[allegro16.5][2层]DP83640实现光口电路(DP83640+SN65LVELT22+光口)pcb文件 1 ` h0 Y# D7 @- A p8 h( Q" F" a6 T. @2 R+ P4 T" t# O3 S6 s5 W6 X3 O$ M$ W2 ~( t3 i
文件描述: * _! r+ p" a* r! Y$ |. O' d" E1 m* |( w0 [9 o: d
1. 作品用途:DP83640实现光口电路 2. 软件版本:allegro16.5 3. 层数:2层 4. 用到的主要芯片: DP83640+SN65LVELT22+光口 l* ?3 ]) I4 B3 c, B
4 E- R# c/ t. S+ F9 s J5. pcb尺寸:46.2*89.5 mm 1 [/ B: w% g- u b
DP83640实现光口电路,可实现单纤通讯 + ]! M4 L* E4 c4 F5 {/ v# e
作品截图如下: 1 q* l. u# D, a3 T `, \) M. p2 N4 D8 O ~4 S
0 M# P* C$ N) H& w C+ t. j顶层截图: * B8 R: Y, A0 ~, `. _1 i
9 p4 L2 p' x$ u/ D底层截图: 4 e: v# e* l" b2 J# M" q: W% ~8 ^3 M# k8 s: S9 I; D3 Q" g# k* J8 [! |! l+ q }7 e
; z% u5 q$ c+ P* }! Y6 f( p% F' g
: e# o" x3 s6 A' Y7 h) S" H; B全层截图: 4 k$ f- ~: ^- B; Q# b! Y: g# S8 L) v0 I
" r% e9 m/ r& v- U ^+ r. p+ J: t" b# G5 i% G( f BOM: | Bill of Material Report (Condensed) | | SYM_NAME | COMP_DEVICE_TYPE | COMP_VALUE | COMP_CLASS | QUANTITY | REFDES | | 名称 | 类型 | 属性 | 类别 | 数量 | 位号 | | 603 | CAP_0603_27PF | 27pF | IC | 2 | C1; C2 | | 603 | CAP NP_0603_10NF | 10nF | IC | 1 | C3 | | 603 | CAP NP_0603_0.1UF | 0.1uF | IC | 9 | C4; C5; C8; C9; C10; C11; C12; C13; C14 | | 603 | CAP NP_0603_104 | 104 | IC | 4 | C16; C17; C19; C20 | | 603 | LQH4C_0603_10NH 3MA | 10nH 3mA | IC | 1 | FB1 | | 603 | LQH4C_0603_600 | 600 | IC | 2 | FB2; FB3 | | 603 | R0_1_0603_4.7K | 4.7K | IC | 1 | R1 | | 603 | R0_1_0603_2.2K | 2.2K | IC | 3 | R2; R3; R4 | | 603 | R0_1_0603_1.5K | 1.5K | IC | 1 | R5 | | 603 | R0_1_0603_4K87 | 4K87 | IC | 1 | R8 | | 603 | R0_1_0603_1K | 1K | IC | 1 | R9 | | 603 | R0_1_0603_49.9 | 49.9 | IC | 2 | R10; R11 | | 603 | R5_0.1K_0603_0603_130/NC | 130/NC | IC | 4 | R12; R13; R16; R18 | | 603 | R5_0.1K_0603_0603_82/NC | 82/NC | IC | 2 | R14; R15 | | 603 | R5_0.1K_0603_0603_150/NC | 150/NC | IC | 2 | R17; R19 | | 603 | R5_0.1K_0603_0603_4.7K | 4.7K | IC | 4 | R20; R21; R22; R24 | | 603 | R5_0.1K_0603_0603_4.7K/NC | 4.7K/NC | IC | 1 | R23 | | 603 | R_1_0603_4.7K | 4.7K | IC | 1 | R25 | | 603 | R0_1_0603_590 | 590 | IC | 2 | R28; R29 | | 805 | CAP NP_0805_10UF | 10UF | IC | 2 | C6; C7 | | 805 | R0_1_0805_0 | 0 | IC | 4 | R6; R7; R26; R27 | | 1206 | CAP NP_1206_47UF/6.3V | 47UF/6.3V | IC | 2 | C15; C18 | | CON_MOL_20_74441_0010 | SFP-FE-SX-MM1310-A_CON_MOL_20_7 | SFP-FE-SX-MM1310-A | IC | 1 | J2 | | HC-49US | CRYSTAL_0_HC-49US_25MHZ | 25MHZ | IC | 1 | Y1 | | HDR_2X20 | HEADER 20X2_HDR_2X20_HEADER 20X | HEADER 20X2 | IC | 1 | J1 | | LED_0603 | 1N6265/TO_1_LED_0603_GREEN | green | IC | 2 | LED1; LED2 | | LQFP-48 | DP83640_LQFP-48_DP83640 | DP83640 | IC | 1 | U1 | | OSC_SIT8103_PKG2 | 767-33_OSC_SIT8103_PKG2_SIT8103 | SiT8103AI -13-25E -25 | IC | 1 | U4 | | SN65LVELT22DR_DGK | SN65LVELT22_SN65LVELT22DR_DGK_S | SN65LVELT22 | IC | 1 | U2 | | SO14 | 74LS04_SO14_74LS04 | 74LS04 | IC | 1 | U3 | | SOT_23 | 2N6660_SOT_23_NDS331N/NC | NDS331N/NC | IC | 1 | Q1 | : Y8 s7 e+ w! E5 N
附件:
) n# m: ?" u: M1 g0 h原理图和pcb文件如下: |
