0 z- Q$ _0 H* x- c! i, c基于S3C2440的OV7670摄像头的裸机程序、、对了解OV7670的硬件编程可能有点用处哦。。特别是初学者+ W1 G* \0 i" u4 X3 L
/ W' M6 d) [) g! ^+ Jcamera_OV7670
7 P" b3 x8 N; }8 ]5 G .............\camera_OV7670.mcp
: E& ?% c- W3 U/ y% N0 \ .............\camera_OV7670_Data
" \+ t' x' y( L3 _; w7 { .............\..................\CWSettingsWindows.stg4 ~; J% F5 U7 c1 K/ o# L
.............\..................\Debug S9 _) g0 i0 K5 b5 E; @
.............\..................\DebugRel
( _) L" K/ Y" A8 C' l: x$ l7 E( N* x. V .............\..................\........\camera_OV7670.axf" P! _& _: ] l6 r
.............\..................\........\camera_OV7670.bin9 \+ I @" Z: z
.............\..................\........\ObjectCode5 ?- C% S( Y6 \0 O
.............\..................\........\..........\2440init.o
5 g( c M+ ~% u .............\..................\........\..........\2440lib.o2 _( O+ M( K" ^$ o( r" A4 i
.............\..................\........\..........\2440slib.o
# s6 t- l) }% X5 w4 \ .............\..................\........\..........\camif.o
% f7 {" w! w5 q4 { .............\..................\........\..........\camproset.o' I+ n/ c" p7 a4 w1 V4 Y8 t
.............\..................\........\..........\main.o
* Z# h+ O8 p; T4 M9 P+ M, P2 o& _$ | .............\..................\........\..........\mmu.o; y; }' Y+ F( Q0 }* P0 _& j) F
.............\..................\........\..........\nand.o
$ k% a( j1 N5 N# z2 S0 Y O. y9 R4 { .............\..................\........\..........\Test_OV7670.o
5 r% c2 c# { y .............\..................\........\..........\TFT_API.o6 `# n6 C1 D& y5 [( D' \
.............\..................\........\..........\TFT_Driver.o9 x; K/ N2 y( u- u8 U" B5 o7 y! C/ a6 O
.............\..................\........\..........\uart.o: Q! S( N4 T3 J0 E% L4 S
.............\..................\........\TargetDataWindows.tdt
2 U' r, o2 j( |; A0 x .............\..................\.....\TargetDataWindows.tdt
8 o3 I* L! }+ E1 v( ?% ~# a$ B: n% R .............\..................\Release9 m' ~7 Q8 ]0 Q" J9 Q; k" \( H
.............\..................\.......\TargetDataWindows.tdt" M; C8 @* X1 \7 t* `; W! p; E. r$ x
.............\main.c
& M6 ^/ s% _( K, x .............\Source7 ]9 S+ X: P9 w) c! M
.............\......\camdata.h- R8 T9 Z# L. v
.............\......\camdef.h
! x w& Y- s, ]7 U' M+ M# ]9 L6 \ .............\......\camera_sccb.c
$ i1 W3 o' w1 r: @* G .............\......\camera_sccb.h' p. n7 t5 R8 M5 ~) I$ ~# `
.............\......\camif.c
! x) W3 z0 H. W3 X .............\......\camif.h
: a1 ?5 p8 |. q5 H- s3 } .............\......\camproset.c' \' o7 ` E3 ~. t) _4 h! N" P- i
.............\......\camproset.h
$ p& J1 E+ n! {9 J$ n* D5 V .............\......\Test_OV7670.c) V) J$ D p& x
.............\......\Test_OV7670.h
% |$ @' D# A& i" C .............\system
) B! k7 W/ `8 D6 S; _1 Q8 k .............\......\inc: X. W. m7 I- z+ K9 l6 h0 M6 M2 d
.............\......\...\2440addr.h" m: ], @2 u8 p% H5 O
.............\......\...\2440addr.inc
1 {! R4 w6 A% y3 c! F .............\......\...\2440lib.h% n8 R1 K- I3 _4 G
.............\......\...\2440slib.h
5 }) r: k: I3 `5 X: {$ N .............\......\...\def.h
! f; o/ q* M8 N) x" ]2 @& o9 ^: ~ _ .............\......\...\MEMCfg.inc7 j1 }0 w7 H8 F/ y9 I/ B( P
.............\......\...\mmu.h0 [. p" a6 ?+ ~% Q9 b5 B
.............\......\...\nand.h
3 ~9 g# j1 h1 X8 d .............\......\...\Option.h/ B6 u* H" \+ u3 u- x% p* z) O2 p
.............\......\...\Option.inc
& c- w+ A4 o I0 l .............\......\...\uart.h3 g& \' ?, A1 r' x9 w, `, F9 t
.............\......\src
6 m4 u0 r# c( Y% i .............\......\...\2440init.s
8 B) z* d% d, C& n .............\......\...\2440lib.c* Z) V0 t& E9 F0 p# n8 ^ @; {
.............\......\...\2440slib.s4 }( s3 ^" ]2 Z, K
.............\......\...\mmu.c
: h! E/ l- M; b/ M3 }8 ?( x .............\......\...\nand.c
: d9 k. Z! x6 L1 B. g' n- B7 B- a .............\......\...\uart.c
8 m, B* n' U1 u* n% q. e7 ? .............\TFT+ I% C& u+ }3 ~9 b
.............\...\TFT_API.c
! C2 Y5 Y8 J0 |9 I2 w: L .............\...\TFT_API.h1 x8 t* ~: b: r, Z
.............\...\TFT_Config.h
4 _% s' O3 C8 m8 r .............\...\TFT_Driver.c( _. U( _( `4 |( _- J
.............\...\TFT_Driver.h | 5 f$ @: y; H" T/ g: p5 k1 H0 q
