Undefined line width 0.0000
" `7 e* M0 U; ?0 j0 j Mirror code NONE+ S! c* [4 ~7 `
Rotate angle NONE+ l/ Y9 b4 B1 `
Offset x: 0.0000
7 E$ D5 G1 C; a Offset y: 0.0000- G, p# j5 \0 r: T: Z
Plot negative NO2 g& T9 m9 I" l; p
Suppress unconnected internal pads NO
1 I: I7 F' r% \ Draw holes only NO0 }2 m, M% r# b2 i# T5 ~
5 R' Q3 O2 c5 O3 p
WARNING: rectangle or unfilled shape composed 0 width line found at (-106.2482 34.6734)6 S3 G6 s9 _* A% V
... ignored.* q' r7 c% _8 A
* ~) a9 `5 G4 R WARNING: 0 width line found at (-106.2482 41.0234)7 X* h: o% B3 ]" I6 l
... ignored.# A5 Y6 G0 ]7 N) d4 ^
7 k7 {& f& v/ q6 X" E WARNING: Multiple 0 width lines; all will be treated the same as the first.$ T% k& w8 q$ f u5 c) r! T
... ignored.8 l6 U: E$ t2 T! |
z% N {* g6 H* r9 u V WARNING: text composed 0 width line found at (-94.8309 74.3609)9 ?5 ^) o$ U ~0 ^* t7 U% ?* B
... ignored.
1 t, C4 S3 h- I; y( I6 V) T
# n4 u8 I% y5 f! _8 u# `( ` WARNING: text having Multiple 0 width lines; all will be treated the same as the first.
; i, C8 u1 B8 z ... ignored.3 F8 {: o8 C3 V1 J1 E( y5 I
