STM32启动文件详细详解
2024-12-9 15:06| 查看: 86| 评论: 0
摘要: 一、STM32启动文件详细解析 STM32启动文件详细解析(V3.5.0) 以:startup_stm32f10x_hd.s为例 ;********************(C)COPYRIGHT2011STMicroelectronics******************** ;*FileName:startup_stm32 ...
一、STM32启动文件详细解析
;*FileName:startup_stm32f10x_hd.s
;*Author:MCDApplicationTeam
;*Version:V3.5.0
;*Date:11-March-2011
;*Description:STM32F10xHighDensityDevicesvectortableforMDK-ARM
;*toolchain.
;*ThismodulepeRForms:
;*-SettheinitialSP
;*-SettheinitialPC==Reset_Handler
;*-SetthevectortableentrieswiththeexceptionsISRaddress
;*-Configuretheclocksystemandalsoconfiguretheexternal
;*SRAMmountedonSTM3210E-EVALboardtobeusedasdata
;*memory(optional,tobeenabledbyuser)
;*-Branchesto__mainintheClibrary(whicheventually
;*callsmain())。
;*AfterResettheCortexM3processorisinThreadmode,
;*priorityisPrivileged,andtheStackissettoMain.
;THEPRESENTFIRMWAREWHICHISFORGUIDANCEONLYAIMSATPROVIDINGCUSTOMERS
;WITHCODINGINFORMATIONREGARDINGTHEIRPRODUCTSINORDERFORTHEMTOSAVETIME.
;ASARESULT,STMICROELECTRONICSSHALLNOTBEHELDLIABLEFORANYDIRECT,
;INDIRECTORCONSEQUENTIALDAMAGESWITHRESPECTTOANYCLAIMSARISINGFROMTHE
;CONTENTOFSUCHFIRMWAREAND/ORTHEUSEMADEBYCUSTOMERSOFTHECODING
;INFORMATIONCONTAINEDHEREININCONNECTIONWITHTHEIRPRODUCTS.
;Amountofmemory(inbytes)allocatedforStack
;Tailorthisvaluetoyourapplicationneeds
;StackConfiguration;栈定义
;StackSize(inBytes)《0x0-0xFFFFFFFF:8》
Stack_SizeEQU0x00000400;EQU伪指令,作用是左边的符号名代表右边的表达式
AREASTACK,NOINIT,READWRITE,ALIGN=3;定义栈段:名称为STACK,未初始化,可读写,ELF的栈段按2^3=8对齐
Stack_MemSPACEStack_Size;分配一片连续的存储区域并初始化为0,栈空间:0x400个字节
__initial_sp;栈空间顶地址
;HeapConfiguration;堆定义
;HeapSize(inBytes)《0x0-0xFFFFFFFF:8》
Heap_SizeEQU0x00000200
AREAHEAP,NOINIT,READWRITE,ALIGN=3
__heap_base;堆空间起始地址
Heap_MemSPACEHeap_Size;堆空间:0x200个字节
__heap_limit;堆空间结束地址
PRESERVE8RESERVE8指令指定当前文件保持堆栈八字节对齐
THUMB;告诉汇编器下面是32位的Thumb指令,如果需要汇编器将插入位以保证对齐
;VectorTableMappedtoAddress0atReset;中断向量表定义
;实际上是在CODE区(假设STM32从FLASH启动,则此中断向量表起始地址即为0x8000000)
AREARESET,DATA,READONLY;定义一块数据段,只可读,段名字是RESET
EXPORT__Vectors;EXPORT:在程序中声明一个全局的标号__Vectors,该标号可在其他的文件中引用
本站拥有对此声明的最终解释权。
GMT+8, 2025-7-6 16:46 , Processed in 0.125000 second(s), 28 queries , Gzip On.
