查看: 781|回复: 1
导出ODB++ 提示报警
发表于 2015-6-25 14:11 | 只看该作者 回帖奖励 |正序浏览 |阅读模式
WARNING: Since the starting (6.7322835,7.6968501)(mm) and the ending (6.7322831,7.6968504)(mm) coordinates of the arc are to close, it will be interpreted as an arc of 360 degrees per ODB++ standards and can potentially cause problems./ `0 a1 z2 @% s- \0 V  O
: c8 g. ?( [$ ~" q# b) ^
WARNING: Since the starting (1.3133467,3.0012447)(mm) and the ending (1.3133473,3.0012450)(mm) coordinates of the arc are to close, it will be interpreted as an arc of 360 degrees per ODB++ standards and can potentially cause problems.
2 k4 a& \' [/ R3 n% z! v* ~2 z7 Q4 l3 i0 G
报警提示的坐标都是在原点附近的,我尝试着把原点设置到-100,-100的位置,报警的坐标也就涨到10,10的样子,不像是PCB上面的线,不知道哪边设置有问题
6 |  m' A" j" s: `
GMT+8, 2025-11-22 15:44 , Processed in 0.140625 second(s), 24 queries , Gzip On.
