本帖最后由 超級狗 于 2018-2-28 20:25 编辑 0 G3 K' k; \. X; w+ N
) L- l4 _7 A4 ?4 D6 j0 p- Y
The circuit uses BP01-type pressure sensor and amplifier MAX4472. BP01-type pressure sensor is specifically designed for the detection of blood pressure, and is mainly used for portable electronic device.It uses precision thick-film ceramic chip and nylon plastic packaging,it has the characteristics of a high linear, low noise and external stress of small;it uses the internal calibration and temperature compensation mode to improve the measurement accuracy, stability and repeatability, in the whole range,the precision is ± 1%, zero offset is not greater than ± 300μV. MAX4472 is the MAXIM company's a low power consumption chip which integrates four operational amplifiers.4 L3 ~" M$ w' g, m0 I- L$ H
* f/ ]' p: S }9 P爽乎?
4 {2 h5 n9 I9 s9 `$ d
6 v$ f( E5 b, [% |# z1 o- }1 Z * d6 k2 V3 k7 H) M9 S
