This Getting Started guide is written for HFSS users who are using the Floquet port feature in version 11 for the first time. This guide leads you step-by-step through creating,solving, and analyzing the results of models that use a Floquet port. 1. Introduction8 M9 `; r! D7 n, t& h4 N E* k
Floquet Ports in HFSS . . . . . . . . . . . . . . . . . . . . 1-28 b$ l( u. s1 V" O8 k6 {+ a! _
2. Antenna Array
! E' i$ k4 ^: P: V; G% dArray antenna tutorial example . . . . . . . . . . . . . 2-2
4 _# J) i, y; b0 mCreate the Unit Cell Model . . . . . . . . . . . . . . . . . 2-4
- [: V% T) m7 v! [* K& rAssign the Master and Slave Boundaries . . . . . 2-5
' [8 P, g4 c" g% k, C2 q3 M" AAssign the Wave Port . . . . . . . . . . . . . . . . . . . 2-6
( T$ i s# n8 a4 M# R! g9 F3 n# `Assign the Floquet Port . . . . . . . . . . . . . . . . . . . 2-8
. |5 x+ G0 ^: k! Y7 I0 I: z7 Z% xCreate the Project Variables . . . . . . . . . . . . . . 2-10
% p) E/ x8 e$ a1 YSetup the Analysis . . . . . . . . . . . . . . . . . . . . . . . 2-112 [; F$ U/ l l" u, k
Run Analysis and View Results . . . . . . . . . . . . . 2-127 M. `: Y, c- Q6 z7 I# D
Parametric Sweep of Scan Angle . . . . . . . . . . . 2-13" F: U, P3 j& u/ v7 z
Prepare the Modes for the Parametric Sweep 2-14
& v c/ L$ r7 p. I cViewing the Results of the Parametric Sweep 2-17
$ o1 i$ x& r* L; k3. Frequency Selective SuRFace Model
( k3 W' L8 T/ [6 zFrequency Selective Surface Example . . . . . . . 3-20 |' Q D: I' ^ J! B. z8 k. [
Create the Unit Cell Model . . . . . . . . . . . . . . . . . 3-4) l, B# r( g5 O1 m/ E
Create the Rhombic Object . . . . . . . . . . . . . . . 3-4
* v/ B! f5 j( E$ F; j8 J7 mCreate the Aperture Object . . . . . . . . . . . . . . . 3-5
" i2 h3 ?* C- u: |! C8 f" JMove the Aperture to the Rhomboid . . . . . . . . 3-6
3 \5 E' k# z" h4 B ?- Q pAssign the Master and Slave Boundaries . . . . . 3-7
, d/ C* e3 i% J' a9 XAssign the Perfect E Boundary . . . . . . . . . . . . 3-9& f$ O( }1 }$ v* Q3 a+ w# \& E. c
Assign the Floquet Ports . . . . . . . . . . . . . . . . . 3-97 m/ A* ^. @# O3 q0 k2 A
Setup the Analysis . . . . . . . . . . . . . . . . . . . . . . . 3-11
; b' c" s% N9 o9 Z( Y+ b$ lSetup the Sweep . . . . . . . . . . . . . . . . . . . . . . . . 3-12
9 F/ d( M+ V. F) cViewing the Results . . . . . . . . . . . . . . . . . . . . . . 3-134 S1 i. M$ ?1 H
# D f* n" W( N) W; S4 _
0 G- G1 S& d. e3 `4 G+ A0 o
