查看: 609|回复: 0
TimeQuest_User_Guide
发表于 2015-1-6 10:07 | 只看该作者 回帖奖励 |正序浏览 |阅读模式
ction 1: Getting Started
3 n0 d- m0 d$ q# {, ^: p" c; a; H' K5 U
          This first section is meant to get a user up and running as quickly as possible.  It touches
: ~9 w- J& x( U' E  S3 jon multiple topics that are detailed later, and is meant for application and a quick understanding.
& t0 M( o6 H, dThat being said, I think all users should look through this section and make sure they understand  8 o; b0 N: j! u$ t
it.  ) @" F( V2 g1 v: ]- d8 k" l
          The last portion of Getting Started covers analyzing results, which is an integral part of
4 A- f6 [1 t. r; `: ?entering constraints.  One can't enter core timing or I/O constraints without being able to read the  6 g& ?; b' }: h5 t4 L" c1 d7 e6 ^
analysis reports, so it is recommended to read that section in conjunction with the information at  & T6 x8 T" D7 _! s' M+ F9 m
the beginning.
3 }. f& `1 `8 h; m, G
  O6 c* N! N% B* h4 dQuartus Setup
" k6 O9 D$ }3 _4 G/ T" O; [          Within Quartus, there are a number of quick steps for setting up your design with  8 X& L, r2 c* @; \0 q2 G
TimeQuest.  These are accessed through the pull-down menu Assignments -> Settings:  1 f4 x+ N, [  q
- M& n. J' O1 C( a; I: o% L- b+ y+ R7 }+ ?+ f5 C
5 D( ~7 s$ _2 M6 |+ {! R' H
1)  Along the left panel, select Timing Analysis Settings and select the "Use TimeQuest…" radio
! e. ^' D' \& C4 Cbutton.  The Classic Timing Analyzer is the old timing analysis engine, which is not  1 C5 J, |" z0 ]% N$ S& d# O
recommended for any new designs or architectures, and will eventually become obsolete.
) o6 J3 y. w! t; ^& |6 ]' m2 l" ?9 @# g
2)  Select TimeQuest Timing Analyzer in the left panel.  The screenshot should look like below,  ; L& e$ O+ h7 t( c. ?# U6 [
whereby the user can add a new SDC file.  SDC stands for Synopsys Design Constraint, which is
% D; j9 s; o) mthe format TimeQuest uses, along with many other tools.  If no .sdc file exists, we will create it
; {* h- K& J( X3 J5 ~! ^& m. Din the next section.  Note that SDC files are analyzed in the order listed, top to bottom.  1 u3 r  Q) h- Z& F1 B
8 L/ s+ \" s2 Y& s7 L+ u/ [8 P* @7 f% I
TimeQuest_User_Guide.pdf
3.77 MB, 下载次数: 2, 下载积分: 威望 -5
GMT+8, 2025-11-22 18:15 , Processed in 0.156250 second(s), 28 queries , Gzip On.
