查看: 217|回复: 0
【Simon Haykin 2010 新书】Adaptive Signal Processing
发表于 2016-11-5 15:48 | 只看该作者 回帖奖励 |正序浏览 |阅读模式
Adaptive Signal Processing: Next Generation Solutions (Adaptive and Learning Systems for Signal Processing, Communications and Control Series)
4 M5 E7 i, y. B9 K  YBy Tülay Adali, Simon Haykin$ h, p! D  y8 E  c6 u) j7 G
; Z+ I6 l# `% M6 H  V, f
Publisher:   Wiley-IEEE Press
  g! G2 o( ~# u/ ]Number Of Pages:   407
! u6 l! a0 B4 H+ e0 ePublication Date:   2010-03-22
- P& }1 G% m. Q( _7 e, d! j: NISBN-10 / ASIN:   04701951773 d# G# c+ _$ T1 R' P5 q
ISBN-13 / EAN:   9780470195178
8 C2 ~- q3 f7 U1 R% [9 Z* ~& ~5 R" z; p( `  I  _
Product Description:
% h6 |8 X  T$ \2 s' QLeading experts present the latest research results in adaptive signal processing
! u& F0 T, g( r& iRecent developments in signal processing have made it clear that significant peRFormance gains can be achieved beyond those achievable using standard adaptive filtering approaches. Adaptive Signal Processing presents the next generation of algorithms that will produce these desired results, with an emphasis on important applications and theoretical advancements. This highly unique resource brings together leading authorities in the field writing on the key topics of significance, each at the cutting edge of its own area of specialty. It begins by addressing the problem of optimization in the complex domain, fully developing a framework that enables taking full advantage of the power of complex-valued processing. Then, the challenges of multichannel processing of complex-valued signals are explored. This comprehensive volume goes on to cover Turbo processing, tracking in the subspace domain, nonlinear sequential state estimation, and speech-bandwidth extension.
$ e2 Q# I- N, |% J# G, H5 @  ?Examines the seven most important topics in adaptive filtering that will define the next-generation adaptive filtering solutions$ @# T" x# j. r2 j
Introduces the powerful adaptive signal processing methods developed within the last ten years to account for the characteristics of real-life data: non-Gaussianity, non-circularity, non-stationarity, and non-linearity" v1 C. Y" N4 d% K+ [$ Y  [1 }
Features self-contained chapters, numerous examples to clarify concepts, and end-of-chapter problems to reinforce understanding of the material
# h' t" b( I+ _8 v' U1 Z3 y$ NContains contributions from acknowledged leaders in the field
- p) R+ q6 m" |1 z: U7 c! l- tIncludes a Solutions Manual for instructors
8 `1 B! V, t3 L" _( F- @Adaptive Signal Processing is an invaluable tool for graduate students, researchers, and practitioners working in the areas of signal processing, communications, controls, radar, sonar, and biomedical engineering." F# H  B+ S5 ?& |- b
Adaptive Signal Processing - Next Generation Solutions.rar
4.86 MB, 下载次数: 1, 下载积分: 威望 -5
GMT+8, 2025-11-24 05:41 , Processed in 0.156250 second(s), 28 queries , Gzip On.
