因为想用串口3,但配置了很长时间还是不行,为什么UART1,2行,UART3就不行的,最后原因是:使能GPIOB,端口时钟 USART3时钟,我只使能了UART3时钟,没有使能UART3所在端口GPIOB的时钟,所以导致无法正常启动串口3。 下面具体写下串口配置过程: 1:系统时钟初始化,包括系统时钟和要开放的IO口和串口的时钟配置。 2:IO口初始化,包括引脚,速率,输入输出模式等。 3:配置USART的波特率,数据位等。 对应的3个函数,相当有条理 /--------------——————---------------------------------------------------------------------/ void RCC_Configuration(void) { RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOB , ENABLE); //使能UART3所在GPIOB的时钟 RCC_APB1PeriphClockCmd(RCC_APB1Periph_USART3,ENABLE); //串口时钟配置 } void GPIO_Configuration(void) { GPIO_InitTypeDef GPIO_InitStructure; // Configure USART3 Tx (PB.10) as alternate function push-pull GPIO_InitStructure.GPIO_Pin = GPIO_Pin_10; GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP; GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz; GPIO_Init(GPIOB, &GPIO_InitStructure); // Configure USART3 Rx (PB.11) as input floating GPIO_InitStructure.GPIO_Pin = GPIO_Pin_11; GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING; GPIO_Init(GPIOB, &GPIO_InitStructure); } void USART_Configuration(void) { USART_InitStructure.USART_BaudRate = 38400; USART_InitStructure.USART_WordLength = USART_WordLength_8b; USART_InitStructure.USART_StopBits = USART_StopBits_1; USART_InitStructure.USART_Parity = USART_Parity_No; USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None; USART_InitStructure.USART_Mode = USART_Mode_Rx | USART_Mode_Tx; USART_Init(USART3, &USART_InitStructure); // 使能 USART3 USART_Cmd(USART3, ENABLE); } |
/1
GMT+8, 2025-10-27 11:27 , Processed in 0.140625 second(s), 27 queries , Gzip On.
