查看: 1965|回复: 10
请教:Import Logic 报错
发表于 2016-3-4 09:49 | 只看该作者 回帖奖励 |正序浏览 |阅读模式
Import Logic  报错  什么问题?
4 B  L* g" m5 i8 r0 r# e( }% K9 X' Y: b7 U& f3 Y
#1   WARNING(SPMHNI-192): Device/Symbol check warning detected.
( p7 h8 I2 \& C8 `. t, u" H( R! u. Q
# t" T9 G6 Q: Q7 p& {  WWARNING(SPMHNI-194): Symbol 'BLANK' for device '2N6802_1_BLANK_SI2302DS_35-3390' not found in PSMPATH or must be "dbdoctor"ed.
  f# j" Y) a# n  R) b! j, M) s0 @1 ^9 h/ R9 w9 b3 w* D! f& P
. G% n. H1 |! @2 M, j  f1 D. y
; B8 @0 L) G9 x. F8 y3 h
    2024-2-21 15:59
  • 签到天数: 313 天
    [LV.8]以坛为家I
    发表于 2016-4-12 13:09 | 只看该作者
    应该是封装库中缺少R0402_CIR和0402_CIR两个封装的psm文件,注意,文件名要完全一样
    2024-1-3 15:02
  • 签到天数: 48 天
    [LV.5]常住居民I
    发表于 2016-4-12 12:47 | 只看该作者
    #1   WARNING(SPMHNI-192): Device/Symbol check warning detected. [help]
    - m1 E1 S6 ?9 n8 VWARNING(SPMHNI-194): Symbol 'R0402_CIR' used by RefDes RX151 for device 'RES_0402_200_0.063W_1%_SMD_V__1' not found in PSMPATH or must be "dbdoctor"ed.
    2 L# w( r- s) L+ W, |8 K#2   WARNING(SPMHNI-192): Device/Symbol check warning detected. [help]& c, [2 \1 w( x* X$ s  W4 N) N
    8 h' l6 [# |' E7 X+ A6 j4 I- ZWARNING(SPMHNI-194): Symbol 'R0402_CIR' used by RefDes RX167 for device 'RES_0402_200_0.063W_1%_SMD_V__2' not found in PSMPATH or must be "dbdoctor"ed.9 n+ D+ g! \' V! o8 @
    #23  WARNING(SPMHNI-192): Device/Symbol check warning detected. [help], U9 W  h5 R. T3 H2 X+ N; ^4 ]
    WARNING(SPMHNI-194): Symbol '0402_CIR' used by RefDes CX287 for device 'CAP_0402_0.1UF_16V_C0402_0.1UF_' not found in PSMPATH or must be "dbdoctor"ed.
    ( l8 N  U( f% H2 A5 O. _#24  WARNING(SPMHNI-192): Device/Symbol check warning detected. [help]
    6 b; W9 T) E* P2 i* R, `WARNING(SPMHNI-194): Symbol '0402_CIR' used by RefDes CX51 for device 'CAP_0402_0.01UF_16V_C0402_NI_10' not found in PSMPATH or must be "dbdoctor"ed.) @% {; N) B! b! d9 f8 n
    #25  WARNING(SPMHNI-192): Device/Symbol check warning detected. [help]. Z; ?! j4 x9 m: T3 P
    WARNING(SPMHNI-194): Symbol 'R0402_CIR' used by RefDes RX149 for device 'RES_0402_200_0.063W_1%_SMD_V_R0' not found in PSMPATH or must be "dbdoctor"ed.( G9 R3 G5 k2 J& j9 Z" d+ o4 E4 k
    , G. W" l8 G4 g0 p7 f( O! N# b7 x
    2024-1-3 15:02
  • 签到天数: 48 天
    [LV.5]常住居民I
    发表于 2016-4-12 12:13 | 只看该作者
    $ a( X. I8 A& {5 B4 n0 ~WARNING(SPMHNI-194): Symbol 'R0402_CIR' used by RefDes R1151 for device 'RES_0402_200_0.063W_1%_SMD_V__1' not found in PSMPATH or must be "dbdoctor"ed.6 `! |# O, h+ ^' u/ j% }# t* b
    / i$ O% G9 B- C——-————————
    ! p1 a- Q: b' @WARNING(SPMHNI-194): Symbol 'R0402_CIR' used by RefDes R1167 for device 'RES_0402_200_0.063W_1%_SMD_V__2' not found in PSMPATH or must be "dbdoctor"ed.
    " g' d( H! F- C9 V/ x2 C#23  WARNING(SPMHNI-192): Device/Symbol check warning detected. [help]% @& s, B2 M  H% _# s! c% ^
    WARNING(SPMHNI-194): Symbol '0402_CIR' used by RefDes C1287 for device 'CAP_0402_0.1UF_16V_C0402_0.1UF_' not found in PSMPATH or must be "dbdoctor"ed.
    6 L7 k) _$ n8 Z#24  WARNING(SPMHNI-192): Device/Symbol check warning detected. [help]
    ( T9 q6 b( ]3 c' RWARNING(SPMHNI-194): Symbol '0402_CIR' used by RefDes C151 for device 'CAP_0402_0.01UF_16V_C0402_NI_10' not found in PSMPATH or must be "dbdoctor"ed.
    0 w' {* Q: x+ B' m+ o#25  WARNING(SPMHNI-192): Device/Symbol check warning detected. [help]. Z/ k7 s* G( D& f3 W
    WARNING(SPMHNI-194): Symbol 'R0402_CIR' used by RefDes R1149 for device 'RES_0402_200_0.063W_1%_SMD_V_R0' not found in PSMPATH or must be "dbdoctor"ed.
    ! Q% u3 m' P5 ?% v; ^, L问一下,我所有0402的封装都有的。其他的0402阻容可以导入。仅上面25个。能导入,但是报错。
    0 k: F3 X# r7 Q7 w8 B$ M
    + j# O: C- }- q4 ~, G1 K* h
    发表于 2016-3-6 14:59 | 只看该作者
    是警告,不是报错
    2020-2-27 15:23
    发表于 2016-3-5 15:09 | 只看该作者
    库里面是不是没有这个封装
    发表于 2016-3-5 13:30 | 只看该作者
    dra psm pad 这一般的文件都需要有的。
    发表于 2016-3-4 15:25 | 只看该作者
    没有psm文件 或者psm文件路径不对
     楼主| 发表于 2016-3-4 10:28 | 只看该作者
    已解决   谢谢
    2020-1-14 15:00
  • 签到天数: 22 天
    [LV.4]偶尔看看III
    发表于 2016-3-4 10:06 | 只看该作者
    库里面是不是没有这个封装
    GMT+8, 2025-12-12 09:07 , Processed in 0.171875 second(s), 25 queries , Gzip On.
