查看: 1886|回复: 12
TI-AM335x核心板TL5209+SN74AUC1G74+LAN8710A+MT41K256M16HA+PCB设计作品文件
发表于 2019-9-4 15:00 | 只看该作者 |只看大图 回帖奖励 |正序浏览 |阅读模式
TI-AM335x核心板TL5209+SN74AUC1G74+LAN8710A+MT41K256M16HA+PCB设计作品文件2 p! F" ^8 E' N6 f' |: |  I
$ n$ @: W1 Z( y层数:6层
% U! o# v0 O4 m- G) U# p5 A用途:核心板. W7 u1 F: q1 G6 M4 C. T8 W, \
作品截图:
7 m+ A9 ?1 j( ~5 {) q) f, M
, z  D( t8 ]$ I# C5 u; G; S. S" H/ U1 [2 F+ E
附件:
% v* ~% B3 I7 d3 D  ]2 P# X
游客,如果您要查看本帖隐藏内容请回复
2 v7 T- l& {, N1 C1 w, R9 S
5 Z0 i! H- w* d2 x' ]6 Y
3 w2 P0 C* I$ u6 U
4 ^, x7 y* f2 }, Y& B
BOM:+ c9 h8 d% Q# D
0 X" L3 Q* p2 Y
SYM_NAMECOMP_DEVICE_TYPECOMP_VALUE
402RES_10K_1/16W_1%_0402_402_10,1%10,1%
402RES_12.1K_1/16W_1%_0402_402_12.12.1K,1%
402RES_0_1/16W_1%_0402_402_10K,1%10K,1%
805CAP_10UF_Y5V_10V_10%_0805_805_110uF,10V
2520IND_2.2UH_2.6A_10%_SMD_2520_LQMLQM2HPN2R2MG0L
AM33XX_15X15IC_AM335X_ZCZ_AM33XX_15X15_AM33AM3358BZCZ100
BGA96_T9_P8_9X14MT47H256M8_7_BGA96_T9_P8_9X14_MMT41K256M16HA -125:E
BGA153_P14_P5_11P5X13MEM_MNAND_2GB_BGA153_P14_P5_11PMEM_MNAND_2GB
DCK5_2P15X1P4IC_SN74LVC1G06DCK_0_DCK5_2P15X1SN74LVC1G06DCK
DCK5_2P15X1P4IC_SN74LVC1G07DCK_DCK5_2P15X1P4SN74LVC1G07DCK
DGN-16X60TPS2061_1_DGN-16X60_TPS2051 (DGTPS2051 (DGN)
HEADER10X2_SMDHDR_10X2_CJTAG_0_HEADER10X2_SMDCTI JTAG,DNI
HEADER21X2HDR_42_F_2_0.1_0.1_HEADER21X2_FFEMALE HEADER 2x21
HEADER23X2HDR_46_F_2_0.1_0.1_HEADER23X2_FFEMALE HEADER 2x23
LED_0603LED_LTST-C150GKT_0_LED_0603_DISLTST-C191TBKT
OSC4_61X65LS_79X98SMDOSC_12MHZ_1.3V_OSC4_61X65LS_79X24.576MHZ
QFN32_5X5MM_EP3P3MMLAN8710 QFN32_1_QFN32_5X5MM_EP3LAN8710A
RD205SMD_250DCAP_100UF_TANT_6.3V_3528-21_RD2100uF,6.3V
SD-MICRO-SCHA5B0300MICROSD_CONN_8_SD-MICRO-SCHA5B0SCHA5B0200
SIP6HEADER 6_SIP6_HEADER 6HEADER 6
SM-7351-IND-0805FER_180_200_0_SM-7351-IND-0805_150OHM800mA
SM-7351-IND-0805FER_180_200_0_SM-7351-IND-080_10.1 Ohm,0805
SM-7351-RES-0402RES_SM-7351-RES-0402_240240
SMINI6-F3-BRN1907_SMINI6-F3-B_DMC56404DMC56404
SO8-25X75PWR_TLV70233DBV_0_SO8-25X75_TL5TL5209
SOP8_DCTIC_SN74AUC1G74_SOP8_DCT_SN74AUCSN74AUC1G74
SOT23-5MEM_24LC32_SOT23-5_SOT23-5_24LC24LC32A
SW4SMD_63X161LSSW_KT11P2JM_2_SW4SMD_63X161LS_DKMR231GLFS
SW4SMD_63X161LSSW_KT11P2JM_1_SW4SMD_63X161LS_DKMR231GLFS
TP60C_SMDTESTPT1_TP60C_SMD_TESTPT1TESTPT1
USB5MINI_4SHIELDED_SMD-5MINI-USB-AB-SOCKET_USB5MINI_4SHUSB5MINI
U_6_DRYPROT_TPD4S012_U_6_DRY_TPD4S012TPD4S012
U_8_DCUIC_SN74LVC2G241_1_U_8_DCU_SN74LSN74LVC2G241
U_48_RSLPWR_TPS65217_2_U_48_RSL_TPS6521TPS65217C
XTAL4_126-216SMDCRYS_32_768KHZ_SMD32_1_XTAL4_1232.768KHz MC-306
XTAL150SMD_125X196CRYS_24MHZ_SCC_0_XTAL150SMD_12524MHz
XTAL150SMD_125X196SUNTSU ITEMP 25MHZ _0.005% 20PF25.000MHz
6 U' |7 @3 c& X; U, q) W4 A2 u. N+ z; T& Q" P% h
发表于 2023-8-21 16:38 | 只看该作者
看看,学习参考下
发表于 2023-4-14 18:23 | 只看该作者
看看老方案
+ v8 x: f9 M* l) }1 i0 v- ~
5 P  S  }+ ?4 U: a! ?% X
发表于 2022-12-2 20:52 | 只看该作者
学习一下,谢谢分享!$ K; O; k* F& S+ C5 h7 S
发表于 2020-8-9 11:28 | 只看该作者
不错不错,谢谢分享不错不错,谢谢分享不错不错,谢谢分享不错不错,谢谢分享不错不错,谢谢分享不错不错,谢谢分享不错不错,谢谢分享不错不错,谢谢分享不错不错,谢谢分享
6 g# y+ }& U. s
    2024-4-29 15:07
  • 签到天数: 466 天
    [LV.9]以坛为家II
    发表于 2020-6-24 19:26 | 只看该作者
    :victory::victory::victory::victory::victory::victory:
    慵懒
    2023-1-28 15:08
  • 签到天数: 245 天
    [LV.8]以坛为家I
    发表于 2020-6-24 10:01 | 只看该作者
    AM335x EVM LCD A Board Schematic (Rev 1.1A)! F: k4 z' ]$ k% P* X  d
    2024-8-26 15:16
    发表于 2020-6-5 18:58 | 只看该作者
    多谢楼主无私分享
    ; r. m' b! D* K! x3 C5 \+ M/ O
    发表于 2020-6-5 16:50 | 只看该作者
    ganxieganxie
    7 [9 `0 u; H; s. w3 x  C# ]
    发表于 2019-11-5 22:25 | 只看该作者
    下载看看,谢谢
    发表于 2019-9-9 20:15 | 只看该作者
    不错哦,还有BOM清单
    GMT+8, 2025-11-27 07:18 , Processed in 0.187500 second(s), 28 queries , Gzip On.
