ZMM5V1+HEADER16+HDR2X13+MP2451DT东软集中器载波模块+原理图+PCB作品文件分享。; `$ `! i2 O+ m( s7 t; X4 }: I
层数:2层
$ B! e1 e. m3 B5 a用途:载波模块
5 P6 F# ^" e9 _' N作品截图:
7 B3 i9 @) h* u3 w$ q0 k4 D* Z' v+ I4 @0 o
: x0 e( o: Q" ?
0 N9 U, \5 l0 N/ q# S
附件:
$ e8 F( V6 h1 T, L" R! \( n5 W& u
0 t& j, N d1 c/ v0 b5 V. WBOM:
7 K# Z* S* p1 S( @, N4 A
/ l; v0 i: O! s0 l3 GComment | Quantity | Footprint | | 0.15uF/305VAC | 15 | RAD0.6 | | 51pF | 30 | C0603 | | 22pF | 30 | C0603 | | 150pF | 15 | C0603 | | 3.3nF | 30 | C0603 | | 120pF | 40 | C0603 | | 56nF | 15 | C0805 | | 15pF | 15 | C0603 | | 1nF | 55 | C0603 | | 100nF | 105 | C0603 | | 1uF | 15 | C0603 | | 10nF | 15 | C0603 | | 560pF | 30 | C0603 | | 220nF | 15 | C0603 | | 10uF/50V | 15 | RB2/5MM | | LL4148 | 75 | LL-34 | | M7-4007 | 15 | D1206-1 | | K1010B | 15 | DIP4 | | P6KE12CA | 15 | TVS0.15 | | P6KE33CA | 5 | TVS0.15 | | 20MHz-3P | 5 | XTAL1-3 | | RED LED | 10 | LED0805 | | GREEN LED | 20 | LED0805 | | 4.7mH/50mA | 30 | AXIAL0.15-4.7 | | 100uH/40mA | 15 | L_100UH | | 33uH/360mA | 5 | L1210 | | WPM3407-3/TR | 15 | SOT23-MOS | | ESPA16 | 5 | QFN-20-ES | | 2SC2412KT146R | 30 | SOT-346 | | 1K | 15 | R0805 | | 39K | 15 | R0603 | | 10K | 60 | R0603 | | 1K | 90 | R0603 | | 100K | 25 | R0603 | | 33R/1W | 15 | RAD0.15 | | 20K | 15 | R0603 | | 2.2K | 20 | R0603 | | 5R1 | 15 | R0603 | | 51R | 15 | R0603 | | 220R | 15 | R0603 | | 6.8K | 5 | R0603 | | 3.3K | 5 | R0603 | | 680K | 15 | R0603 | | 470K | 15 | R0603 | | 47K | 30 | R0603 | | 5.1K | 10 | R0603 | | 100R | 5 | R0603 | | 510K | 30 | 1206 | | 5 | 08050 | | CiHuan-1mH 1:1 | 15 | CIHUAN | | MP2451DT | 5 | SOT23-6 | | RP170N331D | 5 | SOT23-5 | | 1N5819 | 5 | DIODE0.2 | | PLCI38-IV | 15 | SOP-28 | | CON4*2-380 | 5 | CON2X4_3 | | CON5 | 15 | SOP5 | | HDR2X13 | 5 | CON13*2 | | HEADER16 | 5 | RT_RTIAL | | ZMM5V1 | 30 | LL-34 |
) i; s. u) l! K* }, u2 @$ m* u, A# A
