查看: 576|回复: 2
版主sort命令怎么用
发表于 2015-3-3 10:40 | 只看该作者 回帖奖励 |正序浏览 |阅读模式
sort -n +0.3 A.txt> AA.txt什么意思啊,请版本帮忙。谢谢!
 楼主| 发表于 2015-3-3 11:26 | 只看该作者
XYX365 发表于 2015-3-3 11:08
應該是在比較檔案a.txt裡面有0.3這個數值之後,的所有資料另存到aa.txt檔案裡面
不知道是不是你要的答案.
这个排列的功能呀
发表于 2015-3-3 11:08 | 只看该作者
應該是在排列檔案a.txt裡面每一行由小到大之後,在另存到aa.txt檔案裡面
不知道是不是你要的答案.
以下是參數說明:
Usage: sort [OPTION]... [FILE]...
Write sorted concatenation of all FILE(s) to standard output.
  +POS1 [-POS2]    start a key at POS1, end it *before* POS2 (obsolescent)
                     field numbers and character offsets are numbered
                     starting with zero (contrast with the -k option)
  -b               ignore leading blanks in sort fields or keys
  -c               check if given files already sorted, do not sort
  -d               consider only [a-zA-Z0-9 ] characters in keys
  -f               fold lower case to upper case characters in keys
  -g               compare according to general numerical value, imply -b
  -i               consider only [\040-\0176] characters in keys
  -k POS1[,POS2]   start a key at POS1, end it *at* POS2
                     starting with one (contrast with zero-based +POS form)
  -m               merge already sorted files, do not sort
  -M               compare (unknown) < `JAN' < ... < `DEC', imply -b
  -n               compare according to string numerical value, imply -b
  -o FILE          write result on FILE instead of standard output
  -r               reverse the result of comparisons
  -s               stabilize sort by disabling last resort comparison
  -t SEP           use SEParator instead of non- to whitespace transition
  -T DIRECTORY     use DIRECTORY for temporary files, not $TMPDIR or /tmp
  -u               with -c, check for strict ordering;
                   with -m, only output the first of an equal sequence
  -z               end lines with 0 byte, not newline, for find -print0
      --help       display this help and exit
      --version    output version information and exit
POS is F[.C][OPTS], where F is the field number and C the character position
in the field, both counted from one with -k, from zero with the obsolescent
form.  OPTS is made up of one or more of Mbdfinr; this effectively disables
global -Mbdfinr settings for that key.  If no key is given, use the entire
line as the key.  With no FILE, or when FILE is -, read standard input.
这个排列的功能呀  详情 回复 发表于 2015-3-3 11:26
GMT+8, 2025-11-22 16:15 , Processed in 0.140625 second(s), 25 queries , Gzip On.
