[ allegro16.5][4层]HI3518 V200 IP Camera扩展板(18EV2CON+ RTL8201F+SGM8903+网口)pcb文件 3 w: H. h( u+ ~, H8 B- W7 E* S
$ H2 s5 Q/ V: D3 H文件描述: 9 P( i6 H: O/ I0 a" w! T) ], C8 ~4 k" b/ n$ Z: ^3 g9 r1 S5 i1 C$ N; C
1. 作品用途:HI3518 V200 IP Camera扩展板 2. 软件版本:allegro16.5 3. 层数:4层 4. 用到的主要芯片:18EV2CON+ RTL8201F+SGM8903+网口 5. PCB尺寸:127.22*103.99mm
% N1 U9 ~# Z: L! a( y! x作品截图如下: % v# y( E) L9 r. C( G
0 y; Y* |, z( N- w: B$ M# P顶层截图: - Y% h( I* [: F. {8 W
底层截图: # E, Q) m6 h# _2 {8 o- z2 |8 I+ Q7 Q- ?1 K* d& C6 E* u
t8 b1 l8 [# s( h/ j* }/ I2 ]% t1 ?& p& E* n/ y [0 ?5 L5 B: ~% F+ E
全层截图: 9 D5 ~2 C4 j9 C( L2 U7 |- T7 i: \) [
叠层阻抗信息:
BOM: | Bill of Material Report (Condensed) | | SYM_NAME | COMP_DEVICE_TYPE | COMP_VALUE | COMP_CLASS | QUANTITY | REFDES | | 名称 | 类型 | 属性 | 类别 | 数量 | 位号 | | BTH100-050M | BTH100-050M | 18EV2CON_100_M | IC | 2 | J5; J6 | | CAPC2-138-335 | CAPC2-138-335 | 220UF | IC | 1 | C41 | | HSC0402 | HSC0402 | 330N | IC | 2 | C2; C3 | | HSC0402 | HSC0402 | 2.2UF | IC | 2 | C566; C567 | | HSL1008 | HSL1008 | 2.2UH | DISCRETE | 2 | L4; L5 | | HSOD882 | HSOD882 | PESD5V0S1BL315 | IC | 12 | D3; D4; D7; D8; D9; D11; D12; D13; D20; D21; D27; D28 | | HSR0402 | HSR0402 | 560 | DISCRETE | 2 | R105; R106 | | HSX4-0503 | HSX4-0503 | 25MHZ | IC | 1 | OSC1 | | MJ8-RL-A | MJ8-RL-A | 406533_1 | IC | 1 | J1 | | MLF6-065-0202L | MLF6-065-0202L | TPS2553DRVR | IC | 1 | U2 | | MSOP8A-26-118 | MSOP8A-26-118 | PAM8303D | IC | 1 | U5 | | MTH_C6MMD3P2MM | MTH_C6MMD3P2MM | HOLE | IC | 4 | M1; M2; M3; M4 | | PSW6-RA | PSW6-RA | PSE_22F022NL_TA_WK | IO | 1 | S1 | | PWC0103-M-N | PWC0103-M-N | DC2026_00 | IC | 1 | J9 | | QFN16-050-0303LH | QFN16-050-0303LH | MP6507 | IC | 1 | U16 | | QFN32C-050-0505LH | QFN32C-050-0505LH | RTL8201F-VB-CG | IC | 1 | U3 | | SBAT2-13A | SBAT2-13A | BR_1225F1AN | IC | 1 | U9 | | SC0402 | SC0402 | 5.6PF | IC | 1 | C7 | | SC0402 | SC0402 | 15PF/NC | IC | 2 | C8; C22 | | SC0402 | SC0402 | 47PF | IC | 2 | C11; C12 | | SC0402 | SC0402 | 100NF | IC | 17 | C19; C20; C25; C26; C27; C30; C31; C45; C46; C68; C76; C79; C84; C100; C138; C218; C219 | | SC0402 | SC0402 | 1NF | IC | 3 | C52; C144; C145 | | SC0402 | SC0402 | 10NF | IC | 2 | C102; C103 | | SC0402 | SC0402 | 680PF | IC | 2 | C118; C119 | | SC0402 | SC0402 | 1UF | IC | 2 | C123; C169 | | SC0402 | SC0402 | 100NF/NC | IC | 1 | C188 | | SC0402 | SC0402 | 33PF | IC | 2 | C189; C191 | | SC0402 | SC0402 | 10PF | IC | 2 | C193; C196 | | SC0402 | SC0402 | 15PF | IC | 2 | C223; C224 | | SC0402-BGA | SC0402-BGA | 100NF | IC | 5 | C29; C94; C96; C97; C98 | | SC0402-BGA | SC0402-BGA | 1UF | IC | 1 | C114 | | SC0603 | SC0603 | 100NF | IC | 6 | C5; C10; C13; C49; C50; C64 | | SC0603 | SC0603 | 2.2UF | IC | 3 | C35; C147; C148 | | SC0603 | SC0603 | 1UF | IC | 1 | C40 | | SC0603 | SC0603 | 220PF | IC | 2 | C42; C43 | | SC0603 | SC0603 | 10NF | IC | 1 | C55 | | SC0603 | SC0603 | 10UF | IC | 3 | C63; C180; C195 | | SC0603 | SC0603 | 4.7UF/NC | IC | 1 | C192 | | SC0603 | SC0603 | 15PF/NC | IC | 2 | C316; C317 | | SC0805 | SC0805 | 10UF | DISCRETE | 6 | C1; C4; C6; C9; C14; C21 | | SC0805 | SC0805 | 1UF | DISCRETE | 4 | C36; C37; C38; C39 | | SC1206 | SC1206 | 47UF | DISCRETE | 1 | C17 | | SC1206 | SC1206 | 22UF | DISCRETE | 4 | C24; C33; C73; C74 | | SC1206 | SC1206 | 1NF | DISCRETE | 1 | C53 | | SC1210 | SC1210 | 100UF | IC | 1 | C194 | | SC1210B | SC1210B | 22UF | DISCRETE | 5 | C15; C54; C56; C59; C61 | | SCAPC2-0808C | SCAPC2-0808C | 220UF | IC | 1 | C139 | | SD0805-LED | SD0805-LED | LED | DISCRETE | 1 | D6 | | SD1714A | SD1714A | D | IC | 1 | D2 | | SD1714A | SD1714A | DIODE | IC | 1 | D5 | | SD1714D | SD1714D | TISP4350H3BJR_S | IC | 1 | D10 | | SD2723 | SD2723 | DZ | IC | 1 | D1 | | SF6127 | SF6127 | 0451005MRL | DISCRETE | 1 | F1 | | SGM8903 | SGM8903 | SGM8903 | IC | 1 | U7 | | SIP-2P | SIP-2P | NC | IO | 4 | J11; J13; J17; J24 | | SIP-3P | SIP-3P | 201_040_003_05_3 | IO | 2 | J22; J23 | | SIP-4P-100 | SIP-4P-100 | P2500J_04 | IO | 1 | J7 | | SL0402 | SL0402 | LB | DISCRETE | 1 | LB1 | | SL0603 | SL0603 | MGLB1608_030T_LF | IC | 3 | LB14; LB15; LB16 | | SL0805 | SL0805 | MGLB2012_220T_LF | IC | 3 | LB2; LB3; LB9 | | SOP8-50-150 | SOP8-50-150 | TLV2372IDR | IC | 1 | U4 | | SOP8-50-150 | SOP8-50-150 | ADM3485EAR_REEL7 | IC | 1 | U10 | | SOT23 | SOT23 | NPN-BEC | IC | 3 | Q1; Q3; Q6 | | SOT23 | SOT23 | PMOS-GSD | IC | 1 | Q2 | | SPL0505H | SPL0505H | 4.7U | DISCRETE | 3 | L1; L2; L3 | | SR0402 | SR0402 | 10 | IC | 3 | R1; R3; R89 | | SR0402 | SR0402 | 47K | IC | 1 | R2 | | SR0402 | SR0402 | 1MEG | IC | 1 | R4 | | SR0402 | SR0402 | 100 | IC | 3 | R5; R81; R82 | | SR0402 | SR0402 | 220 | IC | 2 | R6; R28 | | SR0402 | SR0402 | 2.2K | IC | 1 | R7 | | SR0402 | SR0402 | 1K | IC | 6 | R11; R49; R51; R61; R210; R236 | | SR0402 | SR0402 | 0 | IC | 5 | R13; R14; R17; R44; R84 | | SR0402 | SR0402 | 33K | IC | 2 | R15; R16 | | SR0402 | SR0402 | 10K | IC | 6 | R18; R132; R157; R158; R173; R203 | | SR0402 | SR0402 | 0/NC | IC | 2 | R20; R85 | | SR0402 | SR0402 | 2MEG | IC | 1 | R21 | | SR0402 | SR0402 | 39.2K | IC | 1 | R24 | | SR0402 | SR0402 | 1.5K | IC | 1 | R25 | | SR0402 | SR0402 | 11.3K | IC | 1 | R27 | | SR0402 | SR0402 | 4.7K | IC | 17 | R30; R32; R36; R67; R68; R78; R91; R97; R127; R128; R129; R130; R131; R133; R135; R205; R209 | | SR0402 | SR0402 | 51K | IC | 2 | R34; R37 | | SR0402 | SR0402 | 121K | IC | 1 | R38 | | SR0402 | SR0402 | 13.7K | IC | 1 | R53 | | SR0402 | SR0402 | 100K | IC | 12 | R54; R55; R56; R58; R59; R60; R64; R65; R66; R80; R174; R175 | | SR0402 | SR0402 | 22 | IC | 4 | R71; R73; R75; R141 | | SR0402 | SR0402 | 4.7K/NC | IC | 2 | R72; R79 | | SR0402 | SR0402 | 200 | IC | 1 | R74 | | SR0402 | SR0402 | 120 | IC | 1 | R83 | | SR0402 | SR0402 | 15K | IC | 1 | R90 | | SR0402 | SR0402 | 2K | IC | 1 | R92 | | SR0402 | SR0402 | 470K | IC | 2 | R93; R94 | | SR0402 | SR0402 | 20K | IC | 1 | R95 | | SR0402 | SR0402 | 75 | IC | 1 | R96 | | SR0402 | SR0402 | 2.7K | IC | 2 | R110; R139 | | SR0402 | SR0402 | 5.6K | IC | 1 | R176 | | SR0402 | SR0402 | NC/4.7K | IC | 2 | R206; R207 | | SR0402 | SR0402 | 6.8K | IC | 2 | R214; R215 | | SR0603 | SR0603 | 5.1K | IC | 2 | R8; R9 | | SR0603 | SR0603 | 10 | IC | 1 | R12 | | SR0603 | SR0603 | 7.68K | IC | 1 | R19 | | SR0603 | SR0603 | 100 | IC | 1 | R23 | | SR0603 | SR0603 | 1.1K | IC | 6 | R26; R40; R43; R57; R150; R151 | | SR0603 | SR0603 | 100/NC | IC | 1 | R35 | | SR0603 | SR0603 | 2K | IC | 1 | R39 | | SR0603 | SR0603 | 75 | IC | 1 | R47 | | SR0603 | SR0603 | 0 | IC | 2 | R48; R52 | | SR0603 | SR0603 | 0/NC | IC | 1 | R50 | | SR0603 | SR0603 | 40.2K | IC | 1 | R62 | | SR0603 | SR0603 | 2.49K | IC | 1 | R63 | | SR0603 | SR0603 | 2 | IC | 2 | R69; R70 | | SR0603 | SR0603 | 24.3K | IC | 2 | R103; R104 | | SR1206 | SR1206 | 0.15 | IC | 1 | R10 | | SRLY8-87-283 | SRLY8-87-283 | UD2_3NU_L5 | IC | 1 | K3 | | STC7343 | STC7343 | 47UF | DISCRETE | 2 | C16; C62 | | STC7343 | STC7343 | 47UF/NC | DISCRETE | 1 | C18 | | STC7343 | STC7343 | 100UF | DISCRETE | 1 | C151 | | STFM16-50-285 | STFM16-50-285 | H1102T | IC | 1 | T1 | | TF_CARD-MISOSD | TF_CARD-MISOSD | 475792245 | IC | 1 | J2 | | TSOT23-6 | TSOT23-6 | MP2370 | IC | 1 | U1 | | TSOT23-8 | TSOT23-8 | MP1494S | IC | 2 | U6; U8 | | USB4-200-1907 | USB4-200-1907 | UB31123_K1_4F | IC | 1 | J12 | | VAF6-1406D | VAF6-1406D | JAM3335_F26_7F_W_A | IC | 2 | J8; J10 | | WBC0104-49T | WBC0104-49T | SDW12501_4A_HW | IC | 3 | J15; J18; J20 | | WBC0108-49T | WBC0108-49T | SDW12501A_8A_HW | IC | 1 | J14 |
附件: PCB文件如下:
( X- b$ Y* Y8 {; m2 | |
