给我的Mac安装 genymotion。遇到关于安装Genymotion-ARM-Translation_v1.1.zip,插件的问题。
+ j2 R& ~$ }+ }1 [6 C& M( z* Y然后按照方法直接拖进去,但是我的Genymotion-ARM-Translation_v1.1.zip被当做文件复制到Sdcart/download目录下
: t) Q, e& t& \/ }: [* d; f# `于是按照百度搜查的 要手动adb shell 我也成功了2 h: }% k5 V3 k! B& y
解决办法:) |2 n8 U) E* p# O5 W. F5 a# W! @
直接自己手动flash 这个archive.8 t6 _8 W5 Q- B( M0 l8 Q3 V. N
1. adb shell
8 ~. h; g. X% i( A2. cd /sdcard/Download/
) B6 p& z: v3 G8 n- [3. sh /system/bin/flash-archive.sh /sdcard/Download/Genymotion-ARM-Translation_v1.1.zip( R4 g+ _) [% ]4 f1 e5 a2 M" G
命令行:$ Q+ N" l2 w* W% u& H, v! F
.................' s: |+ d' u+ n/ `& H9 _
inflating: Genymotion-ARM-Translation_v1/system/lib/libhoudini.so
2 s3 Y& H$ h5 g. V, d6 rinflating: __MACOSX/Genymotion-ARM-Translation_v1/system/lib/._libhoudini.so% S9 \6 j8 ^8 S7 r
inflating: __MACOSX/Genymotion-ARM-Translation_v1/system/._lib5 l. m3 z8 r& ^0 s
inflating: __MACOSX/Genymotion-ARM-Translation_v1/._system
3 j+ V& Q6 \; \% binflating: __MACOSX/._Genymotion-ARM-Translation_v17 d# W' |( g9 b# J! k/ ^
[flash_archive] Remount /system/ in rw
# a' c1 \/ L z! s- A( D[flash_archive] Start file install$ B$ e6 p% \3 Q
find: system/: No such file or directory; b" F- O N& u7 h' O! R; {( ]5 F5 Y: y
[flash_archive] Remount /system/ in ro$ o3 C% N$ @% n& H1 y) l/ L
[flash_archive] Delete tmp directory9 E: }! x! q5 Y3 j* {
rm failed for /data/local/tmp/sanitized.zip, No such file or directory. d+ b/ J; G. s! c9 F
[flash_archive] Done successfully !/ G* b! O; j2 w% K0 H5 ?1 M G1 s
{Result:OK};) y( ], f% {9 s+ g9 L" x
这样子执行成功之后,运行带.so文件的依然报错:
4 \2 n8 Y, r0 c/ s RFailure [INSTALL_FAILED_CPU_ABI_INCOMPATIBLE]
( r' P {0 S7 U5 x, Z/ F7 L: u
5 S4 H, x X2 e$ _$ S8 C5 M) B' F* @) ~ n
) h) Q$ [! {2 y7 {/ [! b$ T2 V3 F# P @. @
( h- k+ B, D- i) y |
