DATE: 10-10-2014 HOTFIX VERSION: 037
( L+ |, p& w% F2 O o$ u===================================================================================================================================
; n$ H- V1 h _. X5 @! h+ e* _4 OCCRID PRODUCT PRODUCTLEVEL2 TITLE9 [/ j6 N0 k* |6 _) q
===================================================================================================================================/ q: g( f) Y! H" o4 J( i
1314031 concept_HDL CORE GenView should automatically refresh the page where the block symbol has been instantiated- r' ?' [: m9 ]! b! R' M+ P
1318575 SIG_EXPLORER SIMULATION Display Parasitic on Wirebond (selecting the second one) crashes APD! d/ Z- l' r4 a3 L. N) K& r8 W
1319258 allegro_EDITOR INTERFACES Enhance IPC-2581 so that the rotation of pad shapes is defined at the LandPattern definition and Pin elements levels
, i. V* W' T* u J: I. i1320054 ALLEGRO_EDITOR INTERFACES IPC2581 Import Stackup
" }; }8 @" o. t1320467 CONCEPT_HDL CORE Incorrect directives in cds.cpm for nconcepthdl (cont.)
/ O3 e1 O0 r1 \+ {1320878 ALLEGRO_EDITOR EDIT_ETCH Allegro crash when using scribble
r: D! C6 N! u# w1321319 ALLEGRO_EDITOR INTERFACES Step Export has wrong size
9 |. ~+ p/ G" @1322394 CONCEPT_HDL OTHER Packager runs without errors even when the DEHDL schematic pages are corrupt.
* J& c6 |) l( J0 d1323892 CONCEPT_HDL CORE The SI_MODEL_PATH should not write to $HOME/pcbenv/env
% ]8 b, G8 i) P3 |- r8 @; y- g- ^1324438 SIP_LAYOUT EXPORT_DATA SiP Layout - netlist spreadsheet, Error on exporting a spreadsheet on design file
, p8 D8 ?1 A0 E( p1324533 F2B PACKAGERXL Export Physical fails - pxl.exe has stopped working# I; W( x- x3 C
! r9 ?/ x9 _- {& j暂时不提供文件下载 |
