[allegro16.6][4层]RK3326官方参考设计之二(ILCC48+FPC40-5920)pcb文件 4 `% d+ v. }1 `9 r. H% |6 y" ^: O8 u2 W
文件描述:
' n! X; X; O5 D& p! J1. 作品用途:RK3326官方参考设计之二 2. 软件版本:allegro16.6 3. 层数:4层 4. 用到的主要芯片:RK3326+K3PE0E000E 5. PCB尺寸:异形板
4 I) y& S. x9 {0 [( @' v$ C
作品截图如下: 2 Q% u6 X8 x1 f$ y. }- k
! K. a; g# ?$ X' O r顶层截图: $ d) v; l& D1 s$ N; {1 u* \
9 j7 H& u3 |* {7 T- M( {底层截图: 4 r$ c5 q# A# ^- S
+ F$ W8 F( i5 W( p8 m ~3 @5 Y- G; {. I$ D* \* m: A+ d! ~9 V0 O* D
全层截图: / O, ~' N! r" f" Q: e1 o: d3 H- g- z+ A
p. k" B \/ W8 N
BOM: | Bill of Material Report (Condensed) | | | | | | | SYM_NAME | COMP_DEVICE_TYPE | COMP_VALUE | COMP_CLASS | QUANTITY | REFDES | | 名称 | 类型 | 属性 | 类别 | 数量 | 位号 | | BGA216_12R00X12R00X0R90 | DRAM_LPDDR2_216P_BGA216_12R00X1 | K3PE0E000E | IC | 1 | U3400 | | BGA418_14R00X14R00X1R24 | mcu_RK3326_BGA418_14R00X14R00X1 | RK3326 | IC | 1 | U1000 | | C0402 | CAP NP_C0402_100NF | 100nF | IC | 35 | C1001; C1002; C1003; C1004; C1005; C1006; C1008; C1009; C1010; C1011; C1012; C1013; C1201; C1202; C1203; C1204; C1205; C1206; C3400; C3401; C3404; C3405; C3410; C3411; C3412; C3413; C3416; C3417; C3418; C3419; C3420; C3423; C3424; C3425; C3426 | | C0402 | CAP NP_C0402_4.7UF | 4.7uF | IC | 3 | C1014; C1015; C1200 | | C0402 | CAP NP_C0402_2.2UF | 2.2uF | IC | 1 | C1016 | | C0402 | CAP NP_C0402_1NF | 1nF | IC | 5 | C3402; C3403; C3406; C3407; C3427 | | C0402 | CAP NP_C0402_100PF | 100pF | IC | 1 | C3408 | | C0402 | CAP NP_C0402_1UF | 1uF | IC | 2 | C3415; C3422 | | C0603 | CAP NP_C0603_22UF | 22uF | IC | 2 | C1000; C1007 | | C0603 | CAP NP_C0603_10UF | 10uF | IC | 3 | C3409; C3414; C3421 | | R0402 | RESISTOR_R0402_10K | 10K | IC | 6 | R3400; R3401; R3405; R3406; R3409; R3410 | | R0402 | RESISTOR_R0402_0R | 0R | IC | 3 | R3402; R3403; R3404 | | R0402 | RESISTOR_R0402_240R | 240R | IC | 2 | R3407; R3408 | | R0402 | RESISTOR_R0402_13K | 13K | IC | 1 | R3411 | | R0402 | RESISTOR_R0402_49.9R | 49.9R | IC | 2 | R3412; R3413 | | R0603 | RESISTOR_R0603_0.1R | 0.1R | IC | 1 | R3414 |
附件: 原理图和pcb文件 , W* Y, E1 C' d. F
* c: F/ J0 `+ [4 i# \1 e" U
