查看: 2153|回复: 4
ORCAD的DRC错误
发表于 2018-10-17 12:28 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
Checking Electrical Rules WARNING(ORCAP-1608): Net has no driving source N17691529 : t+ }' l! V. q7 x( L( F
                    SCHEMATIC1, 09:Connector  (6.21, 6.55)
) G3 i1 O0 R7 O1 Y$ c8 BWARNING(ORCAP-1608): Net has no driving source N17764312
1 y( J# f+ i3 w- F                    SCHEMATIC1, 08:FLASH  (230.38, 86.36) % N4 ~4 h* r& I/ u, y& }
$ ?0 o( u4 q) J
Checking For Single Node Nets
6 Q7 a! e7 u" K2 j+ TWARNING(ORCAP-1600): Net has fewer than two connections N17691529
6 A& S: p5 [" O  `                    SCHEMATIC1, 09:Connector  (6.21, 6.55) 2 ?" ~- d% c& c( U8 H
WARNING(ORCAP-1600): Net has fewer than two connections N17764312 - P/ Q6 p6 b- L( G8 l% `, B
; b9 z, e* o# j5 C
3 i: D' M1 O: l- O9 Y( V7 _5 r: m这个DR处理不掉!. P! u. t% w) ]5 z4 Z8 o
尝试:尝试将网络重新连接也还是有,有没有解决过的老铁,帮忙解答下,谢谢7 d! ]8 L' A. ?3 G" _' M
* Y* x2 U+ }* u/ X
" Y1 r! Y. B0 |( b# q6 I- z7 Y+ s# y6 Q
发表于 2018-10-17 22:21 | 只看该作者
WARNING(ORCAP-1600): Net has fewer than two connections N17691529                      SCHEMATIC1, 09:Connector  (6.21, 6.55) & |0 Q& f. O$ x6 o! F5 k  K  D
》》只有单个网络
0 m. S. N, W3 e
谢谢解答  详情 回复 发表于 2018-10-18 08:29
 楼主| 发表于 2018-10-18 08:29 | 只看该作者
qcb99 发表于 2018-10-17 22:21  w3 f( K7 S4 U  {* N! |
WARNING(ORCAP-1600): Net has fewer than two connections N17691529                      SCHEMATIC1, 0 ...
( Y# J! B& T; s1 x$ g7 V6 u
谢谢解答4 ]4 x( H5 F/ }
GMT+8, 2025-11-23 02:46 , Processed in 0.156250 second(s), 27 queries , Gzip On.
