PC2-6400内存条(8片DDR2+金手指)pcb文件
: l" O5 J: I' }% f( |& C: F0 L$ e% @/ D8 E- y. M( i
; N5 K) d9 M( t \7 s9 A; x- X B文件描述: $ v' c. W5 `* ^" [! j7 B1 N
1. 作品用途:PC2-6400内存条 3. 层数:6层 4. 用到的主要芯片:8片DDR2+金手指 5. PCB尺寸:133.35*30 mm $ `+ T7 W, p" k" | q
( e5 C( r. ?" R2 a3 N" j7 F作品截图如下: ! F$ V0 a4 d+ q# R. }' b
顶层截图: 0 w$ u' B# H& D2 ]9 {
/ F) N. W! P; r, S2 I底层截图: : ?, Z1 P& b3 H' [; E
5 |/ {, H% H5 M4 s1 t* ^& s. s- ?. V. z* k
9 S2 D) k2 g1 M, F全层截图: 1 @/ @9 }; s( h1 y; `) I; a2 k! W/ L0 e7 {+ U# S! L8 {
& r1 |+ q1 L8 S1 G7 C; q6 w
3 b1 [( p4 [9 f ~+ h- H' a6 Q" ~1 m& ?( T2 U2 d7 a( Y
3 Q1 w% v# w: f' J! N; K$ s
BOM: | Bill of Material Report (Condensed) | | SYM_NAME | COMP_DEVICE_TYPE | COMP_VALUE | COMP_CLASS | QUANTITY | REFDES | | 名称 | 类型 | 属性 | 类别 | 数量 | 位号 | | CONN_240DIMMDDR | 240DDR2_INTEL-CONN_240DIMMDDR | | IC | 1 | J1 | | CRA0805 | 8PORT_RES-22OHM,CRA0805-CRA0805 | | DISCRETE | 24 | RN1; RN2; RN3; RN4; RN5; RN6; RN11; RN12; RN13; RN14; RN15; RN16; RN17; RN18; RN19; RN20; RN21; RN22; RN28; RN29; RN30; RN31; RN32; RN33 | | CRA0805 | 8PORT_RES-3OHM,CRA0805-CRA0805 | | DISCRETE | 5 | RN9; RN10; RN23; RN24; RN25 | | FBGA96_12X21 | DDR2_96B_X8-BASE-FBGA96_12X21 | | IC | 16 | U1; U2; U3; U4; U5; U6; U7; U8; U10; U11; U12; U13; U14; U15; U16; U17 | | SMC0402 | CAPACITOR-100NF,SMC0402-SMC0402 | | DISCRETE | 76 | C19; C20; C21; C22; C23; C26; C27; C28; C29; C30; C31; C32; C33; C34; C35; C36; C37; C38; C39; C43; C44; C45; C46; C47; C48; C49; C50; C51; C53; C54; C55; C57; C60; C61; C63; C64; C84; C85; C86; C87; C88; C91; C92; C93; C94; C95; C96; C97; C98; C99; C100; C101; C102; C103; C106; C107; C108; C109; C110; C111; C112; C113; C114; C115; C116; C118; C119; C122; C123; C125; C126; C127; C129; C130; C300; C301 | | SMC0402 | CAPACITOR-2PF,SMC0402-SMC0402 | | DISCRETE | 1 | C40 | | SMC0402 | CAPACITOR-24PF,SMC0402-SMC0402 | | DISCRETE | 6 | C56; C58; C59; C120; C121; C124 | | SMC0805 | CAPACITOR-2.2UF,SMC0805-SMC0805 | | DISCRETE | 6 | C52; C62; C117; C128; C200; C201 | | SMR0402 | RESISTOR-200OHM,SMR0402-SMR0402 | | DISCRETE | 9 | R1; R2; R3; R6; R7; R8; R9; R10; R11 | | SMR0402 | RESISTOR-3OHM,SMR0402-SMR0402 | | DISCRETE | 4 | R4; R5; R12; R13 | | SSOP8_65MM | 24LCS52-SSOP8_65MM | | IC | 1 | U19 | | TESTPOINT_18 | TEST_POINT-TESTPOINT_18 | | IC | 3 | TP11; TP12; TP13 | | TESTPOINT_24 | TEST_POINT-TESTPOINT_24 | | IC | 14 | TP1; TP2; TP3; TP4; TP5; TP6; TP7; TP8; TP9; TP10; TP14; TP15; TP16; TP17 |
附件: PCB文件如下: ) I" ^' I1 L5 P- Q4 H
