; C577; C578; C579; C580; C581; C582; C583; C584; C585; C586; C587; C588; C589; C590; C591; C603; C604; C616; C617; C626; C627; C637; C638; C671; C672; C673; C674; C675; C676; C849; C850; C851; C852; C853; C854; C856; C857; C858; C860; C862; C863; C864; C865; C866; C867; C869; C870; C871; C873; C1524; C1525; C1526; C1527; C1535; C1536; C1537; C1538; C1539; C1540; C1541; C1542; C1543; C1544
C0402_H60CAPACITOR NP_C0402_H60_0.1UF/160.1uF/16VIC200C36; C37; C38; C39; C40; C49; C52; C89; C97; C105; C106; C107; C108; C109; C110; C111; C112; C113; C121; C127; C147; C148; C149; C150; C151; C152; C156; C157; C158; C159; C160; C161; C162; C163; C166; C167; C168; C169; C170; C171; C174; C175; C176; C177; C178; C179; C180; C181; C214; C218; C219; C220; C221; C230; C232; C270; C278; C286; C287; C288; C289; C290; C291; C292; C293; C294; C302; C308; C328; C329; C330; C331; C332; C333; C347; C348; C349; C350; C351; C352; C353; C356; C357; C378; C379; C380; C381; C382; C385; C412; C419; C426; C433; C444; C447; C451; C454; C462; C464; C466; C467; C468; C469; C471; C472; C473; C475; C476; C477; C478; C480; C481; C483; C484; C486; C488; C489; C490; C491; C497; C504; C506; C507; C510; C511; C512; C513; C514; C515; C518; C519; C520; C521; C522; C523; C524; C525; C526; C527; C528; C531; C532; C533; C534; C535; C536; C537; C538; C540; C548; C549; C592; C595; C596; C597; C598; C599; C600; C601; C646; C647; C648; C649; C650; C652; C653; C659; C660; C665; C666; C667; C668; C669; C670; C677; C679; C680; C682; C684; C685; C686; C689; C691; C692; C694; C695; C697; C698; C700; C876; C877; C878; C1519; C1520; C1521; C1522; C1523; C1531; C1532; C1533
C0402_H60CAPACITOR NP_C0402_H60_1000PF/51000pF/50VIC7C92; C274; C458; C661; C678; C688; C699
C0402_H60CAPACITOR NP_C0402_H60_3.3PF/503.3pF/50VIC4C122; C303; C386; C593
C0603_H60CAPACITOR NP_C0603_H60_4.7UF/104.7uF/10VIC51C5; C11; C12; C18; C19; C26; C27; C34; C41; C57; C65; C73; C81; C93; C100; C101; C102; C186; C192; C193; C199; C200; C207; C208; C216; C222; C238; C246; C254; C262; C271; C281; C282; C283; C358; C368; C387; C397; C455; C602; C615; C625; C636; C664; C848; C855; C859; C861; C868; C872; C1534
C0805_H110CAPACITOR NP_C0805_H110_10UF/1010uF/10VIC44C31; C90; C91; C94; C95; C96; C154; C155; C164; C165; C172; C173; C212; C272; C273; C275; C276; C277; C456; C457; C459; C460; C461; C463; C465; C470; C474; C508; C509; C516; C517; C529; C530; C656; C657; C658; C662; C663; C681; C683; C687; C690; C693; C696
C1206_H180CAPACITOR NP_C1206_H180_47UF/1047uF/10VIC38C6; C7; C8; C103; C104; C187; C188; C189; C284; C285; C345; C346; C354; C355; C414; C415; C417; C420; C428; C429; C431; C434; C446; C449; C450; C452; C479; C482; C485; C492; C494; C496; C605; C607; C654; C655; C794; C1474
C1206_H180CAPACITOR NP_C1206_H180_10UF/2510uF/25VIC13C407; C408; C409; C410; C421; C422; C423; C425; C439; C441; C442; C443; C1476
CT3528_H190CAPACITOR POL_CT3528_H190_100UF100uF/6.3VIC43C9; C10; C17; C25; C33; C43; C98; C99; C123; C125; C135; C138; C143; C145; C190; C191; C198; C206; C215; C223; C279; C280; C304; C306; C318; C319; C322; C325; C334; C337; C340; C413; C416; C418; C427; C430; C432; C445; C448; C453; C544; C546; C547
CT7343_H290CAPACITOR POL_CT7343_H290_330UF330uF/6.3VIC8C1; C2; C3; C4; C182; C183; C184; C185
CT7343_H290CAPACITOR POL_CT7343_H290_150UF150uF/10VIC2C795; C1475
CT7343_H400CAPACITOR POL_CT7343_H400_100UF100uF/25VIC4C435; C436; C437; C438
D0603STM_LED_0_D0603_LED/GREENLED/GreenIC8D2; D3; D4; D5; D11; D12; D13; D14
DC005PJ-102A_DC005_DC-005-3DC-005-3IC1JT2
D_SMC_H2131P5SMC16AT3G_D_SMC_H213_1.5SMC11.5SMC16AT3GIC1D15
FBGA96_P80_H110MT41J256M16RE-15E IT_FBGA96_P80MT41K256M16TW-107 ITIC12U9; U10; U24; U25; U29; U30; U31; U32; U48; U49; U50; U51
FBGA900_P100_L3100X3100_H315XC7X045FFG900_FBGA900_P100_L310XC7Z045-2FFG900IIC2U1; U16
HEAD1X2_P254_L254_THEADER 1X2_HEAD1X2_P254_L254_T_201S-2X1PS-6/3IC1J10
HEAD3X1_P254_L254_THEADER 3_HEAD3X1_P254_L254_T_20201S-1X3PS-6/3IC2J20; J21
HEAD7X2_P200_L200_SHEADER 7X2_HEAD7X2_P200_L200_S_302-2S-14P(shpeak)/2.0DC3-14P(ANUOCONN)IC2J2; J5
LED0603_H80STM_LED_LED0603_H80_LED/GREEN/0LED/Green/0603IC3D1; D10; D16
LGA25_P127_H180LTM4622_LGA25_P127_H180_LTM4622LTM4622IV#PBFIC1U76
LQFP64_P50_L1200X1200_H140ADV7511WBSWZ_LQFP64_P50_L1200X1ADV7511WBSWZIC1U37
OSC4_P210_L320X250OCETDLJ-NF_OSC4_P210_L320X250_550MHz/LVCOMSIC2U78; U79
OSC4_P210_L320X250OCETDLJ-NF_OSC4_P210_L320X250_333.33MHz/LVCOMSIC2U80; U81
OSC4_P210_L320X250OCETDLJ-NF_OSC4_P210_L320X250_224MHz/LVCOMSIC1U82
OSC4_P210_L320X250OCETDLJ-NF_OSC4_P210_L320X250_125MHz/LVCOMSIC2U83; U84
OSC6_P254_L500X320SI9121AI-2D2-33E160_OSC6_P254_L125MHz/LVPECLIC2U74; U75
QFN16_P65_L400X400_H75_TMAX13035EETE+_QFN16_P65_L400X40MAX13035EETE+IC1U77
QFN32_P50_L580X580_H100_TTLV320AIC3101_QFN32_P50_L580X58TLV320AIC3101IRHBTIC1U42
QFN_N20_P65_L500X500_T315X315TPS74401RGWT_0_QFN_N20_P65_L500TPS74401RGWTIC3U53; U54; U55
R0402_H40RESISTOR_R0402_H40_R0402_NCR0402_NCIC12R1; R2; R11; R12; R58; R116; R118; R119; R174; R225; R297; R332
R0402_H40RESISTOR_R0402_H40_4.7K/5%4.7K/5%IC40R3; R13; R14; R15; R21; R59; R62; R63; R109; R110; R111; R112; R113; R117; R120; R128; R129; R130; R131; R137; R175; R178; R179; R226; R266; R267; R269; R270; R277; R280; R289; R293; R305; R306; R307; R320; R327; R334; R926; R930
R0402_H40RESISTOR_R0402_H40_20K/1%20K/1%IC14R4; R5; R6; R7; R8; R9; R10; R121; R122; R123; R124; R125; R126; R127
R0402_H40RESISTOR_R0402_H40_33R/1%33R/1%IC2R16; R132
R0402_H40RESISTOR_R0402_H40_10K/1%10K/1%IC28R23; R33; R38; R39; R40; R139; R149; R154; R155; R161; R189; R231; R238; R241; R248; R251; R262; R263; R264; R265; R321; R360; R361; R362; R363; R370; R920; R1051
R0402_H40RESISTOR_R0402_H40_1K/1%1K/1%IC16R24; R25; R85; R86; R93; R94; R96; R108; R140; R141; R309; R311; R313; R314; R317; R318
R0402_H40RESISTOR_R0402_H40_240R/1%240R/1%IC12R26; R27; R142; R143; R199; R200; R227; R228; R330; R348; R358; R359
R0402_H40RESISTOR_R0402_H40_80.6R/1%80.6R/1%IC12R28; R29; R144; R145; R195; R196; R197; R198; R364; R365; R366; R367
R0402_H40RESISTOR_R0402_H40_40.2R/1%40.2R/1%IC100R30; R31; R32; R34; R35; R36; R37; R41; R42; R43; R44; R45; R46; R47; R48; R49; R50; R51; R52; R53; R54; R55; R56; R57; R60; R61; R146; R147; R148; R150; R151; R152; R153; R156; R157; R158; R159; R160; R162; R163; R164; R165; R166; R167; R168; R169; R170; R171; R172; R173; R176; R177; R201; R202; R203; R204; R205; R206; R207; R208; R209; R210; R211; R212; R213; R214; R215; R216; R217; R218; R219; R220; R221; R222; R223; R224; R331; R333; R335; R336; R337; R338; R339; R340; R341; R342; R343; R344; R345; R346; R347; R349; R350; R351; R352; R353; R354; R355; R356; R357
R0402_H40RESISTOR_R0402_H40_330R/5%330R/5%IC13R64; R65; R75; R76; R77; R78; R180; R181; R191; R192; R193; R194; R322
R0402_H40R_R0402_H40_100R/1%100R/1%IC6R66; R927; R928; R929; R931; R932
R0402_H40R_R0402_H40_4.7K/5%4.7K/5%IC1R67
R0402_H40R_R0402_H40_22R/5%22R/5%IC14R68; R69; R70; R71; R72; R74; R115; R184; R185; R186; R187; R188; R190; R319
R0402_H40RESISTOR_R0402_H40_49.9R/1%49.9R/1%IC20R83; R84; R87; R88; R89; R90; R91; R92; R229; R230; R294; R298; R299; R300; R301; R302; R303; R304; R328; R329
R0402_H40RESISTOR_R0402_H40_4.99K/1%4.99K/1%IC3R95; R308; R373
R0402_H40R_R0402_H40_0R/5%0R/5%IC7R101; R102; R105; R295; R296; R316; R933
R0402_H40RESISTOR_R0402_H40_0R/5%0R/5%IC10R232; R236; R237; R239; R242; R246; R247; R249; R252; R261
R0402_H40RESISTOR_R0402_H40_90.9K/1%90.9K/1%IC6R233; R234; R235; R243; R244; R245
R0402_H40RESISTOR_R0402_H40_30.1K/1%30.1K/1%IC1R250
R0402_H40RESISTOR_R0402_H40_40.2K/1%40.2K/1%IC3R258; R259; R921
R0402_H40RESISTOR_R0402_H40_887R/1%887R/1%IC1R273
R0402_H40RESISTOR_R0402_H40_1K/5%1K/5%IC6R285; R288; R291; R292; R325; R326
R0402_H40RESISTOR_R0402_H40_4.53K/1%4.53K/1%IC1R368
R0402_H40RESISTOR_R0402_H40_1.13K/1%1.13K/1%IC1R369
R0402_H40RESISTOR_R0402_H40_3.57K/1%3.57K/1%IC1R371
R0402_H40RESISTOR_R0402_H40_2.87K/1%2.87K/1%IC1R372
R0402_H40RESISTOR_R0402_H40_2.49K/1%2.49K/1%IC1R374
R0402_H40R_R0402_H40_324K/1%324K/1%IC1R934
R0402_H40RESISTOR_R0402_H40_25.8K/1%25.8K/1%IC1R1049
R0402_H40RESISTOR_R0402_H40_8.25K/1%8.25K/1%IC1R1050
R0402_H40RESISTOR_R0402_H40_19.1K/1%19.1K/1%IC1R1078
R0603RESISTOR_R0603_R_NMR_NMIC2R323; R324
R0603_H60RESISTOR_R0603_H60_330R/5%330R/5%IC4R103; R107; R310; R312
R0603_H60RESISTOR_R0603_H60_4.7K/5%4.7K/5%IC4R114; R183; R268; R315
R0603_H60R_R0603_H60_13.3K/1%13.3K/1%IC1R253
R0603_H60RESISTOR_R0603_H60_33R/1%33R/1%DISCRETE1R271
R0603_H60RESISTOR_R0603_H60_10K/5%10K/5%IC1R272
R0603_H60RESISTOR_R0603_H60_5.6K/1%5.6K/1%IC1R278
R0603_H60RESISTOR_R0603_H60_22R/5%22R/5%DISCRETE5R281; R282; R283; R284; R290
R0603_H60RESISTOR_R0603_H60_51K/1%51K/1%IC7R1071; R1072; R1073; R1074; R1075; R1076; R1077
RJ45_HR911130CHR911130C_RJ45_HR911130C_HR9111HR911130CEIC2J3; J9
SLP2510P8RCLAMP0524P_TCT_SLP2510P8_RCLAMRCLAMP0524P.TCTIC3U38; U39; U41
SON10_P50_L285_H100TPS51200DRCT_SON10_P50_L285_H10TPS51200DRCTIC4U11; U26; U36; U52
SOP16_P127_L1030X1065MT25QL256ABA8ESF-OSIT_SOP16_P12MT25QL256ABA8ESF-0SITIC4U2; U3; U18; U19
SOT23_3_H1002N7002-7-F_SOT23_3_H100_2N70022N7002IC2Q1; Q2
SOT23_5_H130SN74LVC1G08_SOT23_5_H130_SN74LVSN74LVC1G08DBVIC2U15; U45
SOT23_6_H145TPS3808G18DBV_SOT23_6_H145_TPS3TPS3808G25DBVIC4U4; U8; U17; U23
STEREO_JACK_STX-3120-5BSTX-3120-5B_STEREO_JACK_STX-312STX-3120-5BIC1J7
TF-15X15TF-15X15A_TF-15X15_TF-15X15TF-15X15IC1J25
TOM-1545P-RTOM-1545L-R_TOM-1545P-R_TOM-154TOM-1545P-RIC1U46
TP_HOLETP_SMD_S_TP_HOLE_TP_HOLETP_HOLEIC20TP1; TP2; TP3; TP4; TP5; TP6; TP7; TP8; TP9; TP10; TP11; TP12; TP13; TP14; TP15; TP16; TP17; TP18; TP19; TP20
TSSOP16_P65_L640_H120SN74AVC4T245PW_TSSOP16_P65_L640SN74AVC4T245PWIC3U12; U27; U47
附件:0 A4 y8 W! Q3 j3 E, M' l
原理图和PCB文件如下:
8 P' h2 \& x; _4 f! N8 _2 U
游客,如果您要查看本帖隐藏内容请回复
2 K7 c' l! L0 Z4 j" J- M
# ~6 k9 t4 O  F
发表于 2020-9-27 16:34 | 只看该作者
谢谢
    奋斗
    2024-3-18 15:56
  • 签到天数: 10 天
    [LV.3]偶尔看看II
    发表于 2023-6-6 10:25 | 只看该作者
    你这个板子验证过吗,怎么记得塞灵思的ddr bank,33 34 35 ,中间bank34必须放地址,33 35放数据,有这回事吗
    发表于 2020-10-10 11:37 | 只看该作者
    看看看看,好强大,呵呵呵/ h1 T' X' t7 U5 I+ h3 M7 f/ z: ?5 }
    24#
    发表于 2023-7-4 13:59 | 只看该作者
    IP camera这么强大
    23#
    发表于 2023-6-6 16:03 | 只看该作者
    :victory::victory:
    2023-8-24 15:07
  • 签到天数: 137 天
    [LV.7]常住居民III
    20#
    发表于 2022-2-4 19:06 | 只看该作者
    学习下,只做过10层板
    : l, d" w/ R+ P2 E  P# B0 x4 c5 ?: p) O, f4 y" Q! \( ~" g, T
    2024-1-3 15:03
  • 签到天数: 4 天
    [LV.2]偶尔看看I
    16#
    发表于 2021-7-30 10:56 | 只看该作者
    学习一下 看看
    2025-11-26 15:28
  • 签到天数: 884 天
    [LV.10]以坛为家III
    15#
    发表于 2021-7-13 08:48 | 只看该作者
    dddddddddddddddd
    9 H7 \/ F- z9 P: e$ V
    2024-8-26 15:16
    14#
    发表于 2021-7-11 16:49 | 只看该作者
    这个比较牛掰
    4 A9 g/ m* e) v3 g. O
    2020-12-14 15:26
    发表于 2021-7-1 17:28 | 只看该作者
    学习一下 看看% X$ G4 L' W9 t& W7 y
    GMT+8, 2025-11-27 03:13 , Processed in 0.218750 second(s), 30 queries , Gzip On.
