Cypress EZ-USB FX3S! l- q4 f7 E7 b( y' ^" l
- Integration: Full USB 3.0 Peripheral Controller with built-in PHY
- Storage Support: Support up to 2 memory cards- SD 3.0, eMMC 4.41, SDIO 3.0
- High-Performance: ARM9 with 512 kB RAM for data processing
- Connectivity: I2C, I2S, SPI and UART peripherals
- Flexibility: Configurable 16-bit 100 MHz GPIF II interface connects with any processor/sensor/ASIC/FPGA with parallel port
- Low Power: Low 1.2 V core and independent power domains
- Multitasking: 32 configurable endpoints
- Flexible Clock: Selectable XTAL input from 19.2, 26, 38.4 and 52 MHz
- Small Footprint: 10x10mm 121 ball 0.8mm pitch BGA package
0 [" D, y5 t" ? - T6 i! c: O' k+ R
/ s4 I6 l+ x: y; s: `6 u
