我在用pads2007自带的translator软件转protel99se的文件时,转出来后元器件的封装不对,如:在protel99se里面R0603的封装在pads2007里面变成了R0603/2,这是怎么回事呢?
) v6 t; k8 a+ x" g3 s# B下面是在转出来的警告:: [2 E0 k( y ^6 x4 o2 l
[W] Renamed pins with duplicate names: 2 in device SOT223 renamed 2/25
0 j% g' a, V3 b# d3 K[W] Renamed pins with duplicate names: 2 in device SOT223 renamed 2/26
2 M. n# r* j- @7 V[W] Renamed symbols with the same pattern: R0805 renamed R0805/4# \ {7 e& } E
[W] Renamed symbols with the same pattern: CAP0.7 renamed CAP0.7/2
2 {8 |; o6 T9 V+ z[W] Renamed symbols with the same pattern: CAP0.4 renamed CAP0.4/2
7 O4 Q, D$ u. ]: a8 r* p0 P[W] Renamed symbols with the same pattern: C0603 renamed C0603/2' p4 k8 C* d* h2 { D1 m( u
[W] Renamed symbols with the same pattern: CAP0.8 renamed CAP0.8/2
3 A& T/ ~ t3 R8 l- |[W] Renamed symbols with the same pattern: CAP0.8 renamed CAP0.8/3% E9 R+ w1 ?; i- E/ L* P8 N
[W] Renamed symbols with the same pattern: R0603 renamed R0603/42 ~/ F" ~( X5 L$ G5 X7 ?
[W] Renamed symbols with the same pattern: SOT223 renamed SOT223/27 |+ @8 {- I s
[W] Renamed symbols with the same pattern: C0603 renamed C0603/3
$ n# \+ C Q4 G/ f7 C" `[W] Renamed symbols with the same pattern: CAP0.8 renamed CAP0.8/4
' E8 j7 V6 E+ }- t9 f c+ _( C. q8 D/ m( ^0 ^2 T: E
等等.是不是软件的问题呢?附件为protel中Examples里面的pcb文件,转出来后封装有些就不对了,有知道的吗?
5 @4 J6 t, G, Y, Y5 G1 ] |
