a.c.or AC
9 T/ t) ?; g) K3 l" ^alternating current交流电6 j1 w) _# e6 R3 U( }) `$ T
& C5 R, p" E0 b- c1 g. P& V) t: U: G
ACEC
& ?, z# K7 F3 z3 e9 _advisory committee on electromagnetic compatibility电磁兼容顾问委员会 B& f8 ~/ p# q# {7 A3 D; J
6 \- \7 M0 w" b' u$ G: BADSL, X5 ]+ \, x; o0 M$ Q+ @7 r
asymmetric DSL非对称数字用户环路, g2 I4 v: w- @0 L
0 y* U$ H. ^5 O; |: h1 \! z o
AE ; m% o/ e7 |& ]( o6 w
auxiliary equipment辅助设备
! ]: l5 z9 o2 e2 P/ D5 G" ^
+ q% G" B2 d7 @AF ; S; p/ Z2 S* |$ _* q
audio frequency音频
! H2 R# `/ x: C$ ]# \! t. k; ?/ ^" V7 R8 S9 F
AM 1 G% l- j' o4 c$ ^0 X
amplitude modulation调幅
- e& a% K) j% @6 A/ H0 T7 _1 y9 }8 C) N1 K2 p# S( c7 [ |
AN % r8 C) ], f# x: I( T7 ^
access network接入网
9 _5 e7 S1 Z( D5 ` Z0 Y% m& l, E$ p; G4 e e. p9 e0 b: O
ANE + K, B) e# V8 ~8 p
access network equipment 接入网设备 5 ]8 L5 c" x Q# R3 f
% `" H0 u; f' d5 B% x a" I
CDMA
; o) s6 j# N6 f: W+ \$ kcode division multiple access码分多址8 L a. I7 d1 K4 h
8 s, _8 f |; r' P5 d7 P7 M
CDN 8 K9 T/ t4 E' o5 i
coupling/decoupling network 耦合/去耦网络9 ]# A. D* t* b/ t
5 P% f7 x9 Y2 V0 yCIGRE 9 S/ @( D& m% A
international conference on large HV electric systems 国际大电网会议8 O- [5 y9 K5 x: W1 T) t7 e1 Y
7 c& h3 b/ {3 ~% ICISPR
9 u$ j% n6 D# Z4 \international special committee on radio inteRFerence 国际无线电干扰特别委员会
0 c2 \' H& l3 g$ u A- |: f" P6 `& p
7 `2 F* m2 q7 j' a9 \, F( p L0 |CPE 8 e8 @' @& P# t7 E- E
customer premises equipment 用户驻地设备4 r, i- ^: p- }$ @% P/ B
, \. D$ G: E9 e6 t5 tCRT
6 |' ]: w9 r$ k3 W2 v6 s8 }* Bcathode ray tube 阴极射线管
; ?6 y6 T: d/ z
' I, j, H! {; m& S2 Y* I& p, Pd.c.or DC
3 f- t9 D! h- N8 r- d2 Gdirect current 直流电. R; a# }, F0 Q8 b* _% Q# S9 h
% h9 D: G) a& A7 n% g) A, Z# q
dpf
! Z& `, J G* ?& q, Pdedicated power feed 专用供(馈)电* c1 G5 N* A7 ^. ~3 v% }. `+ W
$ R5 z/ U+ T) X, ` NDSL 4 W% L* Z4 |7 @5 |0 ?9 F- b
digital subscriber loop 数字用户环路
8 D9 z# w+ R, C/ r7 o. V2 c/ @! _ C) {- B
EFT/B
) P* [$ _) C) t( K& p9 a# ^' Belectrical fast transient /burst 电气快速瞬变/突发0 Y+ Y* f s2 m% k( P, v9 j8 k
# P- I! r( E# c. QEIRP ! T% T* u7 Q! V$ S7 p; d- ~9 ^: {
equivalent isotropically radiated power 等效全向辐射功率9 g7 j* A( b1 Z1 ~/ o
9 O' M( K3 i: B) A
EMC / K: y6 V2 W) t* O1 c- q
electromagnetic compatibility 电磁兼容性
$ `7 a- o$ c8 W6 X1 y3 I* ^; [7 X
emf
7 V* _0 |2 V6 b' G2 t2 k Delectro-morive force 电动势
+ b3 Z- H# [$ y( _ C# f
* C) z# {4 u' l. u5 K+ dEMF 0 o4 U' |6 f& E
electro-magnetic field 电磁场
4 F2 g! G& P1 Z8 A& W8 E- n- A2 L% y2 T2 F! t* M) Z' D
EPR
0 o, |6 u( q1 Y1 T! q6 C- jearth potential rise 地电位升高) v5 L' }3 _+ b5 A5 T
% }. x- ]& b0 H, I% v. j
ERP
- D5 t+ Z9 W4 k+ X4 {( ieffective radiated power 有效辐射功率
) n/ f) [2 P& ? k1 v! t, C% P0 c- N0 k2 ]% J A5 T) P
ESD ; T. L/ w3 k: \0 f, ?& s
electrostatic discharge 静电放电" k$ H2 a0 ^: m1 H7 i0 [# r3 D
! ^ }# |0 x: {) p5 BEUT
" J8 ?8 _+ ]! {* L' U$ |/ V4 z2 ^3 Uequipment under 受试设备& ^- _! e/ q# j. Q
2 B$ ^' `9 I2 l- ~1 K; x9 d$ y9 b
GDT & b9 t8 P0 X# v& P
gas discharge tube 气体放电管0 B! g3 o- C+ V# Q; {
" |, R: n0 B/ g( f8 N; y
GV 4 _$ @4 U- K8 H' i9 h0 ~
high voltage 高电压
+ ^+ W$ i7 f! s* c( U8 }* R' l1 v, z$ H' z& l2 p
ICNIRP
' `3 h4 T# C3 F( B6 finternational commission on non-ionizing radiation protection 国际非电离辐射保护委员会* W. q8 Y# ?/ J( \+ [" A
) @/ F$ k- G+ k* S; M1 aIEC 3 q! A- I, m' D* z
international electrotechnical commission 国际电工委员会) I# Z: m% Z4 P5 m* O1 O U
( \" ]( x* I8 q. B8 I/ XISDN ' e; P8 I! B6 b- L4 w
integrated services digital network 综合业务数字网2 `, I5 a& B" Q
' L1 d8 [% T( e, n7 \ISM
& u+ O( q8 D3 d& \; d; \) Aindustrial, scientific and medical (equipment) 工业的,科学的和医学的(设备)- V4 S7 Q+ f9 s+ p5 w! D7 z3 w
! a; Q# L, d% ~, o
ITE 2 Z1 g. |; ^+ g; Y
information technology fquipment 信息技术设备: }. O3 Q1 g9 g) e
: q8 d+ }; F s% c4 ZITU-T 0 T! I, b) X5 G- D: E
international telecommunication union-telecommunication standardization sector
7 h$ x- r4 z% I. R% H* C! r/ e国际电信联盟电信标准局; A+ f* |: g$ l' g6 o
& z) J( R" D1 t. I; I* tLCL
4 s/ Z; G0 p) K. ulongitudinal conversion loss 纵向转换损耗
. |9 j. n+ D: ]% K# k, v; {% }
3 j% U% n- ]. j* z& Y0 [" SLCTL
( L7 C6 I$ D% nlongitudinal conversion transfer loss 纵向转换传输损耗% R# ~; c9 m9 ?4 L
6 h8 D5 D( D6 d# H4 m. o
LE . y; o6 F9 ?' ^' X6 ~* w4 p
local exchange 本地交换/ y+ _, c3 O; o+ a; x1 |. O
0 _5 J) I1 t* P, }# x, hLEMP
- Q3 ]! Z* Z3 e( I& J) A6 ]lightning electromagnetic pulse 雷电电磁脉冲. ~1 c A- Z$ F( @5 h, R& O ~
: `% ~6 Y+ a% { y4 y" ?* |. [LI + S' s8 v9 w% b$ J0 _, l
line interface 线路接口
; w6 P( C" T4 R9 }" [$ ^% @! _: k/ e. F: B) N
LPS & G: {9 F Z' u- o" E" w
lightning protection system 雷电保护系统% k4 `' O$ z. k3 R& K% @( V, n
S" F' F! X) U' T; JLPZS ; N- _/ v3 U% w4 G1 v1 {
lightning protection zone 雷电保护区+ l$ a4 U/ H! g& F- {
H8 J: n, _; m! n7 |8 YLT
+ D: @$ \( |; R0 B: i; V8 Jline termination 线路终端- S7 b; T: q' g
+ ], ^' h) [, G/ W$ fMDF ) l* }% c+ \' J3 H; G8 p# P& t
main distribution frame 总配线架0 T5 Q$ {" e" w5 t5 w O/ J
7 k7 y! `3 z5 ~6 @( J: B& vMOV / }1 T H& S! i/ g& R4 Z
metal-oxide varistor 金属氧化压敏电阻
7 h b2 Q) n" x) e) n- `
9 t* B' a0 G6 [- q3 e* m7 Y+ zn.a.
% ` \7 E8 H9 J5 E4 R; J5 Ynot applicable 不可用
# \4 `* }# J: E1 L$ |+ a3 l9 ?& g0 S" d$ [# c( B' p8 [
NT 9 |7 d* S7 m1 j* E7 |% p0 p
network termination 网络终端" W/ {# ], ^" x! O. x# o. z1 n
3 k, p+ l4 b8 d" q; oOATS * d& K. J& [5 a& p: V% H& t
open area test site 开阔试验场7 d+ e, |% Y& U- `/ [5 U
" R+ }4 c; E" N0 j
o/c 9 n( V- J1 ?+ K& P$ d
open circuit 开放电路
; B; s: t1 g3 m8 _
: j( a+ M. W% Z* o1 f! v, f+ Spfv & X( P2 T/ C& p
power feeding voltage 供电电压% ]) a! g2 [/ u9 ~+ a
: q5 z5 |+ q8 R, o* @" Y
PNI
, v8 r, I- J' P! z- Vpublic network interface 公用网接口
/ e: g, Y: K( u3 }: d3 L1 s: n% q6 |( u6 j |( h
PRBS 4 f: A k" \3 F' K- N0 L
pseudo random bit sequence 伪随机比特序列
6 r" Z( G& o: p& m
$ [, r7 B! `9 P$ @PSTN ( y) r' i: K6 J u
public switched telephone network 公用交换电话网
7 l1 U% C- e) l% c+ s8 R- s2 z
& k$ ^. R1 j- q8 c' N! CPTC
) W4 E- s2 g& Ppositive temperature coefficient(resistor) 正温度系数
& n! Y5 H* a# E0 E5 T0 n
& B, q; u* r3 hRF 3 T% L/ h% r: Y) s6 D+ Q, j: @9 q9 ?
radio frequency 无线电频率" @: i2 x" _+ L; V
3 t* o2 f3 A( wRFI
: i3 S$ n5 |" B8 F" S% Y) Aradio frequency interference 射频接口 O i0 A9 u1 _ X+ ~' R
9 D- |: }. E5 w* nRFT 7 c; G# _6 [ V) _8 [1 ^2 r! R
remote feeding telecommunications circuit 远供通信电路
. s6 t! O0 V5 R0 Q# z+ X V. d+ ?1 @! S9 B( R$ D1 a! @
RFT-G
, l% f7 N; c( m" o) M( |remote feeding telecommunications circuit-current limited 远供通信电路-限电流
* D* L! T) P8 {7 n
* o0 {: A) C' y- e, o7 r- `RFT-V + g# g; B) H1 u' b* H
remote feeding telecommunications circuit-voltage limited 远供通信电路-限电压
' ?9 h6 }! q" |* M. y/ e& R8 w' E5 Y" S7 r e+ p
RSE 2 Z! Y1 \. z* w6 P2 E$ T% E: [
remote switching fquipment 远端交换设备
0 f9 u; R" R: p8 E1 B% t: A
/ s6 P; f' f1 h b) |1 bSA
: J5 e# }4 S, E aspecific absorption 比吸收能
, U3 E+ y1 N8 m% I7 l2 {; ]4 g, Y+ n9 j, w4 w% V5 f! _8 h8 ]
SA - q' J0 n* E; u8 B, w3 ~
semi-conductor arrester 半导体避雷器
, |9 ^# [: r2 _/ ?
0 N3 E. D( m @SAA ; `. C2 P( _* M! o
semi-conductor arrester assembly 半导体避雷器组件
6 Z" r( g( I4 I5 n+ S
" P- {" P* H1 _6 VSAR / u7 w( M6 D$ @7 v3 a
specific absorption rate 吸收率9 y( E. R2 S' R( y0 h; F, _1 D( U
7 ~' q6 ~2 r8 wSAP
6 J) O" [" q! g% p! o0 j+ p7 p: L- n2 @specific absorption power 吸收功率& w2 |9 ]" H( T Q' B1 N& g: {# B% D: Z
# N, {( R0 q0 _, L/ @, q
SELV ; Q- r6 H+ P( q
safety extra low voltage 安全超低电压- X! b) O9 v( V# i1 K
/ {* e; e' o' r$ A! U. e$ ZSLIC
( i: V3 `& E8 k; Qsubscriber line interface circuit 用户线路接口电路
+ u9 ~4 P( d; U6 z
3 e- D* S3 ^" HSPD
$ w" E/ |( R) `surge protective device 浪涌保护元件3 L% @8 u8 ?" }5 ?9 u1 M
_) N5 `/ V" d! q' c& s8 TSPL 3 Q0 b' n) [$ S( { c, H
sound pressure level 声压级 M% Q6 V0 V* x
- p, o1 h- {6 c; b5 U9 W' t. m9 GSSA 3 V! Q' d6 _/ M7 [/ p6 X
solid state arrester 固体避雷器- V+ k3 F' a' u( D; _
' r" k! f6 O2 d# x( a
TCE $ j- g% q5 H- i6 q6 K+ U! t. x* B
telecommunication centre equip电信中心设备0 ]+ k$ y/ L3 J
3 x) J. ~: g2 C; o6 l
TDMA
" ~- r0 D% l2 x- f [time division multiple access 时分多址9 P; D1 R) n. w
4 ^2 m3 j* e1 C5 D$ `+ G
TN ( ?, W8 C3 s1 {5 t& W
trunk network 干线网) Q) c0 m$ `8 F# n6 g: y0 S
; [* E1 S( b7 mTNV
4 A& |' ]. _/ h6 V# U2 L8 ?telecommunication network voltage 电信网电压' K7 ^+ p; s5 W% O6 k! B
) P+ ?7 m5 W5 a* Q4 g* g
RSD
3 b$ S- C; [* t- m- x: t8 }3 X) ^universal serial bus 通用串联总线
g, d+ a% }; g5 P$ E, S% B" T9 C, G6 v3 S
RPS
' ?- w. _2 |7 S. d! Uuninterruptible power supply 不间断电源1 H. X% H6 O4 W8 z( h
: u& ]) G& W' } g
VDSL + a# ^: G# ^4 b P0 |
very high speed DSL 调整用户数字环路* a# G. G9 P; ~% }* b% O7 z3 k% y
+ Y8 n. T7 k5 C% n! J5 Q
VDU
+ M5 j! j o" W bvisual display unit 视频显示单元
8 P. Z7 h$ O6 { o0 v9 |
2 R# ~* w" l. \2 i: FUIC
2 }$ [1 G, `8 {2 S O; S" l# [international union of railway 国际铁路联盟8 k# j% d7 }9 q; F1 @( [8 \
o) w. C% g- Y% G, Q; AxDSL
3 H& R. O- E, q7 w6 Odigital subscriber loop x数字用户环路
6 V* L# {7 v! J: l; z: j% _. I |
