Nick Grattan Marshall Brain [size=-1]Publisher: Prentice Hall PTR First Edition October 20, 2000& r; g8 h, s# b0 b" o
ISBN: 0-13-025592-0, 544 pages[size=-1]Windows CE 3.0 Application Programming presents programming for Pocket PC, handheld PC, and embedded devices.
* h) |8 G' W$ E4 I0 lTopics include:
. t* A7 c9 h: ~8 FEnterprise computing including COM, DCOM, database access using ADOCE, and Microsoft Message Queue
3 X6 R7 f& X4 }: `Communications, including Internet Web access with HTTP, TCP/IP, sockets, serial communications, and desktop synchronization with ActiveSync 3.0
2 f8 K9 j2 A6 v- ?* x: hBuild and run applications in Visual C++ using Microsoft Foundation Classes
* Q$ T+ \2 ^& ?CD-ROM with eMbedded Visual C++ 3.0 and Pocket PC SDK
b- }. ]8 b, }- H0 HBeyond the user inteRFace to hard-core programming8 N, b$ L+ Z2 b( S* U
Full-scale networking and enterprise computing
2 K' X3 Q* ?: c) g/ @9 N. y4 vGlobal communications from Pocket PCs, R6 r8 }1 Z9 k5 X1 Q1 g5 `
All the new features of Windows CE 3.0( |0 m; O+ _+ ~$ w
Advanced techniques for serious Windows CE programmers7 I& |1 Y" @4 X2 r- _1 w( b$ C
Windows CE 3.0 Application Programming helps you get beyond user interface programming and discover the behind-the-scenes operating system facilities that will let you make the most of the new features in Windows CE 3.0. This hot technology lets you control Pocket PCs, handheld PCs, and the embedded devices in hundreds of commercial products. Learn the lean and mean techniques that keep your programs humming on portable devices with limited memory, and the key data storage methods that make them possible. Master the communications protocols that keep Windows CE devices in contact with desktop computers and the Internet.; [0 \4 C" j0 g! C
In addition: * h3 B( X7 T' a; j u8 u, B0 v
Build and run applications in Visual C++ 6.0 and eMbedded Visual C++ 3.0
M" {+ m+ X& e( p5 p' fUse the Windows CE API and Microsoft Foundation Classes ' [% J) l- n" j0 P. s
Communicate via HTTP, TCP/IP, sockets, remote access, and telephony! E4 t+ |) ~- q
Access standard Windows CE databases and Microsoft SQL Server for Windows CE
0 B6 }( O" |4 A4 y w; j: M& U: _Interface between desktop systems and Windows CE devices
7 _( C- N0 l6 R8 dWindows CE 3.0 Application Programming is for serious developers with real programming experience. Besides familiarity with Windows CE devices and general Windows API programming, a basic knowledge of C and C++ is needed to understand the code samples. + J+ }: e2 _3 R- j
The accompanying CD-ROM contains all the code examples from the book, as well as a fully searchable index of all the book’s examples, programs, and tutorials. The CD-ROM also contains a complete working copy of eMbedded Visual C++ 3.0 and Pocket PC SDK. |
