查看: 20129|回复: 90
Hotfix_SPB16.60.061 (1.7G)包括最新破解程序!好不容易得到的资源!分享给大家!
发表于 2015-12-3 09:33 | 只看该作者 |只看大图 回帖奖励 |正序浏览 |阅读模式
! u& S/ ^% l; E补丁包更新列表!4 q7 d: H' \# k0 O4 K0 ?2 \
. A+ a) ]1 X8 [) z( h
DATE: 11-20-2015   HOTFIX VERSION: 061
  o& A$ {5 A1 J2 u9 U7 r===================================================================================================================================
3 j; y+ v' O2 b, v. L0 \CCRID   PRODUCT        PRODUCTLEVEL2   TITLE1 h* P# A* H- i  T' V' j$ v; `
; C. D4 Q3 O% T' S5 \  k5 U& V4 R1306441 APD            OTHER            The Minimum Shape Area option in Layer Compare uses an unspecified value
. h! x5 }  k- @- u9 L& _5 b& M' b1342644 ADW            COMPONENT_BROWSE Need directive or method for Component Browser to load a search criteria file upon init( P/ ]5 z* e- W2 [1 @/ s; l0 R+ u
1413248 concept_HDL    CORE             Import from another TDO project makes the block read-only, t! A- _( Z2 C% j) L6 X' l+ E
1417429 allegro_EDITOR INTERACTIV       Pick box only accepts 1 set of values. You need to close the box and reopen it to draw a rectangle6 i' }4 V) E# R% k! r$ s5 _  v! n
1417442 ALLEGRO_EDITOR INTERACTIV       Spin via stack and only part of the stack spins
% B. k9 y3 m* W8 ^$ P1 A' i6 T1 B1451977 CONCEPT_HDL    PDF              Origin of PDF mediabox not starting at (0,0) when PDF page_height and page_width are set
2 O. q$ y; L5 r0 \$ Y1 Y0 x1453527 ALLEGRO_EDITOR EDIT_ETCH        Contour route hugs the outer edge of the route keepin% ^% I& m! d4 P  @, K
1464948 PCB_LIBRARIAN  VERIFICATION     The errors/warnings do not match between the various tools
9 y$ _3 A& K) z7 M1467826 CONCEPT_HDL    PDF              PublishPDF from Console Window creates a long PDF filename- }- _7 A, C8 ^4 h2 h4 K
1478639 CAPTURE        OTHER            Capture Browse Nets window does not display all nets
$ P1 L( q5 \+ ~% K! y' s" U4 S& e1479177 SIP_LAYOUT     OTHER            Pin pair constraints do not appear to be supported in Sip Layout XL2 S2 _3 E% ?- M: i8 v  {
1479227 CONCEPT_HDL    CHECKPLUS        Custom DE-HDL Rules Checker rule flagging invalid voltage in hierarchy% P3 P+ Z" h. B
1479454 CONCEPT_HDL    OTHER            DE-HDL issue: locked DIFF_PAIR property is editable! E# z9 Q7 L) b  y- {3 m' V) m. x
1480293 CAPTURE        PROJECT_MANAGER  Capture hangs when searching for all nets) @2 s* _9 X4 |8 m, ^. f5 T& u# E
1483894 CONCEPT_HDL    CORE             Import Design hangs when pull-down arrow is clicked twice
/ i' B( r. y) w/ }1484781 CONCEPT_HDL    CORE             Three different Hierarchical Viewer issues
2 g8 N3 c% _0 r4 q: ^8 p# ^8 v1485059 PCB_LIBRARIAN  CORE             Part Developer pin attributes are randomly marked as read-only$ _( q6 D  o+ @) M# o
1485960 CONCEPT_HDL    CHECKPLUS        Custom DE-HDL Rules Checker rule is crashing the project, a, B& L, p% \. n
1486086 ALLEGRO_EDITOR ARTWORK          Cannot generate artwork./ t% v9 [4 h; |
1486834 CONSTRAINT_MGR OTHER            Restore the Status column in cmDiffUtility/ i% I. }! T9 X* g
1487085 CONCEPT_HDL    CONSTRAINT_MGR   Import Physical with the Constraints only option reports problems" C$ m/ U: p! u0 ~" N/ U, W
1487197 ALLEGRO_EDITOR DRC_CONSTR       Drill to Via DRCs are not being reported* m% j; ~9 b' s* a, f( K1 n9 @. E
1487265 CONCEPT_HDL    CORE             Replace command in Windows mode shows incorrect behavior4 \) b# g6 h+ @3 H' D( Y# ?' Y1 ?+ ~
1487733 CONSTRAINT_MGR OTHER            Running Export Physical - It takes over two hours to update the PCB Editor board9 S* J$ s& ^  q
1488758 CONCEPT_HDL    CONSTRAINT_MGR   CM_VALIDATION_ON_SAVE should be a hard stop on Constraint Manager  p+ F  f% G- t3 z. N" q, L
1490299 SCM            OTHER            ASA does not update revision properly
& v1 s- m8 u: T" o0 s7 V8 w1490744 ALLEGRO_EDITOR skill            axlChangeLine2Cline changes line to cline and places it on the TOP layer6 I" |( X: k/ f
1490924 F2B            PACKAGERXL       Save Design/Export Physical is resetting Via constraints
+ R: d+ ]9 a" T1491351 ALLEGRO_EDITOR OTHER            Create Detail for bond fingers on a custom layer not working
" g; d9 u' J7 v  z3 J& [" u1492595 ALLEGRO_EDITOR MANUFACT         Dimension character substitution help is wrong9 O) _: ?9 Q9 A/ y2 B3 R1 i) M$ b
1492777 ORBITIO        ALLEGRO_SIP_IF   OrbitIO import of customer mcm results in crash# g' w+ @  R4 H5 d9 P
1492901 CONCEPT_HDL    CORE             Cannot instantiate a multi-sections symbol (> 10 versions) in Design Entry HDL) u0 f/ O& C, {% l) m5 e3 D6 k+ A
1495621 ALLEGRO_EDITOR INTERFACES       Oval pins are placed with wrong orientation in IPC25816 D( a( N! v/ x3 i' t
1497597 ALLEGRO_EDITOR DATABASE         Show Element on pin shows wrong drill size' P2 r+ z1 a& l) r; N
1497956 CONCEPT_HDL    CORE             ADW Library Flow test schematic generation crashes DE-HDL while saving the design when using customer adw_conf_root- \  ]* I! S' g4 p% ?( A
1498234 ALLEGRO_EDITOR ARTWORK          PCB Editor fails to create artwork and no error is listed in the log file) V# u; }, x& Z$ u
1499363 CONCEPT_HDL    CORE             Custom attributes under variant management stopped working in Hotfix60+ K3 ?, b% _1 K! v% O  W- t
: @1 V  P* w- \, V# _3 m. n2 e5 o5 o: O( F
4 W' P+ n! }7 K1 Q
最新破解包列表!4 b( ^3 H( a9 p! \/ \0 Z, a
------------------------------------------------------------------------------* ?, m0 \: D2 K# J
SPB 16.6   UPDATED KITS RELEASE: ISR 16.60.061    EST.DATE:  11-20-20153 Z* ^# z+ ?: C! [7 G. _
------------------------------------------------------------------------------( L8 x: m2 P' N+ j# a$ ]% |% ?: u4 w
CompBrowser16.60-s037wint
  {  @9 ^5 i2 ]& p. a  \DSCoreUtils16.60-s077wint% o/ J: a% f1 q7 _6 E: C
DSCore16.60-s055wint/ w6 Q2 D8 S( x& U% ^3 i
DSSchgen16.60-s030wint2 E3 w$ O3 a0 f" S0 R) [
DSSetup16.60-s010wint* `# y  }9 f1 g, l8 J/ t
DSTableEditor16.60-s018wint3 W0 D. _" C9 U) r
DSTextEditor16.60-s015wint/ J6 ^7 p& u1 M: I
DSUICommonIndep16.60-s019
; z- P* a' S! j* r0 t1 t& R, MDSUICommon16.60-s026wint
, C2 ~! e( s7 k" O* J1 XDSUIUtils16.60-s037wint# P% h3 }+ U* h3 F& b' L
SPBIX06116.60-p002wint" t0 o& R1 J5 A/ M& a
adpPDFLibs16.60-s033wint3 x( `. T+ z2 T0 f2 i: v5 ?
advanPakgDsnr16.60-s129wint# V3 C. R& a" ^  r
adwLRM16.60-s033wint
( l; z$ Z9 B( }6 GadwSDM16.60-s044wint
. M8 ?6 S1 C* A. S) S, H+ AalgroAcad16.60-s122wint' ]/ v" u& i# ?+ T
algroArtwork16.60-s122wint" [( T8 W9 Y3 ^
algroAxl16.60-s048
9 M2 d& Z/ A7 D6 [& H& I/ k' J. DalgroBase16.60-s129wint+ X6 b& Q8 U/ ~4 \3 S7 O
algroCxt16.60-s0773 p, ]: \' y. i  n; U
algroDBTools16.60-s124wint3 w+ u6 f+ n0 t, H/ ]( R
algroDsign16.60-s122wint6 L/ M) q( Z: Z2 I: o# y0 @
algroF2B16.60-s122wint
' w4 e- H( v6 b" WalgroIDF16.60-s122wint
+ A# N9 m9 A0 d8 O1 ^; malgroIgin16.60-s122wint
7 {$ z( q. q8 Q9 H% ~0 y5 q/ walgroIgout16.60-s122wint
/ c( s- F2 p/ Z: j% HalgroIpc16.60-s122wint
5 ^- k7 b; q! }" W( UalgroMfg16.60-s122wint
" m+ W+ w/ E2 XalgroNetin16.60-s122wint
" l9 n( _' |4 |7 Z$ calgroPlace16.60-s122wint
( D/ |% Y* x2 d) e. valgroSgnse16.60-s122wint; S/ D- X( q; R  h/ ^
algroSpif16.60-s122wint; y' D- S, H: t
algroStrm16.60-s122wint
9 G! e8 o! t" C( U1 ?' e6 C9 u# KalgroTextIndep16.60-s0897 C( W, q5 z( l4 @! S
algroTransltr16.60-s121wint
+ s8 C7 |9 K4 U7 G  s* t3 ^4 PalgroUtlty16.60-s122wint( t; [' ~8 [. d
bom16.60-s030wint" {- r2 q: A: c) i/ o1 E3 I
capPSpLibMAB16.60-s018wint
, _4 x' `1 H1 H$ {capProg16.60-s044wint
0 D% V$ O( u* K& N; Acheckplus_exp16.60-s023wint1 \- l! ~# ~7 A0 A/ J  U
conceptNT16.60-s106wint
. ]: P; I; u5 z/ D3 EconcptSetup16.60-s015wint
' @3 T. u5 d7 {( t1 a. \0 \  \consMgr16.60-s104wint
6 T; }  ?8 _/ z' r6 A( edesSync16.60-s019wint
. }; r; ~9 E$ @; s. ueCWCore16.60-s009wint% n0 T6 _1 N$ \0 i
fetBase16.60-s034wint
1 f  h3 N0 K$ K. P9 u0 i( c7 f' z0 K  DicpCommon16.60-s122wint
5 @" ~, [$ e( E- w' f9 i( piff2hdl16.60-s010wint
- v5 ?5 D- L/ ~; s# _. Jlmancore16.60-s036wint
% G+ T) `% w# vlmanext16.60-s012wint3 J0 x) I2 \0 A- z3 k$ b
lman16.60-s023wint" k7 L! t( F) ~
productServer16.60-s084wint2 U& ^6 |, ^; R
projMgr16.60-s015wint$ r4 \; p2 z; ^2 e2 f9 L
pspProg16.60-s043wint8 S+ l# _9 f# V4 _6 @+ `
rfpcbfe16.60-s026wint; ~6 b4 W$ |3 ~3 \5 r2 g
rfsipPcellIndep16.60-s005
+ Q! @: B" s3 OsipDsnr16.60-s128wint
. {& b: t# X& N2 P# o  j2 EspbFPGAPlanner16.60-s065wint9 n  Q# T! w8 C# `4 C
specctraQuest16.60-s122wint
6 ^1 Y$ K8 x5 \5 y' VspgSignal16.60-s123wint- r2 P) W3 x5 ~( D: R
vedit16.60-s043wint
2 l0 y% E) S$ C1 O: f: y5 v( K
3 X- n" M$ _2 K. w补丁包种子!$ L6 h( ^8 B* B; E; `7 @3 ^
cadence.spb.orcad.16.60.061.hotfix.rar (17.88 KB, 下载次数: 1069)
1 I3 b# q' C; t+ y! P* X2 Y
9 @; o- ~* F) j/ C# N2 w
2 k" m, [: |+ |5 l' ~
4 D, J6 ~( h. G4 S
发表于 2015-12-3 15:25 | 只看该作者
XYX365 发表于 2015-12-3 13:04  \3 @# M1 f$ B+ F4 c6 B+ r4 j# g
下載的src.lic裡面沒有toolbox的license,必須加入我給的license,才可以使用.
" ?+ _. I& l: _
噢噢噢,发现了,Allegro_PCB_Productivity_TB 早就XX了,只是当时没有切换license的原因,没有用那个Performance L 模式,我说怎么回事。群众力量大哈
9 V% f1 I' M) x; S+ n$ h  f, v
 楼主| 发表于 2015-12-3 15:31 | 只看该作者
# Y8 y  U- s1 K4 S8 U下載的src.lic裡面沒有toolbox的license,必須加入我給的license,才可以使用.
: r8 O+ y+ c* U* i: _4 p& L 我加入了你的代码?问什么还是没有出现TB这个选项?补丁已经是最新的61号!
* M/ K8 F) Z- E' `: [& g
你再執行LicenseServerConfiguration.exe程式後,指定license.lic試試看.  详情 回复 发表于 2015-12-3 16:34
发表于 2015-12-3 16:34 | 只看该作者
crskynet008 发表于 2015-12-3 15:31
' o! E  b3 a, f8 a我加入了你的代码?问什么还是没有出现TB这个选项?补丁已经是最新的61号!
1 f2 \  h8 \1 v( F. P3 G3 {, p
; ]5 r* S) E' u+ P; V
    无聊
    2020-5-2 15:15
    91#
    发表于 2020-4-12 23:34 | 只看该作者
    新人報到,多多學習
    90#
    发表于 2020-2-12 22:53 | 只看该作者
    下载了 试试看了
    89#
    发表于 2019-9-1 18:32 | 只看该作者
    正式想要的,谢谢!!!!
    + `* ]) D/ n0 E/ s% q9 `
    * I/ [- C( N  E' D* s+ A
    88#
    发表于 2018-2-27 17:21 | 只看该作者
    感谢楼主分享!
    83#
    发表于 2017-6-23 11:33 | 只看该作者
    我就想要和谐文件
    82#
    发表于 2017-3-27 08:31 | 只看该作者
    这个版本好像还是低
    81#
    发表于 2017-3-27 08:25 | 只看该作者
    看看最新版本号到多少
    80#
    发表于 2017-3-27 08:19 | 只看该作者
    看看版本号
    79#
    发表于 2017-1-13 23:48 | 只看该作者
    大爱,感谢分享
    78#
    发表于 2017-1-10 11:22 | 只看该作者
    感谢楼主的分享,试试楼主说的license.lic
    GMT+8, 2025-11-22 23:13 , Processed in 0.171875 second(s), 30 queries , Gzip On.
