标题: [allegro16.6][8层]4片DDR,用来练手(816X_0_SKTBGA+4片DDR+ISL6535CRZ)pcb文件 [打印本页]
作者: SallyDai2    时间: 2019-12-31 18:20
2 ]) \1 ]# n2 h
- b8 I" h2 F, K3 j& V
) G! w* ~$ F9 C3 c1 H+ }! L# t文件描述:; |& m0 Q/ m: E' J4 V$ i
5 h" F9 M$ R; C8 C+ t
1. 作品用途:4片DDR,用来练手8 |$ g, ?0 |- b7 G
2. 软件版本:allegro16.6) ?  S7 K  o1 Y* i( \" F; ^+ X  I
3. 层数:8层
' K0 w' W" f. _! S# V: u7 z4. 用到的主要芯片:816X_0_SKTBGA+4片DDR+ISL6535CRZ
6 j) ]! d  P2 S5. pcb尺寸:50*75 MM
/ j& [: @8 c6 [1 u( v: {, j( M& N& z3 \* H
作品截图如下:5 e. m1 g" `+ @3 B4 @' d5 D' L
8 z$ B) E! A* R- @$ F3 r6 n* I0 w
顶层截图:' F( D1 G( a" Q6 J
0 E# T9 S' ^+ P3 M: Q7 h7 t! S全层截图:; m1 s. k6 I& @, e
& S4 D! ^  e1 [3 S# z/ ]
- Q( `; E8 t% r' O$ {1 uBOM:- o9 d. F+ |7 R/ q& ]+ L
SYM_NAMECOMP_DEVICE_TYPECOMP_VALUECOMP_CLASSQUANTITYREFDES
名称类型属性类别数量位号
BGA6X13-P8-12P75EDJ1108DBSE_0_BGA6X13-P8-12P75_MT41J128M8JP-125:GIC4U2; U3; U4; U5
C0402CAP NP_0_C0402_0.1UF0.1uFIC64C1; C2; C3; C4; C5; C6; C7; C8; C9; C10; C11; C12; C13; C14; C15; C16; C17; C18; C19; C20; C21; C86; C87; C88; C89; C90; C91; C92; C93; C94; C95; C96; C97; C99; C100; C101; C102; C103; C104; C105; C106; C108; C109; C110; C111; C112; C113; C114; C115; C116; C117; C118; C119; C121; C122; C123; C124; C125; C126; C127; C128; C151; C157; C158
C0402C_2_C0402_0.1UF0.1uFIC60C22; C23; C24; C25; C26; C27; C28; C29; C30; C31; C32; C33; C34; C35; C36; C37; C38; C39; C40; C41; C42; C43; C44; C45; C46; C47; C48; C49; C50; C51; C52; C53; C54; C55; C56; C57; C58; C59; C60; C61; C62; C63; C64; C65; C66; C67; C68; C69; C70; C71; C72; C73; C74; C75; C76; C77; C78; C79; C80; C81
C0402CAP NP_C0402_0.1UF/16V_YC10-0000.1uF/16VIC6C130; C135; C138; C144; C145; C147
C0402CAP NP_C0402_390PF/50V_YC10-001390pF/50VIC1C142
C0402CAP NP_C0402_1.5PF/50V_YC10-0011.5pF/50VIC1C146
C0402CAP NP_0_C0402_0.001UF0.001uFIC1C149
C0402CAP NP_0_C0402_1000PF1000pFIC1C152
C0402CAP NP_0_C0402_10PF10pFIC1C159
C0603CAP NP_C0603_1UF/25V_YC10-000321uF/25VIC2C136; C137
C0603CAP NP_C0603_3300PF/50V_YC10-003300pF/50VIC2C139; C148
C1206CAP POL_C1206_10UF/25V_YC10-00110uF/25VIC3C131; C132; C143
DRC-10TPS51200_DRC-10_TPS51200DRCTTPS51200DRCTIC1U7
L4040INDUCTOR_L4040_1UH/5A_YL10-00031uH/5AIC1L1
NSIP4CONN RCPT 4/SM_NSIP4_POWER CONPOWER CONIC1J1
QFN16ISL6535CRZ_QFN16_12V PWM_YU00-012V PWMIC1U6
R0402R_R0402_49.9R49.9RIC27R1; R2; R3; R4; R5; R6; R7; R8; R9; R10; R11; R12; R13; R14; R15; R16; R17; R18; R19; R20; R21; R22; R23; R24; R25; R26; R27
R0402R0201_0_R0402_240R240RIC4R28; R29; R30; R31
R0402RES_V_R0402_510 OHM_YR10-00318-510 ohmIC1R33
R0402RES_V_R0402_10K_YR10-00066-10010KIC4R34; R35; R38; R42
R0402RES_V_R0402_11K8_YR10-00311-00011K8IC1R37
R0402RES_V_R0402_4K7_YR10-00091-1004K7IC1R40
R0402RES_V_R0402_120K_YR10-00154-100120KIC1R41
R0402R_R0402_10K10KIC3R45; R47; R49
R0402R_R0402_100K100KIC1R46
R0402R_R0402_10R10RIC1R48
R0603RES_V_R0603_2.2 OHM_YR10-00131-2.2 ohmIC2R32; R36
R0603RES_V_R0603_31K6_YR10-00241-10031K6IC1R39
R0603RES_V_R0603_2K2_YR10-00202-1002K2IC2R43; R44
SKTBGA-1031-37X37_C9212_P65MM816X_0_SKTBGA-1031-37X37_C9212_Controller ICIC1U1
SO8-MOSFETSI468DP-T1-GE3_6_SO8-MOSFET_30V30V/40A NChIC1Q1
SO8-MOSFETSI468DP-T1-GE3_6_SO8-MOSFET_3_130V/60A NChIC1Q2
SOD123MBR05030T1G_8_SOD123_30V/0A5_YD30V/0A5IC1D1
TC3216CAP_0_TC3216_33UF33uFIC8C82; C83; C84; C85; C98; C107; C120; C129
TC3216CAP_0_TC3216_10UF10uFIC1C150
TC3216CAP_0_TC3216_10UF/16V 10%10uF/16V 10%IC2C155; C156
TC3528CAP_0_TC3528_100UF/6.3V 10%100uF/6.3V 10%IC2C153; C154
TC7343CAP POL_TC7343_270UF/16V_YC20-0270uF/16VIC2C133; C134
TC7343CAP POL_TC7343_470UF/6.3V_YC20-470uF/6.3VIC2C140; C141
附件:/ n5 Y% h& v1 f$ E1 d, G* p+ \* k
PCB文件如下:
( ~. R0 H$ L% Y% e' r4 K; y+ u
; `/ Z0 I3 e6 f, l8 |1 c/ |; q/ i9 V4 d5 l! Y* ^1 M/ U5 Q7 s
作者: zcw500234    时间: 2023-2-9 14:08
看一下
作者: Dc202409072a    时间: 2024-9-8 00:06
