' L: l( r: l- `
不確定是不是這個問題造成的,但可以參考一下這些資料。( Q, x7 l4 ]# V
g5 u/ k, G- J- V; j: G% b% G下面這段話是肥死卡好(Freescale)的技術文檔節錄下來的,講得一針見血、但內容較雜( 不只討論這個問題),我給你另一篇 ATMEL 的技術文檔,它專門討論 MCU 的 Start-up Time,淺顯易懂、還有一些電路上的建議!
- c( v; N' D( ^5 V9 C3 ?3 ]' R5 t- |/ O9 N7 X7 U; J
Long Start-Up Time2 U2 `. P8 Z& r% R
A long start-up time is usually a more common problem with low-frequency crystals, since they tend to start much more slowly than high-frequency crystals. One of the causes of a long start-up time is weak loop gain. Oscillator start-up times will also be affected by the rise time of the power supply. When the power supply has a sharp rise time, the crystal will experience an energy impulse that will usually make it start faster than it would using a power supply with a slow rise time.
" n. d+ Q$ F9 k( b, Q! t% B" K; I8 {- B$ S
. J8 v" c* A4 o& a
