查看: 2346|回复: 2
怎样用skill获得每个pin的网络名呢?
发表于 2009-9-7 08:50 | 只看该作者 回帖奖励 |正序浏览 |阅读模式
不知道这个怎么实现...要能把pin和网络名对应上..
 楼主| 发表于 2009-9-7 10:14 | 只看该作者
多谢楼上,这样也应该够用了!!
发表于 2009-9-7 10:08 | 只看该作者
1# btgcht
我這個模組是輸入Net name 得到該Net對應的pin
procedure( cGetRefnum_simplenet(Netname)
prog( ()
  ;;輸入參數: Net name => Output與這條Net有關的Pin接點的List. Ex:Input:"MA_MD0" Output"U10.AC4" "DIMM1.5" "DIMM2.5")
  ;;運作方式: 撈Net的DBID, Branch的DBID, Children的DBID
  DBID_Net = nil
  refTable=makeTable("refTable" nil)
      refnumTable=makeTable("refnumTable" nil)
      DBID_Net = car(axlSelectByName("NET" list(Netname)))
      brnch_dbids = DBID_Net->branches         ;Get the DBIDs of "branches" of the Net
      ;println(brnch_dbids)
      cont=length(brnch_dbids)
      foreach(elm brnch_dbids
       ;println(elm->children)
       foreach(elmkid elm->children
           op = elmkid->objType       ;Get the object Type of each "children"
           when(op == "pin"              ;The condition of the chldren's objType is "IN"
                ref = elmkid->component->name       ;*****Get the reference name of the component which is connected to the net*****
                num = elmkid->number                ;*****Get the pin number which is connected to the Net*****
                refnumTable[Netname]=nconc(refnumTable[Netname] list(strcat(ref "." num)))
            );when
         );foreach
      );foreach
      ;println(refnumTable[Netname])
      return(refnumTable[Netname])
   );prog
);procedure
参与人数 1贡献 +2 收起 理由
btgcht + 2
GMT+8, 2026-4-18 23:16 , Processed in 0.109375 second(s), 27 queries , Gzip On.
